path: root/include/version.h
2015-05-27Makefile: Add U_BOOT_TZ and include in versionChris Packham
Define U_BOOT_TZ alongside U_BOOT_TIME and U_BOOT_DATE and use it to include the timezone in the version output. Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Chris Packham <judge.packham@gmail.com>
2011-10-17Move timestamp and version files into 'generated' subdirSimon Glass
There is a rather subtle build problem where the build time stamp is not updated for out-of-tree builds if there exists an in-tree build which has a valid timestamp file. So if you do an in-tree build, then an out-of-tree build your timestamp will not change. The correct timestamp_autogenerated.h lives in the object tree, but it is not always found there. The source still lives in the source tree and when compiling version.h, it includes timestamp_autogenerated.h. Since the current directory is always searched first, this will come from the source tree rather than the object tree if it exists there. This affects dependency generation also, which means that common/cmd_version.o will not even be rebuilt if you have ever done an in-tree build. A similar problem exists with the version file. This change moves both files into the 'generated' subdir, which is already used for asm-offsets.h. Then timestamp.h and version.h are updated to include the files from there. There are other places where these generated files are included, but I cannot see why these don't just use the timestamp.h and version.h headers. So this change also tidies that up. I have tested this with in- and out-of-tree builds, but not SPL. I have looked at various other options for fixing this, including sed on the dep files, -I- and -include flags to gcc, but I don't think they can be made to work. Comments welcome. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-07-28Fix build error causes by "unify version_string"Wolfgang Denk
Commit 09c2e90 "unify version_string" introduced a build error, fix it. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-07-28unify version_stringAndreas Bießmann
This patch removes the architecture specific implementation of version_string where possible. Some architectures use a special place and therefore we provide U_BOOT_VERSION_STRING definition and a common weak symbol version_string. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> CC: Mike Frysinger <vapier@gentoo.org> CC: Peter Pan <pppeterpppan@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2008-05-13Makefile: fix "error: version_autogenerated.h: No such file or directory"Wolfgang Denk
2006-02-21Add GIT version information (commid ID) to untagged U-Boot versionsWolfgang Denk
As done in the linux kernel, the U-Boot version (U_BOOT_VERSION) of all unreleased (untagged) U-Boot images will be automatically extended upon compiletime with a part of the GIT commit ID and possibly with "dirty" if uncommited changes are detected. Here an example for the resulting version: "U-Boot 1.1.4-g3457ac18-dirty" The version is now maintained in the toplevel Makefile and the version headers are autogenerated. Patch by Stefan Roese, 9 Feb 2006
2005-08-15Changed to version 1.1.4Stefan Roese
2005-01-09* Patch by Jon Loeliger, 02 Sep 2004:wdenk
Reset monitor size back to 256 so environment can be written to flash on MPC85xx ADS and CDS releases. * Patch by Paolo Broggini, 02 Sep 2004: Make BSS clearing on ARM systems more robust * Patch by Yue Hu and Joe, 01 Sep 2004: - add PCI support for ixp425; - add EEPRO100 suppor tfor ixdp425 board. * Fix problem with protected sector detection in driver/cfi_flash.c
2004-05-03* Fix minor NAND JFFS2 related issuewdenk
* Fixes for SL811 USB controller: - implement workaround for broken memory stick - improve error handling * Increase packet send timeout to 10 ms in cpu/mpc8xx/scc.c to better cope with congested networks.
2004-04-12Fix if / elif handling bug in HUSH shellwdenk
2004-04-10Release version 1.1.0U-Boot-1_1_0wdenk
2003-11-07* Patch by Bernhard Kuhn, 28 Oct 2003:wdenk
Add low boot support for MPC5200 * Fix problem with dual PCMCIA support (NSCU) * Fix MPC5200 I2C initialization function
2003-10-29* Prepare for releasewdenk
* Fix problems in memory test on some boards (which was not non-destructive as intended) * Patch by Gary Jennejohn, 28 Oct 2003: Change fs/fat/fat.c to put I/O buffers in BSS instead on the stack to prevent stack overflow on ARM systems
2003-09-11* Patch by Gary Jennejohn, 11 Sep 2003:wdenk
- allow for longer timeouts for USB mass storage devices * Patch by Denis Peter, 11 Sep 2003: - fix USB data pointer assignment for bulk only transfer. - prevent to display erased directories in FAT filesystem. * Change output format for NAND flash - make it look like for other memory, too
2003-08-31Patch by Yuli Barcohen, 7 Aug 2003:wdenk
According to the MPC8260 User's Manual, PCI_MODE signal should be reflected in SCCR register, and local bus pins configuration is taken from HRCW and appears in SIUMCR. For some reason it does not work this way, so the only possibility to detect if the board is configured in PCI mode is to check the BCSR. This patch sets SCCR and SIUMCR according to the BCSR.
2003-08-28* Fix ICU862 environment problemwdenk
* Fix RAM size detection for RMU board * Implement "reset" for MGT5100/MPC5200 systems
2003-08-17* Make Ethernet autonegotiation on INCA-IP work for all clock rates;U-Boot-0_4_6wdenk
allow selection of clock frequency as "make" target * Implement memory autosizing code for IceCube boards * Configure network port on INCA-IP for autonegotiation * Fix overflow problem in network timeout code * Patch by Richard Woodruff, 8 Aug 2003: Allow crc32 to be used at address 0x000 (crc32_no_comp, too).
2003-07-17* Patch by Martin Krause, 17 Jul 2003:wdenk
add delay to get I2C working with "imm" command and s3c24x0_i2c.c * Patch by Richard Woodruff, 17 July 03: - Fixed bug in OMAP1510 baud rate divisor settings. * Patch by Nye Liu, 16 July 2003: MPC860FADS fixes: - add MPC86xADS support (uses MPC86xADS.h) - add 866P/T core support (also MPC859T/MPC859DSL/MPC852T) o PLPRCR changes o BRG changes (EXTAL/XTAL restricted to 10MHz) o don't trust gclk() software measurement by default, depend on CONFIG_8xx_GCLK_FREQ - add DRAM SIMM not installed detection - use more "correct" SDRAM initialization sequence - allow different SDRAM sizes (8xxADS has 8M) - default DER is 0 - remove unused MAMR defines from FADS860T.h (all done in fads.c) - rename MAMR/MBMR defines to be more consistent. Should eventually be merged into MxMR to better reflect the PowerQUICC datasheet. * Patch by Yuli Barcohen, 16 Jul 2003: support new Motorola PQ2FADS-ZU evaluation board which replaced MPC8260ADS and MPC8266ADS
2003-07-16Incorporate Patch by Lutz Dennig, 15 Jul 2003.wdenk
2003-07-14* Patches by Yuli Barcohen, 13 Jul 2003:wdenk
- Correct flash and JFFS2 support for MPC8260ADS - fix PVR values and clock generation for PowerQUICC II family (8270/8275/8280) * Patch by Bernhard Kuhn, 08 Jul 2003: - add support for M68K targets * Patch by Ken Chou, 3 Jul: - Fix PCI config table for A3000 - Fix iobase for natsemi.c (PCI_BASE_ADDRESS_0 is the IO base register for DP83815) * Allow to enable "slow" POST routines by key press on power-on * Fix temperature dependend switching of LCD backlight on LWMON * Tweak output format for LWMON
2003-06-30* Patch by Seb James, 30 Jun 2003:wdenk
Improve documentation of I2C configuration in README * Fix problems with previous log buffer "fixes" * Fix minor help text issues * "log append" did not append a newline
2003-06-26* Patches by Robert Schwebel, 26 Jun 2003:U-Boot-0_4_0wdenk
- logdl - csb226 - innokom * Patch by Pantelis Antoniou, 25 Jun 2003: update NetVia with V2 board support
2003-04-27* LWMON extensions:wdenk
- Splashscreen support - modem support - sysmon support - temperature dependend enabling of LCD * Allow booting from old "PPCBoot" disk partitions * Add support for TQM8255 Board / MPC8255 CPU
2003-04-10Add support for TQM862L moduleswdenk
2003-04-08Prepare for 0.3.0 releaseU-Boot-0_3_0wdenk
* Add support for Purple Board (MIPS64 5Kc) * Add support for MIPS64 5Kc CPUs
2003-02-28* Add support for 16 MB flash configuration of TRAB boardLABEL_2003_02_28_0150wdenk
* Patch by Erwin Rol, 27 Feb 2003: Add support for RTEMS * Add image information to README * Fix dual PCMCIA slot support (when running with just one slot populated) * Add VFD type detection to trab board * extend drivers/cs8900.c driver to synchronize ethaddr environment variable with value in the EEPROM * Start adding MIPS support files
2003-01-13Add support for V37 boardLABEL_2003_01_14_0055wdenk
(patch by Jón Benediktsson, 11 Dec 2002)
2002-12-20* Switch LWMON board default config from FRAM to EEPROM;LABEL_2002_12_21_0040wdenk
in POST, EEPROM shows up on 8 addresses
2002-12-17Prepare for release of version 0.2.0wdenk
2002-11-03* Fix mdelay() on TRAB - this was still the debugging version withwdenk
seconds instead of ms. * Patch by Robert Schwebel, 1 Nov 2002: XScale related cleanup (affects all ARM boards) * Cleanup of names, warnings and README.
