This code is very large, and in SPL it isn't always useful to print
out image information (in fact there might not even be a console
active). So disable this feature unless this option is set.
There are only two left. One is unnecessary and the other can be moved
to the header file.
Much of the image code uses addresses as ulongs and pointers interchangeably,
casting between the two forms as needed.
This doesn't work with sandbox, which has a U-Boot RAM buffer which is
separate from the host machine's memory.
Adjust the cost so that translating from a U-Boot address to a pointer uses
map_sysmem(). This allows bootm to work correctly on sandbox.
Note that there are no exhaustive tests for this code on sandbox, so it is
possible that some dark corners remain.
Reviewed-by: Marek Vasut <marex@denx.de> (v1)
This function will be used to print signatures as well as hashes, so rename
it. Also make it static since it is not used outside this file.
We intend to add signatures to FITs also, so rename this function so that
it is not specific to hashing. Also rename fit_image_set_hashes() and
This function will be needed by signature checking code, so export it,
and also add docs.
The existing function is long and most of the code is indented a long
way. Before adding yet more code, split this out into its own function.
This is the main entry point to the FIT image verification code. We will
be using it to handle image verification with signatures, so rename the
function.
This function doesn't need to be exported, and with verification
we want to use it for setting the 'value' property in any node,
so rename it.
This code is never compiled into U-Boot, so move it into a separate
file in tools/ to avoid the large #ifdef.
One we split out the FIT code from image.c we will need this function.
Export it in the header.
Rather than repeat the line
#if defined(CONFIG_TIMESTAMP) || defined(CONFIG_CMD_DATE) || \
defined(USE_HOSTCC)
everywhere, put this in a header file and #define IMAGE_ENABLE_TIMESTAMP
to either 1 or 0. Then we can use a plain if() in most code and avoid
the #ifdefs.
The compiler's dead code elimination ensures that the result is the same.
Iterating through subnodes with libfdt is a little painful to write as we
need something like this:
for (depth = 0, count = 0,
offset = fdt_next_node(fdt, parent_offset, &depth);
(offset >= 0) && (depth > 0);
offset = fdt_next_node(fdt, offset, &depth)) {
if (depth == 1) {
/* code body */
Using fdt_next_subnode() we can instead write this, which is shorter and
easier to get right:
for (offset = fdt_first_subnode(fdt, parent_offset);
offset >= 0;
offset = fdt_next_subnode(fdt, offset)) {
/* code body */
Also, it doesn't require two levels of indentation for the loop body.
(Cherry-picked from dtc commit 4e76ec79)
Acked-by: Gerald Van Baren <vanbaren@cideas.com>
We don't measure boot timing on the host, or with SPL, so use both
conditions in the bootstage header. This allows us to avoid using
conditional compilation around bootstage_...() calls. (#ifdef)
Rather than needing to call one of many hashing algorithms in U-Boot,
provide a function hash_block() which handles this, and can support all
available hash algorithms.
Once we have md5 supported within hashing, we can use this function in
the FIT image code.
powerpc-eldk53-warning-fixes
We don't use zlib and gzip but do use lzo, so enable this.
Add a function which allows a (file, function, line number) to be marked
in bootstage.
Reviewed-by: Che-Liang Chiou <clchiou@chromium.org>
This is a convenient way of finding out where boottime is going. Enable
it for coreboot.
Any pointers to name strings that were passed to bootstage_mark_name()
pre-relocation should be copied post-relocation so that they don't get
trashed as the original location of U-Boot is re-used for other
purposes.
This change introduces a new API call that should be called from
board_init_r() after malloc has been initted on any board that uses
bootstage.
Signed-off-by: Doug Anderson <dianders@chromium.org>
Some functions don't have a stub for when CONFIG_BOOTSTAGE is not defined.
Add one to avoid #ifdefs in the code when this is used in U-Boot.
Reviewed-by: Tom Wai-Hong Tam <waihong@chromium.org>
While we don't want PCAT timers for timing, we want timer 2 so that we can
still make a beep. Re-purpose the PCAT driver for this, and enable it in
coreboot.
This timer runs at a rate that can be calculated, well over 100MHz. It is
ideal for accurate timing and does not need interrupt servicing.
Tidy up some old broken and unneeded implementations at the same time.
To provide a consistent view of boot time, we use the same time
base as coreboot. Use the base timestamp supplied by coreboot
as U-Boot's base time.
Signed-off-by: Simon Glass <sjg@chromium.org>base
The gpio spec for bf54x and bf60x differ a lot from the old gpio driver for bf5xx.
A lot of machine macros are used to accomodate both code in one gpio driver.
This patch split the old gpio driver and move new gpio2 support to the generic
gpio driver folder.
- To enable gpio2 driver, macro CONFIG_ADI_GPIO2 should be defined in the board's
config header file.
- The gpio2 driver supports bf54x, bf60x and future ADI processors, while the
older gpio driver supports bf50x, bf51x, bf52x, bf53x and bf561.
- All blackfin specific gpio function names are replaced by the generic gpio APIs.
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
- Move blackfin serial driver to the generic driver folder.
- Move blackfin serial headers to blackfin arch head folder.
- Update the include path to blackfin serial header in start up code.
- Enable hw_watchdog_init() in watchdog.h if CONFIG_HW_WATCHDOG is defined.
- Move blackfin hw watchdog driver to the generic driver folder.
- Call hw_watchdog_init() from blackfin board init code.
- Reuse macro CONFIG_WATCHDOG_TIMEOUT_MSECS
- Update README.watchdog accordingly
Remove blackfin specific implementation of the generic serial API when
early print macro is defined.
In BFIN_BOOT_BYPASS mode, don't call generic serial_puts, because
early print in bypass mode is running before code binary is relocated
to the link address.
- Disable NAND driver on bf537-stamp.
- Make MMC_SPI optional.
- Disable LCD driver on bf527-ezkit.
- Enlarge BF609 nor flash reserved size from 256k to 512k bytes.
Signed-off-by: Sonic Zhang <sonic.adi@gmail.com>
Add softswitch_output command for bf609-ezkit to enable softswitches.
Signed-off-by: Bob Liu <lliubbo@gmail.com>
Define core 1 L1 code sram start address.
Add function to enable core 1 for BF609 and BF561.
Add config macro to allow customer to run core 1 in uboot init code on core 0.
Enable VIDEO and NAND supports only when the config options is defined.
The define should not have been put in fdt.h originally, libfdt_env.h
is the proper place for target-specific customizations.
Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
This commit adds a license header to fdt.h and libfdt_env.h
because the license was omitted.
U-Boot note: the u-boot libfdt_env.h header portion was not applied to
the u-boot libfdt_env.h because that file was created by Gerald Van Baren
(with a license header). - gvb
Ref: DTC commit 27cdc1b1
Signed-off-by: Justin Sobota <jsobota@ti.com>
Acked-by: David Gibson <david@gibson.dropbear.id.au>
Ref: DTC commit cc11e522
Signed-off-by: François Revol <revol@free.fr>
This function is useful outside libfdt, so export it.
Ref: DTC commit b7aa300e
The 512 byte block size was hard coded in the ext4 file systems.
Large harddisks today support bigger block sizes typically 4096
bytes.
This patch removes this limitation.
Signed-off-by: Egbert Eich <eich@suse.com>
Microblaze uses gpio which is connected to the system reset.
Currently gpio subsystem wasn't used for it.
Add gpio driver and change Microblaze reset logic to be done
via gpio subsystem.
There are various configurations which Microblaze can have
that's why gpio_alloc/gpio_alloc_dual(for dual channel)
function has been introduced and gpio can be allocated
dynamically.
Adding several gpios IP is also possible and supported.
For listing gpio configuration please use "gpio status" command
This patch also remove one compilation warning:
microblaze-generic.c: In function 'do_reset':
microblaze-generic.c:38:47: warning: operation on '*1073741824u'
may be undefined [-Wsequence-point]
Most of time that MMC driver spends on initializing a device is polling
OCR (operation conditions register). To decouple this polling loop,
device init is split into two parts: The first part fires the OCR query
command, and the second part polls the result. So the caller is now no
longer bound to the OCR-polling delay; he may fire the query, go
somewhere and then come back later for the result.
To use this, call mmc_set_preinit() on any device which needs this.
This can save significant amounts of time on boot (e.g. 200ms) by
hiding the MMC init time behind other init.
Signed-off-by: Che-Liang Chiou <clchiou@chromium.org>
Acked-by: Jaehoon Chung <jh80.chung@samsung.com>
Signed-off-by: Andy Fleming <afleming@freescale.com>
We can use a common global method for calculating minimum of
3 numbers. Put the same in 'common header' and let 'ehci'
use it.
Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com>
Acked-by: Tom Rini <trini@ti.com>
Fix the Port status bit constants and Port feature number
constants as a part of USB 2.0 and USB 3.0 Hub class.
This adds usb framework support for super-speed usb, which will
further facilitate to add stack support for xHCI.
Signed-off-by: Vikas C Sajjan <vikas.sajjan@samsung.com>
Some cleanup in usb framework, nothing much on feature side.
This patch adds a new 'usb test' command, that will set a port to a USB
2.0 test mode (see USB 2.0 spec 7.1.20). It supports all five test modes
on both downstream hub ports and ordinary device's upstream ports. In
addition, it supports EHCI root hub ports.
Signed-off-by: Julius Werner <jwerner@chromium.org>
With the u-boot-with-spl.bin rule calling $(OBJCOPY) with
CONFIG_SPL_PAD_TO, and CONFIG_SPL_PAD_TO defaulting to
CONFIG_SPL_MAX_SIZE we cannot use math here, so set it to 4096 rather
than 4 * 1024.
The Hydra and Superhydra (P3041DS, P5020DS, and P5040DS) boards have a
second USB port that can be configured in either host, peripheral (aka
device), or OTG (on-the-go) mode. When configured in host mode, if
the port is connected to another USB host, damage to the board can
occur.
To avoid this, we change the default setting to peripheral mode. Ideally,
we'd set it to OTG mode, but currently there is no OTG support for
these boards.
Setting the hwconfig variable will also update the device tree, and so
Linux will configure the port for peripheral mode as well.
Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com>
Signed-off-by: Timur Tabi <timur@tabi.org>
Add defines needed to access NAND, remove second flash bank that is
actually connected to NAND.
Add nand booting support for P1022DS with hardcoded DDR config using
SPL framework from 2011
Signed-off-by: Matthew McClintock <msm@freescale.com>
Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com>
Signed-off-by: Jiang Yutang <b14898@freescale.com>
The changes to a3m071/a4m2k in summary are:
- Enable CAN1 on I2C in GPS Port Configuration
- Enable SPI on PSC2
- Activate network console
- New flash partitioning
- Fix some typos
- Pass host name to Linux
- Change rootfs to squashfs,jffs2
- Enable UBI/UBIFS support
- Enable FIT support
