add delay to get I2C working with "imm" command and s3c24x0_i2c.c
* Patch by Richard Woodruff, 17 July 03:
- Fixed bug in OMAP1510 baud rate divisor settings.
* Patch by Nye Liu, 16 July 2003:
MPC860FADS fixes:
- add MPC86xADS support (uses MPC86xADS.h)
- add 866P/T core support (also MPC859T/MPC859DSL/MPC852T)
o PLPRCR changes
o BRG changes (EXTAL/XTAL restricted to 10MHz)
o don't trust gclk() software measurement by default, depend on
CONFIG_8xx_GCLK_FREQ
- add DRAM SIMM not installed detection
- use more "correct" SDRAM initialization sequence
- allow different SDRAM sizes (8xxADS has 8M)
- default DER is 0
- remove unused MAMR defines from FADS860T.h (all done in fads.c)
- rename MAMR/MBMR defines to be more consistent. Should eventually
be merged into MxMR to better reflect the PowerQUICC datasheet.
* Patch by Yuli Barcohen, 16 Jul 2003:
support new Motorola PQ2FADS-ZU evaluation board which replaced
MPC8260ADS and MPC8266ADS
- Correct flash and JFFS2 support for MPC8260ADS
- fix PVR values and clock generation for PowerQUICC II family
(8270/8275/8280)
* Patch by Bernhard Kuhn, 08 Jul 2003:
- add support for M68K targets
* Patch by Ken Chou, 3 Jul:
- Fix PCI config table for A3000
- Fix iobase for natsemi.c
(PCI_BASE_ADDRESS_0 is the IO base register for DP83815)
* Allow to enable "slow" POST routines by key press on power-on
* Fix temperature dependend switching of LCD backlight on LWMON
* Tweak output format for LWMON
Improve documentation of I2C configuration in README
* Fix problems with previous log buffer "fixes"
* Fix minor help text issues
* "log append" did not append a newline
- remove trailing white space, trailing empty lines, C++ comments, etc.
- split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c)
* Patches by Kenneth Johansson, 25 Jun 2003:
- major rework of command structure
(work done mostly by Michal Cendrowski and Joakim Kristiansen)
- logdl
- csb226
- innokom
* Patch by Pantelis Antoniou, 25 Jun 2003:
update NetVia with V2 board support
- Splashscreen support
- modem support
- sysmon support
- temperature dependend enabling of LCD
* Allow booting from old "PPCBoot" disk partitions
* Add support for TQM8255 Board / MPC8255 CPU
* Add support for Purple Board (MIPS64 5Kc)
* Add support for MIPS64 5Kc CPUs
* Patch by Erwin Rol, 27 Feb 2003:
Add support for RTEMS
* Add image information to README
* Fix dual PCMCIA slot support (when running with just one
slot populated)
* Add VFD type detection to trab board
* extend drivers/cs8900.c driver to synchronize ethaddr environment
variable with value in the EEPROM
* Start adding MIPS support files
(patch by Jón Benediktsson, 11 Dec 2002)
in POST, EEPROM shows up on 8 addresses
seconds instead of ms.
* Patch by Robert Schwebel, 1 Nov 2002:
XScale related cleanup (affects all ARM boards)
* Cleanup of names, warnings and README.
