Only the GPIO driver knows about the full GPIO device tree binding used by
a device. Add a method to allow the driver to provide this information to the
uclass, including the GPIO offset within the device and flags such as the
polarity.
So far driver model's GPIO uclass just implements the existing GPIO API.
This has some limitations:
- it requires manual device tree munging to support GPIOs in device tree
(fdtdec_get_gpio() and friends)
- it does not understand polarity
- it is somewhat slower since we must scan for the GPIO device each time
- Global GPIO numbering can change if other GPIO drivers are probed
- it requires extra steps to set the GPIO direction and value
The new functions have a dm_ prefix where necessary to avoid name conflicts
but we can remove that when it is no-longer needed. The new struct gpio_desc
holds all required information about the GPIO. For now this is intended to
be stored by the client requesting the GPIO, but in future it might be
brought into the uclass in some way.
With these changes the old GPIO API still works, and uses the driver model
API underneath.
For GPIOs and other functions we want to look up a phandle and then decode
a list of arguments for that phandle. Each phandle can have a different
number of arguments, specified by a property in the target node. This is
the "#gpio-cells" property for GPIOs.
Add a function to provide this feature, taken modified from Linux 3.18.
The common/board_r.c has show_model_r() to display the model name
if the DTB has a "model" property. It sounds useful to have a similar
function in common/board_f.c too because most of the boards show
their board name before relocation.
Instead of implementing the same function in both common/board_f.c
and common/board_r.c, let's split it up into common/show_board_info.c.
updated the zynq config to support the lthor
download protocol.
This lthor functionality helps us to load linux
images on to DDR/MMC and can boot linux using bootm.
In order to load images the user should run lthor
command run "thor_ram" from u-boot prompt and
then send the images from host using lthor utility.
Define g_dnl_bind_fixup for zynq so that correct vendor
and product ids assigned incase of DFU and lthor.
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
Enable DFU functionality in zynq.
This DFU functionality helps us to load linux
images on to DDR and can boot linux using bootm.
In order to load images the user should run dfu
command "dfu 0 ram 0" from u-boot prompt and then
send the images from host.
The malloc size has been increased to match the DFU
buffer requirements.
Dont send always emio value as zero for zynq_gem_initialize
send it based on config.
No functional chagnes.
Based on:
"am335x_evm: Enable CMD_EXT4 and CMD_FS_GENERIC, add bootpart to env"
(sha1: 73a27a84e58cb99b4e64ed6a35eab5bc61f44f29)
Fix filesystem specific commands for loading.
Show board information in bootlog and enable it by default.
Refresh for newer kernel.
Prepare ENV settings for sheevaplugs to be OpenWRT ready.
| UBOOT | >> 896 Kb (7x128) = uboot
| ENV | >> 128 Kb = uboot_env
| ROOT(FS) | >> 511 Mb @ 1 Mb = root -> rootfs (ubifs)
With (CC) TRUNK OpenWRT build (QUICK HOWTO) :
<INTERRUPT>
Marvell>> nand erase.part root
Marvell>> ubi part root
Marvell>> ubi remove rootfs
Marvell>> ubi create rootfs
Marvell>> usb reset
Marvell>> fatload usb 2:1 0x800000 guruplug/openwrt/openwrt-kirkwood-guruplug-rootfs.ubifs
Marvell>> ubi write 0x800000 rootfs ${filesize}
Marvell>> reset
Changes in v1:
- ADD generic board define
- ADD FDT support
- ADD HUSH interpreter
- Define new NAND partition mapping
Signed-off-by: Gerald Kerma <dreagle@doukki.net>
Signed-off-by: Luka Perkov <luka@openwrt.org>
CC: Prafulla Wadaskar <prafulla@marvell.com>
Add deep sleep support on Freescale LS1021QDS platform.
Signed-off-by: Tang Yuantian <Yuantian.Tang@freescale.com>
[York Sun: Fix conflict in fdt.c]
Reviewed-by: York Sun <yorksun@freescale.com>
Enable an environment area.
Add a hook to ensure that this information is saved.
As a temporary measure before the ICH driver moves over to driver model,
add device tree support to the driver.
On x86 we use CMOS RAM to read and write some settings. Add basic support
for this, including access to registers 128-255.
Move the checksum code out into its own file so it can be used elsewhere.
Also use a new version which supports a length which is not a multiple of
2 and add a new function to add two checksums.
Add this to the enum so that we can use the various fdtdec functions. A
later commit will move this driver to driver model.
This patch adds LPUART support for LS1021ATWR board.
For ls1021atwr_nor_lpuart_defconfig, LPUART is used as the console.
Signed-off-by: Alison Wang <alison.wang@freescale.com>
This patch adds LPUART support for LS1021AQDS board.
For ls1021aqds_nor_lpuart_defconfig, LPUART is used as the console.
This patch adds the CH7301 HDMI options and the common configuration
for DCU on LS1021AQDS board.
Signed-off-by: Xiubo Li <Li.Xiubo@freescale.com>
Cc: Jason Jin <Jason.Jin@freescale.com>
Internal memory controller counters can reach a bad state after
training in DDR4 mode if accumulated ECC or DBI mode is eanbled.
Signed-off-by: York Sun <yorksun@freescale.com>
Scrolling a line at a time is very slow for reasons that I don't understand.
It seems to take about 100ms to copy 4MB of RAM in the frame buffer. To cope
with this, scroll 5 lines each time.
Add code to the generic pci_rom file to access the VGA ROM in PCI space
when needed.
Allow the supported modes to be listed when in debug mode.
We shouldn't assume that the VGA ROM can always be loaded at c0000. This
is only true on x86 machines.
These boards are still non-generic boards.
Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
This board is still a non-generic board.
Cc: Josef Wagner <Wagner@Microsys.de>
It is a good thing that we can drop board-specific hack code
from drivers/mtd/nand/nand_base.c
Cc: Andrea "llandre" Marson <andrea.marson@dave-tech.it>
Cc: Ira W. Snyder <iws@ovro.caltech.edu>
These boards are still non-generic boards:
P1011RDB, P1022RDB, P2010RDB, P2020RDB
Cc: Poonam Aggrwal <poonam.aggrwal@freescale.com>
Cc: Dave Liu <daveliu@freescale.com>
Cc: Anton Vorontsov <avorontsov@ru.mvista.com>
The CPU info is already logged during boot e.g.
CPU: Allwinner A20 (SUN7I)
so the prompt is just one more thing to change for each new SoC, just makes it
"sunxi#" instead.
Signed-off-by: Ian Campbell <ijc@hellion.org.uk>
Acked-by: Hans de Goede <hdegoede@redhat.com>
