CONFIG_ENABLE_CORTEXA9 and CONFIG_SKIP_RELOCATE_UBOOT are not needed,
so remove them.
Signed-off-by: Tom Warren <twarren@nvidia.com>
We want to move away from a special Tegra2 start-up, and just use
arch_cpu_init() instead. However, if we run board_init_f() from boot
we need to build it for ARMv4T, since the Tegra's AVP start-up CPU
does not support ARMv7.
The effect of this is to do the AVP init earlier, and in
arch_cpu_init(), rather that board_early_init_f().
Ventana is a board which is very similar to Seaboard. Support it by
re-using board/nvidia/seaboard/seaboard.c with minor run-time conditionals.
v5: Makefile: Use cmd_link_o_target, remove unused clean/distclean targets.
v6: Make gpio_config_uart_seaboard() static.
v7: Add MAINTAINERS entry for Ventana. Tom Warren doesn't have Ventana, so
he asked me to add myself for this board.
This fixes the build of the two sh boards shmin and r7780mp and qemu-mips
which currently fail to build due to dropped pre-CONFIG_NET_MULTI code.
This v2 patch minimizes the number of lines in the diff for easy review
and to eliminate any possible accidential changes resulting from moving
lines of code in the file. This also makes the register function very easy.
Any cleanups and improvements are intentionally deferred to follow-up patches
to keep this patch as simple and as easy to review as possible.
A new driver register function, ne2k_register() calls the existing
one-time setup part of the old init function and calls eth_register().
Changes to shmin, r7780mp and qemu-mips:
- Call the new ne2k_register() from board_eth_init() of the boards.
- Tested using qemu-mips board,
- Tested the two renesas / sh boards r7780mp and shmin to compile again,
and should work.
checkpatch-clean when "--ignore VOLATILE" is added to .checkpatch.conf,
and no warnings introduced in none of the three boards using this driver.
Signed-off-by: Bernhard Kaindl <bernhard.kaindl@gmx.net>
The "rmu" board has long been unmaintained, and is broken.
Remove it.
The OXC board has long been unmaintained, and is broken.
Remove it.
The BAB7xx boards are almost deceased. They cause build warnings, an
it's not worth the effort to fix these. Remove the dead body.
Cc: Frank Gottschling <fgottschling@eltec.de>
* 'master' of git://git.denx.de/u-boot-arm:
davinci: Remove unwanted memsize.c from hawkboard's nand spl build
devkit8000: Move CONFIG_SYS_TEXT_BASE out of bss
da850evm: pass board revision info to kernel
arch/arm/include/asm/arch-omap5/clocks.h: Fix GCC 4.2 warnings
arch/arm/cpu/armv7/omap-common/clocks-common.c: Fix GCC 4.6 warnings
arch/arm/cpu/armv7/omap-common/spl.c: Fix GCC 4.2 warnings
MX35: flea3: changes due to hardware revision B
MX: serial_mxc: cleanup removing nasty #ifdef
M28: Fix OB1 bug in GPIO driver
MXS: Add static annotations to dma driver
apbh_dma: return error value on timeout
Efika: Configure additional regulators for HDMI output
mx5: Correct a warning in clock.c
MC13892: Add REGMODE0 bits definitions
mx51evk: Configure the pins as GPIOs prior to using gpio_get_value
mx53smd: Configure the pins as GPIOs prior to using gpio_get_value
mx53evk: Configure the pins as GPIOs prior to using gpio_get_value
mx53ard: Configure the pins as GPIOs prior to using gpio_get_value
mx53loco: Configure the pins as GPIOs prior to using gpio_get_value
OMAP3: Add SPL_BOARD_INIT hook
AM3517 CraneBoard: Add SPL support
AM3517: Add SPL support
OMAP3: Add SPL support to omap3_evm
OMAP3: Add SPL support to Beagleboard
OMAP3 SPL: Add identify_nand_chip function
OMAP3 SPL: Rework memory initalization and devkit8000 support
OMAP3: Suffix all Micron memory timing parts with their speed
OMAP3: Add optimal SDRC autorefresh control values
omap3: mem: Add MCFG helper macro
OMAP3: Remove get_mem_type prototype
OMAP3: Change mem_ok to clear again after reading back
OMAP3: Add a helper function to set timings in SDRC
OMAP3: Update SDRC dram_init to always call make_cs1_contiguous()
omap3: mem: Comment enable_gpmc_cs_config more
ARM: davici_emac: Fix condition for number of phy detects
arm: printf() is not available in some SPL configurations
arm, davinci: add support for am1808 based enbw_cmc board
arm, davinci: move misc function in arch tree
arm, board/davinci/common/misc.c: Codingstyle cleanup
arm, davinci, da850: add uart1 tx rx pinmux config
arm, davinci: move davinci_rtc struct to hardware.h
arm, davinci: Remove duplication of pinmux configuration code
arm, hawkboard: Use the pinmux configurations defined in the arch tree
arm, da850evm: Use the pinmux configurations defined in the arch tree
arm, da850: Add pinmux configurations to the arch tree
arm, da850evm: Do pinmux configuration for EMAC together with other pinmuxes
arm, hawkboard: Remove obsolete struct pinmux_config i2c_pins
arm, davinci: Move pinmux functions from board to arch tree
arm, arm926ejs: always do cpu critical inits
omap_gpmc: use SOFTECC in SPL if it's enabled
nand_spl_simple: add support for software ECC
AM3517: move AM3517 specific mux defines to generic header
AM35xx: add EMAC support
davinci_emac: hardcode 100Mbps for AM35xx and RMII
davinci_emac: fix for running with dcache enabled
arm926ejs: add noop implementation for dcache ops
davinci_emac: conditionally compile specific PHY support
davinci_emac: use internal addresses in buffer descriptors
davinci_emac: move arch-independent defines to separate header
BeagleBoard: config: Really switch to ttyO2
ARM: davinci_dm6467Tevm: Fix build breakage
ARM: OMAP: Remove STACKSIZE for IRQ and FIQ if unused
ARM: OMAP3: Remove unused define SDRC_R_C_B
ARM: OMAP3: Remove unused define CONFIG_OMAP3430
omap4: fix IO setting
omap4+: streamline CONFIG_SYS_TEXT_BASE and other SDRAM addresses
omap4460: add ES1.1 identification
omap4: emif: fix error in driver
omap: remove I2C from SPL
omap4460: fix TPS initialization
omap: fix cache line size for omap3/omap4 boards
omap4: ttyO2 instead of ttyS2 in default bootargs
omap: Improve PLL parameter calculation tool
start.S: remove omap3 specific code from start.S
armv7: setup vector
armv7: include armv7/cpu.c in SPL build
armv7: disable L2 cache in cleanup_before_linux()
arm, arm926ejs: Fix clear bss loop for zero length bss
PXA: Move colibri_pxa270 to board/toradex/
PXA: Flip colibri_pxa27x to pxa-common.h
PXA: Introduce common configuration header for PXA
PXA: Rename pxa_dram_init to pxa2xx_dram_init
PXA: Squash extern pxa_dram_init()
PXA: Export cpu_is_ and pxa_dram_init functions
PXA: Cleanup Colibri PXA270
PXA: Replace timer driver
PXA: Add cpuinfo display for PXA2xx
PXA: Separate PXA2xx CPU init
PXA: Rename CONFIG_PXA2[57]X to CONFIG_CPU_PXA2[57]X
PXA: Unify vpac270 environment size
PXA: Enable command line editing for vpac270
PXA: Adapt Voipac PXA270 to OneNAND SPL
PXA: Drop Voipac PXA270 OneNAND IPL
PXA: Fixup PXA25x boards after start.S update
PXA: Re-add the Dcache locking as RAM for pxa250
PXA: Rework start.S to be closer to other ARMs
PXA: Drop XM250 board
PXA: Drop PLEB2 board
PXA: Drop CRADLE board
PXA: Drop CERF250 board
Fix regression in SMDK6400
nand: Add common functions to linux/mtd/nand.h
Ethernut 5 board support
net: Armada100: Fix compilation warnings
ARM: remove duplicated code for LaCie boards
ARM: add support for LaCie 2Big Network v2
mvsata: fix ide_preinit for missing disks
netspace_v2: Read Ethernet MAC address from EEPROM
omap3evm: Add support for EFI partitions
part_efi: Fix compile errors
TPM (Trusted Platform Module) is an integrated circuit and
software platform that provides computer manufacturers with the
core components of a subsystem used to assure authenticity,
integrity and confidentiality.
This driver supports version 1.2 of the TCG (Trusted Computing
Group) specifications.
The TCG specification defines several so called localities in a
TPM chip, to be controlled by different software layers. When
used on a typical x86 platform during the firmware phase, only
locality 0 can be accessed by the CPU, so this driver even while
supporting the locality concept presumes that only locality zero
is used.
This implementation is loosely based on the article "Writing a
TPM Device Driver" published on http://ptgmedia.pearsoncmg.com
Compiling this driver with DEBUG defined will generate trace of
all accesses to TMP registers.
This driver has been tested and is being used in three different
functional ChromeOS machines (Pinetrail and Sandy Bridge Intel
chipsets) all using the same Infineon SLB 9635 TT 1.2 device.
A u-boot cli command allowing access to the TPM was also
implemented and is being submitted as a second patch.
Change-Id: I22a33c3e5b2e20eec9557a7621bd463b30389d73
Signed-off-by: Vadim Bendebury <vbendeb@chromium.org>
CC: Wolfgang Denk <wd@denx.de>
This reverts commit 5c45a22b9203351a32aec4600514341b91175542.
It causes a lot of "incompatible pointer type" warnings for a large
number of Ethernet drivers, which are not really worth fixing
especially as this patch was only supposed to help the old,
deprecated miiphy API. Instead of adding more efforts to a lost case
we rather revert it.
This moves CONFIG_SYS_TEXT_BASE one MB after beginning of SD-RAM. Move
CONFIG_SYS_SPL_MALLOC_START to have one MB of free space for the u-boot
image.
CONFIG_SYS_TEXT_BASE was in the middle of the bss-section. This was the
reason for the problems with MMC boot described here:
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/118711
Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com>
Tested-by: Thomas Weber <weber@corscience.de>
there are two boards based on da850 SOC - OMAP-L138 and AM18x.
In order to differentiate between these two boards, revision id
is passed to kernel via second byte of ATAG_REVISION.
Signed-off-by: Manjunathappa, Prakash <prakash.pm@ti.com>
Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com>
Revision B of the board uses CSD0 for the DRAM,
as usual for MX3 boards. The patch fixes also
some values in the U-Boot environment.
The serial driver for iMX SOCs is continuosly changed if a
new SOC or not yet used port is used. CONFIG_SYS_<SOC>_<UART Port>
defines were used only to find the base address for the selected UART.
Instead of that, move the base address to the board configuration
file and drop all #ifdef from driver.
CC: Marek Vasut <marek.vasut@gmail.com>
CC: Fabio Estevam <fabio.estevam@freescale.com>
CC: Helmut Raiger <helmut.raiger@hale.at>
CC: John Rigby <jcrigby@gmail.com>
CC: Matthias Weisser <weisserm@arcor.de>
CC: Jason Liu <jason.hui@linaro.org>
Acked-by: Jason Liu <jason.hui@linaro.org>
Add an SPL_BOARD_INIT hook and for OMAP3 have it turn on i2c. OMAP4
doesn't need i2c enabled in SPL. Enable SPL_BOARD_INIT on devkit8000.
Cc: Frederik Kriewitz <frederik@kriewitz.eu>
The only change of note is that we move from 0x80008000 to 0x80100000
for CONFIG_SYS_TEXT_BASE
Cc: Nagendra T S <nagendra@mistralsolutions.com>
Tested-by: Koen Kooi <k-kooi@ti.com>
Cc: Vaibhav Hiremath <hvaibhav@ti.com>
Add Hynix 200MHz timing information to <asm/arch-omap3/mem.h>.
This also changes CONFIG_SYS_TEXT_BASE to 0x80100000.
This introduces 200MHz Micron parts timing information based on x-loader
to <asm/arch-omap3/mem.h> and Numonyx MCFG calculation. The memory init
logic is also based on what x-loader does in these cases. Note that
while previously u-boot would be flashed in with SW ECC in this case it
now must be flashed with HW ECC. We also change CONFIG_SYS_TEXT_BASE to
0x80100000.
Cc: Dirk Behme <dirk.behme@gmail.com>
Beagleboard rev C5, xM rev A:
Tested-by: Tom Rini <trini@ti.com>
Beagleboard xM rev C:
Tested-by: Matt Ranostay <mranostay@gmail.com>
Beagleboard rev B7, C2, xM rev B:
Tested-by: Matt Porter <mporter@ti.com>
This changes to making the board be responsible for providing the
memory initialization timings in SPL and converts the devkit8000
to this framework. In SPL we try and initialize both CS0 and CS1.
- booting from NOR Flash with direct boot method
- POST support
- LOGBUF support
Cc: Paulraj Sandeep <s-paulraj@ti.com>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Cc: Christian Riesch <christian.riesch@omicron.at>
The boards in board/davinci/da8xxevm/ define pinmux_config[] vectors
that contain pinmux configurations for emac, uarts, memory controllers...
In an earlier patch such pinmux configurations were added to the arch
tree. This patch makes the hawkboard use these definitions instead of
defining its own.
Signed-off-by: Christian Riesch <christian.riesch@omicron.at>
Cc: Sandeep Paulraj <s-paulraj@ti.com>
Cc: Syed Mohammed Khasim <sm.khasim@gmail.com>
Cc: Sughosh Ganu <urwithsughosh@gmail.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Acked-by: Heiko Schocher <hs@denx.de>
tree. This patch makes the da850evm use these definitions instead of
defining its own.
Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
The previous commit changed it to "zero two" instead of the proper "Oh two". This was completely broken!
Signed-off-by: Koen Kooi <koen@dominion.thruhere.net>
Acked-by: Tom Rini <trini@ti.com>
Fix:
arch/arm/cpu/arm926ejs/davinci/libdavinci.o: In function `timer_init':
/work/agust/git/u-boot/arch/arm/cpu/arm926ejs/davinci/timer.c:62:
undefined reference to `davinci_arm_clk_get'
drivers/i2c/libi2c.o: In function `i2c_init':
/work/agust/git/u-boot/drivers/i2c/davinci_i2c.c:102:
This patch removes the definition of stack sizes for
irq and fiq if the CONFIG_USE_IRQ is undefined before.
Acked-by: Enric Balletbo i Serra <eballetbo@iseebcn.com>
Signed-off-by: Thomas Weber <weber@corscience.de>
Acked-by: Luca Ceresoli <luca.ceresoli@comelit.it>
This patch removes the unused definition of SDRC_R_C_B
from the config files.
This patch removes the CONFIG_OMAP3430, because it is unused.
Change the CONFIG_SYS_TEXT_BASE and the addresses of SDRAM
buffers used by SPL(heap and BSS) keeping in mind the
following requirements:
1. Make sure that SPL's heap and BSS doesn't come in the way
of Linux kernel, which is typically loaded at 0x80008000. This
will be important when SPL directly loads kernel.
2. Align the CONFIG_SYS_TEXT_BASE between TI internal
U-Boot and mainline U-Boot. This avoids a lot of confusion
and allows for the inter-operability of x-loader, SPL,
internal U-Boot, mainline U-Boot etc. The internal U-Boot's
address can not be changed to that of mainline U-Boot
as internal U-Boot doesn't have relocation and 0x80100000
used by mainline U-Boot will clash with kernel
3. Assume only a minimum amount of memory that may be available
on any practical OMAP4/5 board in future too. We are assuming
a minimum of 128 MB of memory
Signed-off-by: Aneesh V <aneesh@ti.com>
Set console=ttyO2 instead of ttyS2 in default bootargs
according to latest kernel config
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
V2: Add missing u-boot-spl.lds, convert bitshifts to division,
convert to spl_onenand_load_image()
The board is unmaintained and maintainer doesn't respond.
Functions often used in SPL are now part of linux/mtd/nand.h.
Static modifiers are removed from these functions in
drivers/mtd/nand/nand_base.c.
Cc: scottwood@freescale.com
Cc: s-paulraj@ti.com
Cc: albert.u.boot@aribaud.net
Acked-by: Scott Wood <scottwood@freescale.com>
Add support for the Ethernut 5 open hardware design, based
on Atmel's AT91SAM9XE512 SoC.
V4
- Fix several coding style issues.
- Move machine type to config file.
- Remove use of CONFIG_ATMEL_LEGACY.
Signed-off-by: Tim Schendekehl <tim.schendekehl@egnite.de>
This patch groups together all the common functions for LaCie boards:
Ethernet PHY and MAC address initializations.
Moreover the configurations for LaCie Kirkwood boards are merged into
a single file: include/configs/lacie_kw.h
Signed-off-by: Simon Guinot <simon.guinot@sequanux.org>
This patch adds support for the LaCie 2Big Network v2 board, based on
the Marvell Kirkwood 6281 SoC.
Additional information is available at:
http://lacie-nas.org/doku.php?id=2big_network_v2
Defines CONFIG_EFI_PARTITION for OMAP3 EVM.
Signed-off-by: Sanjeev Premi <premi@ti.com>
Cc: Tom Rini <tom.rini@gmail.com>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
