2005-10-14 | Add fat & ext2 support to AMCC 440EP boards Yosemite & Bamboo | Stefan Roese | |
Patch by Stefan Roese, 14 Oct 2005 | |||
2005-10-13 | Add missing files for Pantelis Antoniou's patch | Wolfgang Denk | |
Patch by Pantelis Antoniou, 04 Sep 2005 | |||
2005-10-13 | Merge with /home/sr/git/u-boot | Wolfgang Denk | |
2005-10-13 | Add support for OF flat tree for the STXtc board. | Wolfgang Denk | |
2005-10-13 | Support passing of OF flat trees to the kernel. | Wolfgang Denk | |
2005-10-09 | Add support for NetSilicon NS7520 processor. | Wolfgang Denk | |
Patch by Art Shipkowski, 12 May 2005 Cleanup. | |||
2005-10-09 | Add support for AP1000 board. | Wolfgang Denk | |
Patch by James MacAulay, 07 Oct 2005 | |||
2005-10-08 | Fix gzip bmp support (test if malloc fails, warning when truncated). | Stefan Roese | |
Increase CFG_VIDEO_LOGO_MAX_SIZE on HH405 board. Patch by Stefan Roese, 08 Oct 2005 | |||
2005-10-06 | Cleanup | Wolfgang Denk | |
2005-10-06 | Update make target for ARM supported boards. | Wolfgang Denk | |
Use lowlevel_init() instead of platformsetup() [rename]. Patch by Peter Pearse, 06 Oct 2005 | |||
2005-10-06 | Add JFFS2 support for TRAB board | Wolfgang Denk | |
Patch by Martin Krause, 25 Aug 2005 | |||
2005-10-06 | Fix the machine-id of the Cogent csb637 board | Wolfgang Denk | |
Patch by Anders Larsen, 05 Oct 2005 | |||
2005-10-06 | Complete support for the KwikByte KB920x boards | Wolfgang Denk | |
2005-10-05 | Add support for Cogent csb637 | Wolfgang Denk | |
Patch by Anders Larsen, 29 Apr 2005 | |||
2005-10-05 | * Move dm9161.c and lxt972.c into cpu/arm920t/at91rm9200 | Wolfgang Denk | |
Patch by Anders Larsen, 29 Apr 2005 * Fix problems introduced by Patch by Steven Scholz, 02 Mar 2005 (8e2be51de8dd03c1ce4d06cbb18ad06133d47cd5) | |||
2005-10-05 | Fix device partition intialization for SystemACE disks. | Wolfgang Denk | |
Patch by Stephen Williams, 28 Apr 2005 | |||
2005-10-05 | Added support for KwikByte KB920x boards (based on AT91RM9200) | Wolfgang Denk | |
Patch by Matt ?? <kb9200_dev@kwikbyte.com>, 27 Apr 2005 | |||
2005-10-05 | Add support for S29GL064M-R3 flash chip on xsengine board | Wolfgang Denk | |
Patch by Kurt Stremerch, 18 Apr 2005 | |||
2005-10-04 | Update ARM Integrator boards: | Wolfgang Denk | |
Correct addessing errors in platform files. Split off common core module data from Integrator header files to include/armcoremodule.h. Patch by Peter Pearse, 04 Oct 2005 | |||
2005-10-04 | Fix 440GR to print correct cpu revision | Stefan Roese | |
Patch by Stefan Roese, 4 Oct 2005 | |||
2005-09-30 | Fix problem with SM501 init on HH405 board. | Stefan Roese | |
Patch by Stefan Roese, 30 Sep 2005 | |||
2005-09-29 | Fix FEC PHY addresses for TQM85xx boards | Wolfgang Denk | |
2005-09-26 | Undo change of f6e20fc6ca... to include/configs/trab.h | Wolfgang Denk | |
(Must have been an accident?) | |||
2005-09-26 | Add support for AT91RM9200 OHCI Controller. | Wolfgang Denk | |
Patch by Eric Benard, 07 Apr 2005 | |||
2005-09-26 | Update ARM mach-types.h | Wolfgang Denk | |
2005-09-26 | Add support for MP2USB board. | Wolfgang Denk | |
2005-09-26 | Add board support for armadillo HT1070 | Wolfgang Denk | |
Patch by Rowel Atienza, 06 Apr 2005 | |||
2005-09-26 | Second Ethernet address enabled for MPC885ADS and MPC8272ADS. | Wolfgang Denk | |
Patch by Vitaly Bordug, 30 Mar 2005 | |||
2005-09-26 | Add iopset command on mpc8xx | Wolfgang Denk | |
Patch by Daniel Eisenhut, 25 Mar 2005 | |||
2005-09-26 | Fixes to the Lubbock (PXA 25x) support: | Wolfgang Denk | |
- Resolve the FIXME with respect to saving the u-boot environment. - Make the default load address land in real memory. - Fix lan91c96 SMC_{in,out}{b,w,l}() macros Patch by David Brownell, 10 Mar 2005 | |||
2005-09-25 | Add Barco Streaming Video Card (SVC) and Sample Compress Network (SCN) board | Wolfgang Denk | |
Patch by Marc Leeman, 04 Mar 2005 | |||
2005-09-25 | Cleanup | Wolfgang Denk | |
2005-09-25 | OMAP242x H4 board update | Wolfgang Denk | |
- fix for ES2 differences. - switch to using the cfi_flash driver. - fix SRAM build address. - fix for GP device operation. - unlock SRAM for GP devices. - display more device information. - fix potential deadlock in omap24xx_i2c driver. - fix DLL load values to match dpllout*1 operation. - fix 2nd chip select init for combo DDR device. - add support for CFI Intel 28F256L18 on H4 board. Patch by Richard Woodruff, 03 Mar 2005 | |||
2005-09-25 | Fix formating in include/asm-arm/arch-at91rm9200/AT91RM9200.h | Wolfgang Denk | |
Patch by Steven Scholz, 02 Mar 2005 | |||
2005-09-25 | Add cramfs support for m68k | Wolfgang Denk | |
Patch by Zachary Landau, 21 Feb 2005 | |||
2005-09-25 | Update ep8260: Fix flash timeouts; improve clock resolution for faster UARTs | Wolfgang Denk | |
Patch by Jeff Angielski, 21 Feb 2005 | |||
2005-09-25 | Add Xilinx Spartan3 family FPGA support | Wolfgang Denk | |
Patch by Kurt Stremerch, 14 February 2005 | |||
2005-09-25 | Added support for PCI bridge on MPC8272ADS | Wolfgang Denk | |
Patch by Vitaly Bordug, Feb 09 2005 | |||
2005-09-25 | Update multicore CM9XX support for Integrator AP to allow booting from flash | Wolfgang Denk | |
Patch by Jean-Paul Saman, 8 Feb 2005 | |||
2005-09-25 | Fix typos in include/ppc440.h | Wolfgang Denk | |
Patch by Andrew E Mileski, 04 Feb 2005 | |||
2005-09-25 | Add Vibren (was Accelent) PXA255 IDP Support | Wolfgang Denk | |
Patch by Cliff Brake, 04 Feb 2005 | |||
2005-09-25 | Add ARM946E cpu and core module targets; remap memory to 0x00000000 | Wolfgang Denk | |
Patch by Peter Pearse, 2 Feb 2005 | |||
2005-09-25 | OMAP242x fix for GP device booting | Wolfgang Denk | |
- Add SRAM unlock for GP devices. - Change DDR DLL unlock value to allow DPLLout*1 operation. Patches by Richard Woodruff, 21 Jan 2005: | |||
2005-09-25 | Add support for AMD's Pb1x00 eval board; | Wolfgang Denk | |
add MII routines to the au1x00 ethernet driver; add USB ohci driver (work in progress) Patch by Thomas Sailer, 20 Jan 2005 | |||
2005-09-24 | * Fix PHY address argument passing with mii info command | Wolfgang Denk | |
Patch by Andrew Dyer, 28 Dec 2004 * Cleanup: fix broken builds | |||
2005-09-23 | Cleanup (PPC4xx is AMCC now) | Wolfgang Denk | |
2005-09-22 | Cleanup - update CHANGELOG, undo test settings | Wolfgang Denk | |
2005-09-22 | esd CPCI2DP board added | Stefan Roese | |
Patch by Matthias Fuchs, 22 Sep 2005 | |||
2005-09-22 | esd PMC405 board updated | Stefan Roese | |
