The commit 04a9e1180ac76a7bacc15a6fcd95ad839d65bddb
cause the 83xx immap broken, so the DMA and PCI will
be failed.
The patch fix the struct spi8xxx and rm struct spi83xx.
Signed-off-by: Dave Liu <daveliu@freescale.com>
Add support for the ATNGW100 Network Gateway reference design,
including flash, ethernet and MMC support.
Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
The patch adds 4 boards, called AcTux-1 .. AcTux-4. This patch contains the
files that
contain changes for multiple boards, the board-specific files follow as
separate patches.
Signed-off-by: Michael Schwingen <michael@schwingen.org>
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
Signed-off by: John Rigby <jrigby@freescale.com>
Definition update and change from 16bit to 32bit
Add CF specific modules header files
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
Signed-off-by: John Rigby <jrigby@freescale.com>
..and rm unused CONFIG_FSL_SPI define
Enable command-line editing for all MPC86xx boards.
This patch implements the fsl_spi driver on the MPC8349EMDS evaluation board.
This board has an ST M25P40 4Mbit EEPROM on its SPI bus
This patch adds support for the SPI controller found on Freescale PowerPC
processors such as the MCP834x family. Additionally, a new config option,
CONFIG_HARD_SPI, is added for general purpose SPI controller use.
The commit 9e89647889cd4b5ada5b5e7cad6cbe55737a08d7
will cause the mpc8315erdb board can't boot up.
The patch fix that bug, and remove the duplicated #ifdef
CFG_SPCR_TSECEP code and clean the SCCR_TSEC2 for
MPC8313E processor.
- Various fixes
- Reduced rom_size from 384 to 320 kB
- Environment is now in flash
- Added POST
- Support for OF
Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com>
- Various fixes
- Added POST
- Support for OF
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
Previous setting cause ips clock to be out of spec. This bug was found by John
Rigby from Freescale.
Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
Now that all boards have been converted, remove old config code and the
config option for the new style.
