path: root/include/vbe.h
2022-10-31vbe: Record which phases loaded using VBESimon Glass
We expect VPL and SPL to load using VBE. Add a record of this so we can check it in U-Boot proper. Signed-off-by: Simon Glass <sjg@chromium.org>
2022-10-31vbe: Support selecting operations by SPL phaseSimon Glass
VBE supports booting firmware during the SPL phases, i.e. so that VPL can start SPL and SPL can start U-Boot. It also supports booting an OS, when in U-Boot. As a first step towards these features, add functions to indicate the current VBE phase. The firmware selection is done in VPL and the OS selection is done in U-Boot proper. Signed-off-by: Simon Glass <sjg@chromium.org>
2022-08-12vbe: Add initial support for VBESimon Glass
Create a new bootmeth for VBE along with a library to handle finding the VBE methods. Signed-off-by: Simon Glass <sjg@chromium.org>
2022-08-12video: Renname vbe.h to vesa.hSimon Glass
We want to use VBE to mean Verfiied Boot for Embedded in U-Boot. Rename the existing VBE (Vesa BIOS extensions) to allow this. Verified Boot for Embedded is documented doc/develop/vbe.rst Signed-off-by: Simon Glass <sjg@chromium.org>
2020-12-13dm: treewide: Rename ..._platdata variables to just ..._platSimon Glass
Try to maintain some consistency between these variables by using _plat as a suffix for them. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-24vbe: Drop vbe_get_video_info()Bin Meng
With DM video, this is not used any more. Drop it. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2016-10-12vbe: Make vbe_setup_video_priv() publicBin Meng
vbe_setup_video_priv() might be useful to other drivers. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-11dm: video: Add driver-model support to vesa graphicsSimon Glass
Provide a function to run the Vesa BIOS for a given PCI device and obtain the resulting configuration (e.g. display size) for use by the video uclass. This makes it easier to write a video driver that uses vesa and supports driver model. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-26video: coreboot: Save VESA mode for future useBin Meng
When booting as a coreboot payload, the framebuffer details are passed from coreboot via configuration tables. We save these information into vesa_mode_info structure for future use. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-07-14x86: Configure VESA parameters before loading Linux kernelBin Meng
Store VESA parameters to Linux setup header so that vesafb driver in the kernel could work. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Jian Luo <jian.luo4@boschrexroth.de>
2015-01-23bios_emulator: Add some VESA interface debuggingSimon Glass
Allow the supported modes to be listed when in debug mode. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-25Add support for Vesa BIOS extensionsSimon Glass
For option ROMs we can use these extensions to request a particular video mode. Add a header file which defines the binary interface. Signed-off-by: Simon Glass <sjg@chromium.org>
