path: root/include/xilinx.h
2010-03-24add block write function to spartan3 slave serial loadWolfgang Wegner
Using seperate function calls for each bit-bang of slave serial load can be painfully slow. This patch adds the possibility to supply a block write function that loads the complete block of data in one call (like it can already be done with Altera FPGAs). On an MCF5373L (240 MHz) loading an XC3S4000 this reduces the load time from around 15 seconds to around 3 seconds Signed-off-by: Wolfgang Wegner <w.wegner at astro-kom.de>
2009-10-03fpga: Remove relocation fixupsPeter Tyser
PPC boards are the only users of the current FPGA code which is littered with manual relocation fixups. Now that proper relocation is supported for PPC boards, remove FPGA manual relocation. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-01-09Improve configuration of FPGA subsystemMatthias Fuchs
This patch removes the FPGA subsystem configuration through the CONFIG_FPGA bitmask configuration option. See README for the new options: CONFIG_FPGA, CONFIG_FPGA_<vendor>, CONFIG_FPGA_<family> Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2005-09-25Add Xilinx Spartan3 family FPGA supportWolfgang Denk
Patch by Kurt Stremerch, 14 February 2005
