path: root/include/virtex2.h
2014-05-13fpga: xilinx: Simplify load/dump/info function handlingMichal Simek
Connect FPGA version with appropriate operations to remove huge switch-cases for every FPGA family. Tested on Zynq. Spartan2/Spartan3/Virtex2 just compile test. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-13fpga: xilinx: Fix the rest of CamelCasesMichal Simek
No functional changes. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-13fpga: xilinx: Avoid CamelCase for in Xilinx_descMichal Simek
2014-05-13fpga: virtex2: Avoid CamelCaseMichal Simek
2011-08-01fpga: constify to fix build warningWolfgang Denk
Fix compiler warning: cmd_fpga.c:318: warning: passing argument 3 of 'fit_image_get_data' from incompatible pointer type Adding the needed 'const' here entails a whole bunch of additonal changes all over the FPGA code. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Andre Schwarz <andre.schwarz@matrix-vision.de> Cc: Murray Jensen <Murray.Jensen@csiro.au> Acked-by: Andre Schwarz<andre.schwarz@matrix-vision.de>
2009-10-03fpga: Remove relocation fixupsPeter Tyser
PPC boards are the only users of the current FPGA code which is littered with manual relocation fixups. Now that proper relocation is supported for PPC boards, remove FPGA manual relocation. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
