path: root/include/vsprintf.h
2016-08-20vsprintf: Include stdarg for va_listMaxime Ripard
vsprintf.h doesn't include the stdarg.h file, which means that it relies on the files that include vsprintf.h to include stdarg.h as well. Add an explicit include to avoid build errors when simply including that file. Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2016-01-19vsprintf.c: Always enable CONFIG_SYS_VSNPRINTFTom Rini
Enabling this function always removes some class of string saftey issues. The size change here in general is about 400 bytes and this seems a reasonable trade-off. Cc: Peng Fan <peng.fan@nxp.com> Cc: Peter Robinson <pbrobinson@gmail.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Adrian Alonso <aalonso@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2015-07-21lib: Add function to extract a number from the end of a stringSimon Glass
Split out the code in fdtdec which finds a number at the end of a string. It can be useful in other situations. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-06-30mtd, nand: Move common functions from cmd_nand.c to common placeHeiko Schocher
Move common functions from cmd_nand.c (for calculating offset and size from cmdline paramter) to common place, so they could used from other commands which use mtd partitions. For onenand the arg_off_size() is left in common/cmd_onenand.c. It should use now the common arg_off() function, but as I could not test onenand I let it there ... Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Scott Wood <scottwood@freescale.com> Reviewed-by: Jagannadh Teki <jteki@openedev.com>
2015-04-23dm: Add a panic_str() function to reduce code sizeSimon Glass
The printf() in panic() adds about 1.5KB of code size to SPL when compiled with Thumb-2. Provide a smaller version that does not support printf()-style arguments and use it in two commonly compiled places. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-26Add function to print a number with grouped digitsSimon Glass
Move bootstage's numbering printing code into a generic place so that it can be used by tracing also. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-12-17vsprintf: Move function documentation into header fileSimon Glass
Now that this is not in common.h, perhaps it is acceptable to move this documentation into the header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-12-17Add safe vsnprintf and snprintf library functionsSonny Rao
From: Sonny Rao <sonnyrao@chromium.org> These functions are useful in U-Boot because they allow a graceful failure rather than an unpredictable stack overflow when printf() buffers are exceeded. Mostly copied from the Linux kernel. I copied vscnprintf and scnprintf so we can change printf and vprintf to use the safe implementation but still return the correct values. (Simon Glass <sjg@chromium.org> modified this commit a little) Signed-off-by: Sonny Rao <sonnyrao@chromium.org>
2011-12-17Move vsprintf functions into their own headerSimon Glass
common.h is very large, so before changing the vsprintf functions, move the prototypes into their own header file. Signed-off-by: Simon Glass <sjg@chromium.org>
