* Patch by Curt Brune, 17 May 2004:
- Add support for Samsung S3C4510B CPU (ARM7tdmi based SoC)
- Add support for ESPD-Inc. EVB4510 Board
display even after showing a bitmap
- DDR Ram support for PM520 (MPC5200)
- support for different flash types (PM520)
- USB / IDE / CF-Card / DiskOnChip support for PM520
- 8 bit boot rom support for PM520/CE520
- Add auto SDRAM module detection for MicroSys CPC45 board (MPC8245)
- I2C and RTC support for CPC45
- support of new flash type (28F160C3T) for CPC45
* Remove eth_init() from lib_arm/board.c; it's done in net.net.c.
fix support for Logic SDK-LH7A404 board and clean up the
LH7A404 register macros.
* Patch by Matthew McClintock, 10 Jun 2004:
Modify code to select correct serial clock on Sandpoint8245
Add support for Intel K3 strata flash.
* Some cleanup
* Patch by Thomas Brand, 10 Jun 2004:
Fix "loads" command on DK1S10 board
Add support for Analogue&Micro Adder87x and the older AdderII board.
* Patch by Ming-Len Wu, 09 Jun 2004:
Add suppport for MC9328 (Dargonball) CPU and Motorola MX1ADS board
- Add support for RPXlite_DW board
- Update FLASH driver for 4*AM29DL323DB90VI
- Add option configuration of CFG_ENV_IS_IN_NVRAM on RPXlite_DW board
- Make MPC5200 boards evaluate the SVR to print processor name and
version in checkcpu() (cpu/mpc5xxx/cpu.c).
* Patch by Kai-Uwe Bloem, 06 May 2004:
Fix endianess problem in cramfs code
Add support for Exys XSEngine board
Some code cleanup.
On OMAP1610 platforms check if booting from RAM(CS0) or flash(CS3).
Set flash base accordingly, and decide whether to do or skip board
specific setup steps.
* Patch by Josef Baumgartner, 26 May 2004:
Add missing define in include/asm-m68k/global_data.h
Add support for Interphase iSPAN boards.
- Add support for the Logic Zoom LH7A40x based SDK board(s),
specifically the LPD7A400.
* Patches by Robert Schwebel, 15 May 2004:
- call MAC address reading code also for SMSC91C111;
- make SMSC91C111 timeout configurable, remove duplicate code
- fix get_timer() for PXA
- update doc/README.JFFS2
- use "bootfile" env variable also for jffs2
Add support for Cogent CSB472 board (8MB Flash Rev)
- flash.h: more flash types added
- immap_8260.h: some bits added (useful for RMII)
- cmd_coninfo.c: typo corrected, printf -> puts
- reduced size by replacing spaces with tab
Add 'imgextract' command: extract one part of a multi file image.
(partially, as they contained a lot of crap)
Add support for TI OMAP5912 OSK Board
* Patch by Sam Song May, 07 May 2004:
Fix typo of UPM table for rmu board
- Intracom board update.
- Add Codec POST.
Add support for OMAP730 Perseus2 Development board
* Patch by Alan J. Luse, 29 Apr 2004:
Fix flash chip-select (OR0) option register setting on FADS boards.
Report MII network speed and duplex setting properly when
auto-negotiate is not enabled.
* Patch by Jarrett Redd, 29 Apr 2004:
Fix hang on reset on Ocotea board due to flash in wrong mode.
- Rename DUET_ADS to MPC885ADS
- Rename CONFIG_DUET to CONFIG_MPC885_FAMILY
- Rename CONFIG_866_et_al to CONFIG_MPC866_FAMILY
- Clean up FADS family port to use the new defines
Sort Makefile.
Update docs.
Add Nios GDB/JTAG Console support:
- Add stubs to support gdb via JTAG.
- Add support for console over JTAG.
- Minor cleanup.
Using external watchdog for KUP4 boards in mpc8xx/cpu.c;
load_sernum_ethaddr() for KUP4 boards in lib_ppc/board.c;
various changes to KUP4 board specific files
* Fix PHY discovery problem in cpu/mpc8xx/fec.c (introduced by
patches by Pantelis Antoniou, 30 Mar 2004)
* Fixes for SL811 USB controller:
- implement workaround for broken memory stick
- improve error handling
* Increase packet send timeout to 10 ms in cpu/mpc8xx/scc.c to better
cope with congested networks.
JFFS2 speed enhancements:
- repair header CRC calculation in jffs2_1pass.c
- add eraseblock size to the partition information to skip empty
eraseblocks if we find more then 4k of free space.
- The JFFS2 scanner is now fast enough to remove the spinning wheel
so #ifdef-ed out.
- add watchdog calls in long running loops
* Patch by Philippe Robin, 22 Apr 2004:
Fix ethernet configuration for "versatile" board
* Patch by Kshitij Gupta, 21 Apr 2004:
Remove busy loop and use MPU timer fr usleep() on OMAP1510/1610 boards
* Patch by Steven Scholz, 24 Feb 2004:
Fix a bug in AT91RM9200 ethernet driver:
The MII interface is now initialized before accessing the PHY.
* Cleanup PCI ID's
Use U-boot's miiphy.h for PHY register names, rather than
introducing a new header file.
* Update pci_ids.h from linux-2.4.26
* Patch by Masami Komiya, 19 Apr 2004:
Fix problem cause by VLAN function on little endian architecture
without VLAN environment
binary image for all clock frequencies. Implement run-time
optimization of flash access timing based on the actual bus
frequency.
sticks (including FAT / VFAT filesystem support)
* Add SL811 Host Controller Interface driver for USB
* Add CFG_I2C_EEPROM_ADDR_OVERFLOW desription to README
* Patch by Pantelis Antoniou, 19 Apr 2004:
Allow to use shell style syntax (i. e. ${var} ) with standard parser.
Minor patches for Intracom boards.
* Patch by Christian Pell, 19 Apr 2004:
cleanup support for CF/IDE on PCMCIA for PXA25X
Enable ranges in mii command, e.g. mii read 0-1f 0 or
mii read 4-7 18-1a. Also add mii dump subcommand for
pretty-printing standard regs 0-5.
* Patch by Stephen Williams, 16 April 2004:
fix typo in JSE.h; update MAINTAINERS
fix initdram function for utx8245 board
* Patch by Markus Pietrek, 14 Apr 2004:
use ATAG_INITRD2 instead of deprecated ATAG_INITRD tag
* Patch by Reinhard Meyer, 18 Apr 2004:
provide the IDE Reset Function for EMK 5200 boards
* Patch by Masami Komiya, 12 Apr 2004:
fix pci_hose_write_config_{byte,word}_via_dword problems
Update max RAM size for debris board
* Patch by Travis Sawyer, 08 Apr 2004:
Add TLB entry for second DIMM slot on ocotea
* Patch by Masami Komiya, 08 Apr 2004:
add RTL8169 network driver
- Add support for RPC/STx GP3, Motorola 8560 board
- Update 85xx TSEC driver so it searches MII for first available PHY
and uses that one.
- Add functions to support console MII commands.
* Patch by Tolunay Orkun, 07 Apr 2004:
Move initialization of bi_iic_fast[]
from board_init_f() to board_init_r()
* Patch by Yasushi Shoji, 07 Apr 2004:
Cleanup microblaze port
* Patch by Sangmoon Kim, 07 Apr 2004:
Add auto SDRAM module detection for Debris board
* Patch by Rune Torgersen, 06 Apr 2004:
- Fix some PCI problems on the MPC8266ADS board
- Fix the location of some PCI entries in the immap structure
- add support for microblaze processors
- add support for AtmarkTechno "suzaku" board
* Configure PPChameleon board to use JFFS2 NAND support.
* Added support for JFFS2 filesystem (read-only) on top of NAND flash
* Patch by Rune Torgersen, 16 Apr 2004:
LBA48 fixes
* Patches by Pantelis Antoniou, 16 Apr 2004:
- Fix some compile problems;
add "once" functionality for the netretry variable
- add support for a new version of an Intracom board and fix
various other things on others.
- add verify support to the crc32 command (define
CONFIG_CRC32_VERIFY to enable it)
- fix FEC driver for MPC8xx systems:
1. fix compilation problems for boards that use dynamic
allocation of DPRAM
2. shut down FEC after network transfers
- HUSH parser fixes:
1. A new test command was added. This is a simplified version of
the one in the bourne shell.
2. A new exit command was added which terminates the current
executing script.
3. Fixed handing of $? (exit code of last executed command)
add support for Intel Assabet board
Add support for Picture Elements JSE board
* Patch by Christian Pell, 01 Apr 2004:
Add CompactFlash support for PXA systems.
add networking support for VLANs (802.1q), and CDP (Cisco Discovery Protocol)
Improve and fix various things in the MPC8xx FEC driver:
1. The new 87x and 88x series of processors have two FECs,
and the new driver supports them both.
2. Another change in the 87x/88x series is support for
the RMII (Reduced MII) interface. However numerous
changes are needed to make it work since the PHYs
are connected to the same lines. That means that
you have to address them correctly over the MII
interface.
- add support for the Epson 156x series of graphical displays
(These displays are serial and not suitable for using a normal
framebuffer console on them)
- add infrastructure needed in order to POST any DSPs in a board
- add auto-complete support to the U-Boot CLI
- add support for NETTA and NETPHONE boards; fix NETVIA board
* Patch by Yuli Barcohen, 28 Mar 2004:
- Add support for MPC8272 family including MPC8247/8248/8271/8272
- Add support for MPC8272ADS evaluation board (another flavour of MPC8260ADS)
- Change configuration method for MPC8260ADS family
unconfiguring the board
* Adapt RMU board for bigger flash memory
* Test fix for ethernet problems on MPC5200
