path: root/include/zynqmppl.h
2018-06-01fpga: zynqmp: Add secure bitstream loading for ZynqMPSiva Durga Prasad Paladugu
This patch adds support for loading secure bitstreams on ZynqMP platforms. The secure bitstream images has to be generated using Xilinx bootgen tool. Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-04-09fpga: zynqmp: Add support to get the PCAP status for fpga info commandNitin Jain
This patch adds support for ZynqMP platform to print FPGA PCAP status for "fpga status" command. Signed-off-by: Nitin Jain <nitinj@xilinx.com> Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-08-02arm64: zynqmp: Fix SVD mask for getting chip IDMichal Simek
Mask should start from the first bit - using 0xe is just wrong. 3bits are used that's why 0x7 mask is correct. This patch is fixing silicon ID code detection. Previous behavior was that bit0 was completely ignored. Issue was found on 2eg chip detection. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-11-15ARM64: zynqmp: Adjust to new SMC interface to get silicon versionSoren Brinkmann
The new FW interface returns the IDCODE and version register, leaving extracting bitfields to the caller. Cc: Michal Simek <michal.simek@xilinx.com> Cc: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-09-22ARM64: zynqmp: Add support for chip ID detectionMichal Simek
Chip ID needs to be known for loading bitstream because U-Boot checks ID from bitstream header in BIT format. BIN format is completely unchecked. The chipid is get from ATF via SMC. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-09-22fpga: xilinx: zynqmp: Add PL bitstream download support for ZynqMPSiva Durga Prasad Paladugu
Add PL bitstream dowload support for ZynqMP Bitstream will be validated by uboot and loaded to PL by invoking an smc instruction to ATF which route this request to PMU FW which will take care of loading it to PL Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
