path: root/include/wait_bit.h
2018-01-24wait_bit: use wait_for_bit_le32 and remove wait_for_bitÁlvaro Fernández Rojas
wait_for_bit callers use the 32 bit LE version Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-01-24wait_bit: add 8/16/32 BE/LE versions of wait_for_bitÁlvaro Fernández Rojas
Add 8/16/32 bits and BE/LE versions of wait_for_bit. This is needed for reading registers that are not aligned to 32 bits, and for Big Endian platforms. Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-01-10lib: Add WATCHDOG_RESET to wait_bit.hMichal Simek
wait_for_bit() is missing reset watchdog in case watchdog is configured. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-01-25lib: Add wait_for_bitMateusz Kulikowski
Add function to poll register waiting for specific bit(s). Similar functions are implemented in few drivers - they are almost identical and can be generalized. Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
