path: root/include
2008-07-15Merge branch 'master' of git://git.denx.de/u-boot-mpc5xxxWolfgang Denk
2008-07-15Merge branch 'master' of git://git.denx.de/u-boot-mpc86xxWolfgang Denk
2008-07-15Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
2008-07-15mpc5xxx: Add MVBC_P board supportAndre Schwarz
The MVBC_P is a MPC5200B based camera system with Intel Gigabit ethernet controller (using e1000) and custom Altera Cyclone-II FPGA on PCI. Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2008-07-15Update Freescale sys_eeprom.c to handle CCID formatsTimur Tabi
Update the sys_eeprom.c file to handle both NXID and CCID EEPROM formats. The NXID format replaces the older CCID format, but it's important to support both since most boards out there still use the CCID format. This change is in preparation for using one file to handle both formats. This will also unify EEPROM support for all Freescale 85xx and 86xx boards. Also update the 86xx board header files to use the standard CFG_I2C_EEPROM_ADDR instead of ID_EEPROM_ADDR. Signed-off-by: Timur Tabi <timur@freescale.com>
2008-07-14Clean up INIT_RAM optionsAndy Fleming
The L2_INIT_RAM option was unused, and recent changes to the TLB code meant that the INIT_RAM TLBs weren't being cleared out. In order to reduce the amount of mapped space attached to nothing, we change things so the TLBs get cleared. Signed-off-by: Andy Fleming <afleming@freescale.com>
2008-07-14Remove fake flash bank from 8544 DSAndy Fleming
The fake flash bank was generating errors for anyone who didn't have a PromJET hooked up to the board. As that constitutes the vast majority of users, we remove it. Signed-off-by: Andy Fleming <afleming@freescale.com>
2008-07-14MPC8544DS: Add ATI Video card supportKumar Gala
Add support for using a PCIe ATI Video card on PCIe2. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-07-1485xx: Add some L1/L2 SPR register definitionsKumar Gala
Add new L1/L2 SPRs related to e500mc cache config and control. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-07-14sbc8560: enable CONFIG_OF_LIBFDT by defaultPaul Gortmaker
Make the default build for the sbc8560 board be powerpc capable with libfdt support. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2008-07-14Fix indentation for default boot environment variablesAndy Fleming
This was proposed by Paul Gortmaker in response to Wolfgang's comments on similar #defines in sbc8560.h. Signed-off-by: Andy Fleming <afleming@freescale.com>
2008-07-14sbc8560: add default fdt valuesPaul Gortmaker
Add in the default fdt settings and the typical EXTRA_ENV settings as borrowed from the mpc8560ads. Fix a couple of stale references to the mpc8560ads dating back to the original clone/fork. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2008-07-14sbc8560: define eth0 and eth1 instead of eth1 and eth2Paul Gortmaker
The existing config doesn't define CONFIG_HAS_ETH0, and so the fdt support doesn't update the zeros in the dtb local-mac with real data from the u-boot env. Since the existing config is tailored to just two interfaces, get rid of the ETH2 definitions at the same time. Also don't include any end user specific data into the environment by default -- things like MAC address, network parameters etc. need to come from the end user. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2008-07-14sbc8560: proper definitions for TSEC.Paul Gortmaker
The definitions for the TSEC have become out of date. There is no longer any such options like "CONFIG_MPC85xx_TSEC1" or similar. Update to match those of other boards, like the MPC8560ADS. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2008-07-14fdt: add crypto node handling for MPC8{3, 5}xxE processorsKim Phillips
Delete the crypto node if not on an E-processor. If on 8360 or 834x family, check rev and up-rev crypto node (to SEC rev. 2.4 property values) if on an 'EA' processor, e.g. MPC8349EA. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-07-14Remove LBC_CACHE_BASE from 8544 DSAndy Fleming
The 8544 DS doesn't have any cacheable Local Bus memories set up. By mapping space for some anyway, we were allowing speculative loads into unmapped space, which would cause an exception (annoying, even if ultimately harmless). Removing LBC_CACHE_BASE, and using LBC_NONCACHE_BASE for the LBC LAW solves the problem. Signed-off-by: Andy Fleming <afleming@freescale.com>
2008-07-13Fix some more printf() format issues.Wolfgang Denk
2008-07-13hwmon: rename CONFIG_DS1722 to CONFIG_DTT_DS1722Michal Simek
Signed-off-by: Michal Simek <monstr@monstr.eu> Acked-by: Stefan Roese <sr@denx.de>
2008-07-13hwmon: Cleaning hwmon devicesMichal Simek
Clean Makefile Move device specific values to driver for better reading Signed-off-by: Michal Simek <monstr@monstr.eu> Acked-by: Stefan Roese <sr@denx.de>
2008-07-13microblaze: Remove useless ancient headersMichal Simek
2008-07-13microblaze: Clean uartlite driverMichal Simek
Redesign uartlite driver to in_be32 and out_be32 macros Fix missing header in io.h Signed-off-by: Michal Simek <monstr@monstr.eu> Acked-by: Grant Likely <grant.likely@secretlab.ca>
2008-07-13Enable passing of ATAGs required by latest Linux kernel.Marcel Ziswiler
2008-07-13ARM: Fix for broken compilation when defining CONFIG_CMD_ELFHugo Villeneuve
caused by missing dcache status/enable/disable functions. Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com>
2008-07-13Merge branch 'master' of git://git.denx.de/u-boot-coldfireWolfgang Denk
2008-07-11Fix compile error caused by missing timer functionTsiChung Liew
Add #define CONFIG_MCFTMR in EB+MCF-EV123.h configuration file Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-07-11ColdFire: Fix timer issue for MCF5272TsiChung Liew
The timer was assigned to wrong timer memory mapped which caused udelay() and timer() not working properly. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-07-11ColdFire: Fix code flash configuration for M547x/M548x boardsTsiChung Liew
Signed-off-by: Kurt Mahan <kmahan@freescale.com>
2008-07-10DataFlash AT45DB021 supportSergey Lapin
Some boards based on AT91SAM926X-EK use smaller DF chips to keep bootstrap, u-boot and its environment, using NAND or other external storage for kernel and rootfs. This patch adds support for small 1024x263 chip. Signed-off-by: Sergey Lapin <slapin@ossfans.org>
2008-07-10Merge branch 'master' of git://git.denx.de/u-boot-mpc512xWolfgang Denk
2008-07-10Configuration changes for ADS5121 Rev 3Martha Marx
ADS5121 Rev 3 board is now the default config config targets are now ads5121_config Rev 3 board with PCI M41T62 on board RTC 512MB DRAM ads5121_rev2_config Rev 2 board with No PCI 256MB DRAM Signed-off-by: Martha Marx <mmarx@silicontkx.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: John Rigby <jrigby@freescale.com>
2008-07-10Consolidate ADS5121 IO Pin configurationMartha Marx
Consolidate ADS5121 IO Pin configuration to one file board/ads5121/iopin.c. Remove pin config from cpu/mpc512x/fec.c Signed-off-by: Martha Marx <mmarx@silicontkx.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: John Rigby <jrigby@freescale.com>
2008-07-10Merge commit 'wd/master'Jon Loeliger
2008-07-10ppc4xx: Enable support for > 2GB SDRAM on AMCC KatmaiStefan Roese
Newer PPC's like 440SPe, 460EX/GT can be equipped with more than 2GB of SDRAM. To support such configurations, we "only" map the first 2GB via the TLB's. We need some free virtual address space for the remaining peripherals like, SoC devices, FLASH etc. Note that ECC is currently not supported on configurations with more than 2GB SDRAM. This is because we only map the first 2GB on such systems, and therefore the ECC parity byte of the remaining area can't be written. Signed-off-by: Stefan Roese <sr@denx.de>
2008-07-10ppc4xx: Remove implementation of testdram() from Korat board supportLarry Johnson
Signed-off-by: Larry Johnson <lrj@acm.org> Signed-off-by: Stefan Roese <sr@denx.de>
2008-07-10ppc4xx: Update and add FDT to Korat board supportLarry Johnson
2008-07-10Merge branch 'master' of git://www.denx.de/git/u-boot-nand-flashWolfgang Denk
2008-07-10e1000: add support for 82545GM 64bit PCI-X copper variantPaul Gortmaker
This PCI-X e1000 variant works by just adding in the correct PCI IDs in the appropriate places. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2008-07-10SPARC: Build error fixDaniel Hellstrom
(introduced by commit 391fd93ab23e15ab3dd58a54f5b609024009c378) This patch makes SPARC targets build again. It is caused by phys_addr_t and phys_size_t being defined in the wrong header file. include/lmb.h need those typedefs to build. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
2008-07-09NAND: ifdef-protect most of nand.h when using legacy NAND.Scott Wood
Some macros such as NAND_CTL_SETALE conflict between current and legacy NAND, being defined by the subsystem in the former case and the board config file in the latter. Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-07-10ARM: Fix for wrong patch version applied for Lyrtech SFF-SDR board (ARM926EJS)Hugo Villeneuve
ARM: Fix for incorrect version of patch applied when adding support for the Lyrtech SFF-SDR board. Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com> Signed-off-by: Philip Balister, OpenSDR <philip@opensdr.com>
2008-07-10Fix LMB type issuesAndy Fleming
The LMB code now uses phys_addr_t and phys_size_t. Also, there were a couple of casting problems in the bootm code that called the LMB functions. Signed-off-by: Andy Fleming <afleming@freescale.com>
2008-07-10Remove code duplication for setting the default environmentHarald Welte
common/env_common.c (default_env): new function that resets the environment to the default value common/env_common.c (env_relocate): use default_env instead of own copy common/env_nand.c (env_relocate_spec): use default_env instead of own copy include/environment.h: added default_env prototype Signed-off-by: Werner Almesberger <werner@openmoko.org> Signed-off-by: Harald Welte <laforge@openmoko.org>
2008-07-09NAND: Rename DEBUG to MTDDEBUG to avoid namespace pollution.Scott Wood
This is particularly problematic now that non-NAND-specific code is including <nand.h>, and thus all debugging code is being compiled regardless of whether it was requested, as reported by Scott McNutt <smcnutt@psyent.com>. Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-07-10avr32: Use CONFIG_ATMEL_MCI to select the atmel_mci driverHaavard Skinnemoen
After we move the atmel_mci driver into drivers/mmc, we can't select it with CONFIG_MMC anymore. Introduce a new symbol specifically for this driver so that there's no ambiguity. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Acked-by: Jean-Chritophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-07-09Change env_get_char from a global function ptr to a functionJoakim Tjernlund
This avoids an early global data reference. Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
2008-07-09FDT memory and pci node fixes for MPC8260ADSMatvejchikov Ilya
Signed-off-by: Matvejchikov Ilya <matvejchikov@gmail.com>
2008-07-09Fix printf errors.Andrew Klossner
The compiler will help find mismatches between printf formats and arguments if you let it. This patch adds the necessary attributes to declarations in include/common.h, then begins to correct the resulting compiler warnings. Some of these were bugs, e.g., "$d" instead of "%d" and incorrect arguments. Others were just annoying, like int-long mismatches on a system where both are 32 bits. It's worth fixing the annoying errors to catch the real ones. Signed-off-by: Andrew Klossner <andrew@cesa.opbu.xerox.com>
2008-07-09Merge branch 'master' of git://www.denx.de/git/u-boot-netWolfgang Denk
2008-07-08sh: Fix compile error sh7763rdp boardNobuhiro Iwamatsu
Disable SH ether driver. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-07-07Feed the watchdog in u-boot for 8610 board.Jason Jin
The watchdog on 8610 board is enabled by setting sw[6] to on. Once enabled, the watchdog can not be disabled by software. So feed the dog in u-boot is necessary for normal operation. Signed-off-by: Jason Jin <Jason.jin@freescale.com>
