path: root/include/vsprintf.h
2013-06-26Add function to print a number with grouped digitsSimon Glass
Move bootstage's numbering printing code into a generic place so that it can be used by tracing also. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-12-17vsprintf: Move function documentation into header fileSimon Glass
Now that this is not in common.h, perhaps it is acceptable to move this documentation into the header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-12-17Add safe vsnprintf and snprintf library functionsSonny Rao
From: Sonny Rao <sonnyrao@chromium.org> These functions are useful in U-Boot because they allow a graceful failure rather than an unpredictable stack overflow when printf() buffers are exceeded. Mostly copied from the Linux kernel. I copied vscnprintf and scnprintf so we can change printf and vprintf to use the safe implementation but still return the correct values. (Simon Glass <sjg@chromium.org> modified this commit a little) Signed-off-by: Sonny Rao <sonnyrao@chromium.org>
2011-12-17Move vsprintf functions into their own headerSimon Glass
common.h is very large, so before changing the vsprintf functions, move the prototypes into their own header file. Signed-off-by: Simon Glass <sjg@chromium.org>
