Added support to load a bitstream image in chunks by reading it in
chunks from SD/MMC.
Command format:
loadfs [dev] [address] [image size] [blocksize] <interface>
[<dev[:part]>] <filename>
Example: fpga loadfs 0 1000000 3dbafc 4000 mmc 0 fpga.bin
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
Clean up partial, full and compressed bitstream handling.
U-Boot supports full bitstream loading and partial
based on detection which is not 100% correct.
Extending fpga_load/fpga_loadbitstream() with one more
argument which stores bitstream type.
Connect FPGA version with appropriate operations
to remove huge switch-cases for every FPGA family.
Tested on Zynq. Spartan2/Spartan3/Virtex2 just compile test.
No functional changes.
[trini: Fixup common/cmd_io.c]
All these macros are completely unused by any code.
CONFIG_FPGA is not a bitfield anymore.
Reviewed-by: Tom Rini <trini@ti.com>
Ensure that wrong bitstream won't be loaded
to current device.
Devcfg device requires to load bitstream in binary format.
But u-boot also has an option for loading bitstream in bit
format. Let's handle both cases by zynqpl driver.
Also add suport for loading partial bitstreams.
The first driver version was done by:
Joe Hershberger <joe.hershberger@ni.com>
Fix compiler warning:
cmd_fpga.c:318: warning: passing argument 3 of 'fit_image_get_data'
from incompatible pointer type
Adding the needed 'const' here entails a whole bunch of additonal
changes all over the FPGA code.
Cc: Andre Schwarz <andre.schwarz@matrix-vision.de>
Cc: Murray Jensen <Murray.Jensen@csiro.au>
Acked-by: Andre Schwarz<andre.schwarz@matrix-vision.de>
Using seperate function calls for each bit-bang of slave serial
load can be painfully slow. This patch adds the possibility to
supply a block write function that loads the complete block of
data in one call (like it can already be done with Altera FPGAs).
On an MCF5373L (240 MHz) loading an XC3S4000 this reduces the load
time from around 15 seconds to around 3 seconds
Signed-off-by: Wolfgang Wegner <w.wegner at astro-kom.de>
PPC boards are the only users of the current FPGA code which is littered
with manual relocation fixups. Now that proper relocation is supported
for PPC boards, remove FPGA manual relocation.
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
This patch removes the FPGA subsystem configuration through
the CONFIG_FPGA bitmask configuration option.
See README for the new options:
CONFIG_FPGA,
CONFIG_FPGA_<vendor>,
CONFIG_FPGA_<family>
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
Patch by Kurt Stremerch, 14 February 2005
