path: root/include/vbe.h
2017-08-24vbe: Drop vbe_get_video_info()Bin Meng
With DM video, this is not used any more. Drop it. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2016-10-12vbe: Make vbe_setup_video_priv() publicBin Meng
vbe_setup_video_priv() might be useful to other drivers. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-11dm: video: Add driver-model support to vesa graphicsSimon Glass
Provide a function to run the Vesa BIOS for a given PCI device and obtain the resulting configuration (e.g. display size) for use by the video uclass. This makes it easier to write a video driver that uses vesa and supports driver model. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-26video: coreboot: Save VESA mode for future useBin Meng
When booting as a coreboot payload, the framebuffer details are passed from coreboot via configuration tables. We save these information into vesa_mode_info structure for future use. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-07-14x86: Configure VESA parameters before loading Linux kernelBin Meng
Store VESA parameters to Linux setup header so that vesafb driver in the kernel could work. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Jian Luo <jian.luo4@boschrexroth.de>
2015-01-23bios_emulator: Add some VESA interface debuggingSimon Glass
Allow the supported modes to be listed when in debug mode. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-25Add support for Vesa BIOS extensionsSimon Glass
For option ROMs we can use these extensions to request a particular video mode. Add a header file which defines the binary interface. Signed-off-by: Simon Glass <sjg@chromium.org>
