path: root/include/video_font_4x6.h
2018-03-06video: indicate code page of bitmap fontsHeinrich Schuchardt
Add comments clarifying that the bitmap fonts support code page 437. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2013-11-08cosmetic: remove empty lines at the top of fileMasahiro Yamada
2013-08-12video: Add small 4x6 font from LinuxMarek Vasut
This font is based on Linux drivers/video/console/font_mini_4x6.c as of commit: commit bcfbeecea11c15e243f076d37d637c2598aff4fe Author: Bjarni Ingi Gislason <bjarniig@rhi.hi.is> Date: Sun Aug 12 15:05:10 2012 +0000 drivers: console: font_: Change a glyph from "broken bar" to "vertical line" I removed these lines as they are useless in U-Boot: #include <linux/font.h> #define FONTDATAMAX 1536 Whole "const struct font_desc font_mini_4x6" block This patch also adds a new configuration option to select this smaller font, CONFIG_VIDEO_FONT_4X6 , but this is disabled by default. The default setting is the regular "large" font. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Anatolij Gustschin <agust@denx.de>
