2008-02-05 | AT91SAM9RL: Fix Dataflash timing | Justin Waters | |
The timings for the dataflash chip on the SAM9RL-EK board are incorrect. This patch fixes them. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Justin Waters <justin.waters@timesys.com> | |||
2008-01-21 | Add Atmel AT91 patch version 1.5 | Justin Waters | |
This patch adds support for the following boards: AT91RM9200-EK AT91SAM9260-EK AT91SAM9261-EK AT91SAM9263-EK AT91SAM9RL-EK It was downloaded from http://www.linux4sam.org/twiki/pub/Linux4SAM/U-Boot/u-boot-1.1.5_atmel_1.5.diff.bz2 Signed-off-by: Justin Waters <justin.waters@timesys.com> | |||
2006-10-20 | Fix compile problem in include/configs/ep82xxm.h | Wolfgang Denk | |
(must have never been tested before!) | |||
2006-10-20 | Add board/cpu specific NAND chip select function to 440 NDFC | Stefan Roese | |
Based on idea and implementation from Jeff Mann Patch by Stefan Roese, 20 Oct 2006 | |||
2006-10-18 | Coding Style cleanup. | Wolfgang Denk | |
2006-10-18 | Merge with /home/tur/proj/051_uboot_linux_v38b/u-boot | Wolfgang Denk | |
2006-10-13 | Preliminary patch adding support for the MarelV38B board. | Bartlomiej Sieka | |
2006-10-10 | * Several improvements to the new NAND subsystem: | Stefan Roese | |
- JFFS2 related commands implemented in mtd-utils style - Support for bad blocks - Bad block testing commands - NAND lock commands Please take a look at doc/README.nand for more details Patch by Guido Classen, 10 Oct 2006 | |||
2006-10-09 | Define IH_CPU_AVR32 | Stefan Roese | |
Make it possible to generate AVR32 uImage files with mkimage and make cmd_bootm recognize them. Patch by Haavard Skinnemoen, 22 Sep 2006 | |||
2006-10-09 | Add missing files for EP82xxM boards | Wolfgang Denk | |
Patch by Aaron Sells, 20 Jun 2006 | |||
2006-10-09 | Coding style cleanup | Wolfgang Denk | |
2006-10-08 | Merge with git+ssh://fifi/home/wd/git/u-boot/master | Wolfgang Denk | |
2006-10-05 | Merge with /home/m8/git/u-boot | Wolfgang Denk | |
2006-10-03 | Update for CAM5200 board: | Marian Balakowicz | |
- Map in a additional chip selects CS4 and CS5. - Modify the port configration, configure six UARTs and no PCI, ATA and USB. - Add custom flash driver to handle specific byte swapping | |||
2006-09-20 | Fix comments in include/ppc440.h | Wolfgang Denk | |
Patch by Martin Hicks, 16 Jun 2006 | |||
2006-09-13 | Add support for AMCC Rainier PPX440GRx eval board | Stefan Roese | |
Patch by Stefan Roese, 13 Sep 2006 | |||
2006-09-12 | Add NAND environment support for PPC440EPx Sequoia NAND boot config | Stefan Roese | |
Patch by Stefan Roese, 12 Sep 2006 | |||
2006-09-07 | Fix build problem with CPCI440 | Stefan Roese | |
Patch by Stefan Roese, 07 Sep 2006 | |||
2006-09-07 | Change Yellowstone to use CFI write buffer | Stefan Roese | |
Patch by Stefan Roese, 07 Aug 2006 | |||
2006-09-07 | Add support for AMCC Sequoia PPC440EPx eval board | Stefan Roese | |
- Add support for PPC440EPx & PPC440GRx - Add support for PPC440EP(x)/GR(x) NAND controller in cpu/ppc4xx directory - Add NAND boot functionality for Sequoia board, please see doc/README.nand-boot-ppc440 for details - This Sequoia NAND image doesn't support environment in NAND for now. This will be added in a short while. Patch by Stefan Roese, 07 Sep 2006 | |||
2006-09-04 | Fix build problems on sorcery board. | Wolfgang Denk | |
2006-09-03 | Fixed problems on PRS200 board caused by adding splash screen on MCC200 | Wolfgang Denk | |
2006-09-01 | Added simple_strtoul(), getenv() and setenv() to the exported functions. | Detlev Zundel | |
Also bumped up ABI version to reflect this change. | |||
2006-09-01 | Added interrupt handling capabilities for mpc5xxx processors. | Detlev Zundel | |
Also added Linux like BUG() macros. | |||
2006-08-30 | Add splashscreen support for MCC200 board. | Wolfgang Denk | |
2006-08-30 | Make the serial driver framework work with CONFIG_SERIAL_MULTI enabled | Wolfgang Denk | |
2006-08-29 | Fix typo. | Wolfgang Denk | |
2006-08-27 | Code cleanup | Wolfgang Denk | |
2006-08-25 | Fix typo in MCC200/PRS200 configuration | Wolfgang Denk | |
2006-08-25 | Update for MCC200 / PRS200 boards: | Wolfgang Denk | |
- auto-adjust console device for Linux. - fix typos. | |||
2006-08-25 | Merge with /home/tur/proj/fo300/u-boot | Wolfgang Denk | |
2006-08-24 | Updates for MCC200 / PRS200 boards: | Wolfgang Denk | |
- support for configurations with SDRAM or DDR memory, - support for highboot and lowboot - adjusting environment definitions | |||
2006-08-22 | Add a fix for a buggy USB device on the FO300 board. | Bartlomiej Sieka | |
2006-08-18 | Minor cleanup | Wolfgang Denk | |
2006-08-18 | Add support for WTK FO300 board (TQM5200 based). | Marian Balakowicz | |
2006-08-18 | Merge with /home/raj/git/u-boot | Wolfgang Denk | |
2006-08-18 | Merge with git+ssh://fifi/home/wd/git/u-boot/master | Wolfgang Denk | |
2006-08-18 | Fix TQM834x hang. | Rafal Jaworowski | |
2006-08-17 | Cleanup debug code for yucca board. | Wolfgang Denk | |
2006-08-17 | Add debug console on COM12 for MCC200 board | Wolfgang Denk | |
2006-08-14 | Fixed common.h spelling error. | Wolfgang Denk | |
Patch by Cory Tusar, 30 Nov 2005 | |||
2006-08-14 | Fix fatload command on FAT32 formatted partitions. | Wolfgang Denk | |
Patch by Joachim Jaeger, 18 Nov 2005 | |||
2006-08-13 | Merge with /home/sr/git/u-boot/denx | Wolfgang Denk | |
2006-08-11 | Merge with /home/raj/git/u-boot | Wolfgang Denk | |
2006-08-11 | Fix preboot message on TQM85xx after switching to hush parser. | Wolfgang Denk | |
2006-08-11 | Adapt TQM85xx ramdisk address to Linux kernel memory map | Wolfgang Denk | |
2006-08-11 | Fix PCI-Express on PPC440SPe rev. A. | Rafal Jaworowski | |
2006-08-10 | Merge with /home/raj/git/u-boot | Wolfgang Denk | |
2006-08-10 | Add support for PCI-Express on PPC440SPe (Yucca board). | Rafal Jaworowski | |
2006-08-07 | Merge with /home/tur/proj/usb_sticks/u-boot | Wolfgang Denk | |
