path: root/include
2011-08-02Merge branch 'master' of git://git.denx.de/u-boot-blackfinWolfgang Denk
* 'master' of git://git.denx.de/u-boot-blackfin: Blackfin: jtag-console: fix timer usage Blackfin: switch to common display_options() Blackfin: serial: move early debug strings into .rodata section Blackfin: adi boards: also set stderr to nc with helper Blackfin: update anomaly lists to latest public info Blackfin: serial: convert to bfin_{read,write} helpers Blackfin: split out async setup Blackfin: adi boards: enable pretty flash progress output Blackfin: drop unused dma.h header from start code Blackfin: portmux: allow header to be included in assembly files Blackfin: cm-bf537e/cm-bf537u/tcm-bf537: enable mmc_spi support Blackfin: cm-bf537e/cm-bf537u/tcm-bf537: update network settings Blackfin: sync MMR read/write helpers with Linux Blackfin: gpio: optimize free path a little Blackfin: post: setup default CONFIG_SYS_POST_WORD_ADDR Blackfin: uart: fix printf warning Blackfin: add init.elf helper code Blackfin: dont reset SWRST on newer bf526 parts Blackfin: adi boards: enable multi serial support by default Blackfin: uart: add multiple serial support Blackfin: uart: move debug buffers into local bss
2011-08-02Merge branch 'master' of git://git.denx.de/u-boot-mipsWolfgang Denk
* 'master' of git://git.denx.de/u-boot-mips: README: update MIPS related informations MIPS: make cache operation mode configurable MIPS: rename INFINEON_EBU_BOOTCFG to CONFIG_SYS_XWAY_EBU_BOOTFG MIPS: INCA-IP: rename inca-swap-bytes host tool
2011-08-01environment.h: fix warning: "CONFIG_ENV_IS_EMBEDDED" redefinedWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de>
2011-08-01fpga: constify to fix build warningWolfgang Denk
Fix compiler warning: cmd_fpga.c:318: warning: passing argument 3 of 'fit_image_get_data' from incompatible pointer type Adding the needed 'const' here entails a whole bunch of additonal changes all over the FPGA code. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Andre Schwarz <andre.schwarz@matrix-vision.de> Cc: Murray Jensen <Murray.Jensen@csiro.au> Acked-by: Andre Schwarz<andre.schwarz@matrix-vision.de>
2011-08-01Unify timer_init() and cpu_init() prototypesWolfgang Denk
Clean up some duplicated prototype declarations. Get rid of now useless AVR32 initcalls.h file. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert Aribaud <albert.aribaud@free.fr> Cc: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Cc: Graeme Russ <graeme.russ@gmail.com>
2011-07-31MIPS: rename INFINEON_EBU_BOOTCFG to CONFIG_SYS_XWAY_EBU_BOOTFGDaniel Schwierzeck
This define is a board-specific config option and should be renamed to follow the U-Boot naming convention. Additionally, add an explaining comment for this option. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Acked-by: Thomas Langer <thomas.langer@lantiq.com> Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2011-07-31MIPS: INCA-IP: rename inca-swap-bytes host toolDaniel Schwierzeck
The INCA-IP SoC belongs to the Lantiq XWAY SoC product portfolio. For the upcoming support of other Lantiq SoC devices this tool should not solely depend on the INCA-IP board. Rename the tool to xway-swap-bytes and add an config option to enable compilation optionally. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Acked-by: Thomas Langer <thomas.langer@lantiq.com> Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2011-07-30Merge branch 'master' of /home/wd/git/u-boot/custodiansWolfgang Denk
* 'master' of /home/wd/git/u-boot/custodians: powerpc/8xxx: Remove dependency on <usb.h> powerpc/85xx: enable USB2 gadget mode for corenet ds board powerpc/85xx: verify the device tree before booting Linux MPC8xxx: drop redundant boot messages powerpc/85xx: Fix build failure for P1023RDS powerpc/p2041rdb: Enable SATA support powerpc/85xx: Cleanup handling of PVR detection for e500/e500mc/e5500 powerpc/85xx: Fix up clock_freq property in CAN node of dts 85xx: enable FDT support for STX SSA board powerpc/85xx: provide 85xx flush_icache for cmd_cache powerpc/p2041rdb: Enable backside L2 cache support powerpc/85xx: Handle the lack of L2 cache on P2040/P2040E powerpc/85xx: Add support for P2041[e] XAUI in SERDES powerpc/85xx: Rename P2040 id & SERDES to P2041 powerpc/85xx: Adding configuration for DCSRCR to enable 32M access powerpc/85xx: Fix setting of EPAPR_MAGIC value
2011-07-30Constify getenv(), setenv() and hash code functionsWolfgang Denk
This is needed to get rid of build warnings like main.c:311: warning: passing argument 2 of 'setenv' discards qualifiers from pointer target type which result from commit 09c2e90 "unify version_string". Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com>
2011-07-29powerpc/85xx: enable USB2 gadget mode for corenet ds boardShaohui Xie
to make USB2 worked in gadget mode, we need to set it's 'dr_mode' to 'peripheral' in hwconfig, but driver starts scan from 'usb1', it'll break out if it cannot find 'usb1', so drop the 'else' clause to make driver scan all the 'usbx'. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-29powerpc/85xx: Fix build failure for P1023RDSKumar Gala
When we added the fman fdt fixup we forgot to fixup the P1023RDS platform. So we would get: fdt.c: In function 'fdt_fixup_fman_firmware': fdt.c:465:15: error: 'CONFIG_SYS_FMAN_FW_LENGTH' undeclared (first use in this function) fdt.c:465:15: note: each undeclared identifier is reported only once for each function it appears in Add the needed #defines in P1023RDS.h to fix this. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-29powerpc/p2041rdb: Enable SATA supportMingkai Hu
Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-2985xx: enable FDT support for STX SSA boardWolfgang Denk
We also have to shift TEXT_BASE to accomodate for the additional code size. Signed-off-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-29powerpc/p2041rdb: Enable backside L2 cache supportMingkai Hu
2011-07-28post, memory test: add memory_post_test() to include fileHeiko Schocher
This include is needed, if this memory test is used "outside" from post code, for example booting with nand_spl, and using this memory test before copying u-boot code to RAM and jumping to it. Signed-off-by: Heiko Schocher <hs@denx.de>
2011-07-28Fix build error causes by "unify version_string"Wolfgang Denk
Commit 09c2e90 "unify version_string" introduced a build error, fix it. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-07-28Removed obsolete Netstal boardsNiklaus Giger
Signed-off-by: Niklaus Giger <niklaus.giger@member.fsf.org>
2011-07-28cleanup: Fix typos and misspellings in various files.Mike Williams
Recieve/Receive recieve/receive Interupt/Interrupt interupt/interrupt Addres/Address addres/address Signed-off-by: Mike Williams <mike@mikebwilliams.com>
2011-07-28include/compiler.h: typedef ulong for FreeBSDJeroen Hofstee
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2011-07-28unify version_stringAndreas Bießmann
This patch removes the architecture specific implementation of version_string where possible. Some architectures use a special place and therefore we provide U_BOOT_VERSION_STRING definition and a common weak symbol version_string. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> CC: Mike Frysinger <vapier@gentoo.org> CC: Peter Pan <pppeterpppan@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-07-28mkimage: add UBL header support for booting davinci cpusHeiko Schocher
creating an u-boot.ubl file, which contains the UBL Header needed for booting from NAND with the RBL from TI. For more information read doc/README.ublimage. Signed-off-by: Heiko Schocher <hs@denx.de>
2011-07-28fpga: add #define for Altera Cyclone EP3C5Michael Jones
Signed-off-by: Michael Jones <michael.jones@matrix-vision.de>
2011-07-28cosmetic: spell fixes etc.Michael Jones
Signed-off-by: Michael Jones <michael.jones@matrix-vision.de> Acked-by: Detlev Zundel <dzu@denx.de>
2011-07-28km/common: moved eeprom config to pbec specific partStefan Bigler
Moved eeprom config to specific part, to allow bigger eeprom write pages for km_kirkwood designs. Write page only used for env eeprom in std use cases. 24C128 has page size of 64bytes -> 8 time faster. Signed-off-by: Stefan Bigler <stefan.bigler@keymile.com> cc: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de>
2011-07-28km/common: use u-boot.kwb for u-boot update function on armHolger Brunck
Now we use the standard u-boot make to build the Kirkwood binary. The output file is u-boot.kwb. So use this name for the tftp update function to avoid confusion, because this is the binary we need on Kirkwood. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> cc: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de>
2011-07-27common: move BUILD_BUG_ON define to common.hHeiko Schocher
see discussion also here: http://patchwork.ozlabs.org/patch/75309/ Signed-off-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Holger Brunck <holger.brunck@keymile.com>
2011-07-27km/common: enable cramfs and cramfs cmdlineHolger Brunck
All the km boards uses CRAMFS images where the kernel is stored. This isn't architecture specific because we use it on ARM and POWERPC. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de>
2011-07-27powerpc/km82xx: remove 82xx specific functions from common.cHolger Brunck
Common code should be valid for more than one architecture, therefore the km82xx specific code was removed from common.c. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de>
2011-07-27km/common: remove obsolete defines and headerHolger Brunck
These defines and the header keymile_hdlc_enet.h are obsolete due to the removed hdlc code. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de>
2011-07-27km/common: simplify debug environmentHolger Brunck
The debug environment which is stored in textfiles in the scripts directory was reworked. Two usecase are now present which can be executed simply from the default environment: run develop: this configures the environment to setup the rootfs via nfs run ramfs: this configures the environment to setup the rootfs in ram Each architecture now has a "arch" variable which is used to load the architecture specific debug scripts and to set the rootpath for NFS. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de>
2011-07-27km/common: add test sw starting variableThomas Herzmann
The test SW is started when the test_bank variable is set. Signed-off-by: Thomas Herzmann <thomas.herzmann@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
2011-07-27km/common: rework and simplify default environmentHolger Brunck
This is the second step to simplify and decrease the default environment for the keymile boards. The release usecase formaly used to set the production environment was removed and the default configuration is now the production environment. So the formar environment variable "release" which has done a lot of things in the past, simply erase the current environment and do a reset which forces u-boot to setup the default environment again. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de>
2011-07-27digsy_mtc: move board into vendor dir and add vendor logoAnatolij Gustschin
2011-07-27mpc5200: digsy_mtc: add support for graphic extension boardAnatolij Gustschin
Add detection and initialisation for graphic extension board and support splash screen when booting. Enable "bmp" command in the board configuration and provide "disp" command to be able to switch the display on/off. Signed-off-by: Anatolij Gustschin <agust@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2011-07-27phylib: Detect link on 10G devices correctlyAndy Fleming
gen10g_startup() had 2 bugs: 1) It had a boolean logic error in checking the MMD mask, and always checked all of them. 2) It checked devices which don't actually report link state, which meant that it would never believe the link was fully up. Fix the boolean logic, and then mask the MMD mask so only link-reporting devices are checked. Signed-off-by: Andy Fleming <afleming@freescale.com> Reported-by: Ed Swarthout <Ed.Swarthout@freescale.com>
2011-07-26panic: add noreturn attributeMike Frysinger
Since panic() never returns, we should add an appropriate attribute to let gcc improve optimization around it. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-26post: new nor flash testMike Frysinger
This adds a simple flash test to automatically verify erasing, writing, and reading of sectors. The code is based on existing Blackfin tests but generalized for everyone to use. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-26serial: implement common uart post testMike Frysinger
The current arch/driver specific UART posts basically boil down to setting the UART to loop back mode, then reading and writing data. If we ignore the loop back part, the rest can be built upon the existing common serial API. So let's do just that. First add a call back for serial drivers to implement loop back control. Then write a post test that walks all of the serial drivers, puts them into loop back mode, and verifies that reading/writing at all the diff baud rates is OK. If a serial driver doesn't support loop back mode (either it can't or it hasn't done so yet), then skip it. This should allow for people to easily migrate to the new post test with existing serial drivers. I haven't touched the few already existing uart post tests as I don't the hardware or knowledge of converting them over. So I've marked the new test as weak which will allow the existing tests to override the default until they are converted. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-26serial: drop useless ctlr fieldMike Frysinger
The multi serial support has a "ctlr" field which almost no one uses, but everyone is forced to set to useless strings. So punt it. Funny enough, the only code that actually reads this field (the mpc8xx driver) has a typo where it meant to look for the SCC driver. Fix it while converting the check to use the name field. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Heiko Schocher <hs@denx.de> CC: Anatolij Gustschin <agust@denx.de> CC: Tom Rix <Tom.Rix@windriver.com> CC: Minkyu Kang <mk7.kang@samsung.com> CC: Craig Nauman <cnauman@diagraph.com> CC: Marek Vasut <marek.vasut@gmail.com> CC: Prafulla Wadaskar <prafulla@marvell.com> CC: Mahavir Jain <mjain@marvell.com>
2011-07-26cmd_usage: constifyMike Frysinger
The usage helper doesn't modify the command, so constify its input arg. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-26constify default envMike Frysinger
I can't see any obvious needs for the default environment to be writable, so make it const. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-26env: allow people to force envcrc buildingMike Frysinger
For people who want to manually extract the embedded environment so that it can be manually packed into the final u-boot image, add a config opt to force building of the envcrc tool. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-26sf: unify write funcsMike Frysinger
Once we add a new page_size field for write lengths, we can unify the write methods for most of the spi flash drivers. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-26Timer: Allow reset_timer() only for systems with low resolution timersGraeme Russ
2011-07-26Timer: Remove set_timer completelyGraeme Russ
2011-07-26disk/part.c: Make features optionalMatthew McClintock
If we don't want to build support for any partition types we can now add #undef CONFIG_PARTITIONS in a board config file to keep this from being compiled in. Otherwise boards assume this is compiled in by default Signed-off-by: Matthew McClintock <msm@freescale.com>
2011-07-26Revert "post, memory test: add memory_post_test() to include file"Wolfgang Denk
This reverts commit f18714dd61331b48ab9dc0ef717d61f1441a0e17 which cuases compile errors on a number of boards. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-07-26scsi/ahci: add support for non-PCI controllersRob Herring
Add support for AHCI controllers that are not PCI based. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Wolfgang Denk <wd@denx.de>
2011-07-25post, memory test: add memory_post_test() to include fileHeiko Schocher
2011-07-25autostart: unify duplicated logic into the bootm codeMike Frysinger
Rather than having a bunch of random commands handle autostart behavior, unify the logic in a single place. This also fixes building of these different commands when bootm is disabled. Acked-by: Matthew McClintock <msm@freescale.com> Acked-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
