path: root/include/usb_defs.h
2017-07-28usb: hub: Parse and save TT details from device descriptorBin Meng
A high speed hub has a special responsibility to handle full speed/ low speed devices connected on downstream ports. In this case, the hub must isolate the high speed signaling environment from the full speed/low speed signaling environment with the help of Transaction Translator (TT). TT details are provided by hub descriptors and we parse and save it to hub uclass_priv for later use. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-28usb: hub: Support 'set hub depth' request for USB 3.0 hubsBin Meng
USB 3.0 hub uses a hub depth value multiplied by four as an offset into the 'route string' to locate the bits it uses to determine the downstream port number. We shall set the hub depth value of a USB 3.0 hub after it is configured. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-28usb: hub: Add 3.0 hub port status mask of 2.0 hubBin Meng
USB 3.0 hub port status has different bit position regarding to port power, port speed, etc. But others are the same as 2.0 hubs. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2017-07-28usb: hub: Send correct wValue to get hub descriptor of a USB 3.0 hubBin Meng
Testing a USB 3.0 hub by connecting it to the xHCI port on Intel MinnowMax, when issuing 'get hub descriptor' to the hub, xHCI reports a transfer event TRB with a completion code 6 which means 'Stall Error'. In fact super speed USB hub descriptor type is 0x2a, not 0x29. Sending correct SETUP packet to the hub makes it not stall anymore. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2015-04-18dm: usb: Tidy up pipe value decodingSimon Glass
Add a few more shifts/masks to make it easier to decode a pipe value (rather than just building it). We need this for USB device emulation. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: sandbox: Add an emulator for USB hub emulationSimon Glass
All USB controllers need a root hub. Add a sandbox emulation for this so that we can add USB devices to sandbox. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: Move USB storage definitions to usb_defs.hSimon Glass
These are better off in a header file so they can be used by other code (e.g. the sandbox USB storage emulator). Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2013-10-20usb: Move 'bmRequestType' USB device request macros from EHCI headerVivek Gautam
Macros defining bmRequestType field of USB device request, given in table 9.2 USB 2.0 spec, are rather generic macros which can be further used by other Host controller stacks. So moving them to usb_defs header. Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com> Cc: Julius Werner <jwerner@chromium.org> Cc: Simon Glass <sjg@chromium.org> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Dan Murphy <dmurphy@ti.com> Cc: Marek Vasut <marex@denx.de>
2013-05-06usb: fix: Fixing Port status and feature number constantsVivek Gautam
Fix the Port status bit constants and Port feature number constants as a part of USB 2.0 and USB 3.0 Hub class. Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com>
2013-05-05USB: SS: Add support for Super Speed USB interfaceVivek Gautam
This adds usb framework support for super-speed usb, which will further facilitate to add stack support for xHCI. Signed-off-by: Vikas C Sajjan <vikas.sajjan@samsung.com> Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com>
2013-05-05USB: Some cleanup prior to USB 3.0 interface additionVivek Gautam
Some cleanup in usb framework, nothing much on feature side. Signed-off-by: Vikas C Sajjan <vikas.sajjan@samsung.com> Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com>
2013-05-05usb: Add new command to set USB 2.0 port test modesJulius Werner
This patch adds a new 'usb test' command, that will set a port to a USB 2.0 test mode (see USB 2.0 spec 7.1.20). It supports all five test modes on both downstream hub ports and ordinary device's upstream ports. In addition, it supports EHCI root hub ports. Signed-off-by: Julius Werner <jwerner@chromium.org>
2012-11-20usb: use linux/usb/ch9.h instead of usbdescriptors.hIlya Yanok
Linux usb/ch9.h seems to have all the same information (and more) as usbdescriptors.h so use the former instead of the later one. As a consequense of this change USB_SPEED_* values don't correspond directly to EHCI speed encoding anymore, I've added necessary recoding in EHCI driver. Also there is no point to put speed into pipe anymore so it's removed and a bunch of host drivers fixed to look at usb_device->speed instead. Old usbdescriptors.h included is not removed as it seems to be used by old USB device code. This makes usb.h and usbdevice.h incompatible. Fortunately the only place that tries to include both are the old MUSB code and it needs usb.h only for USB_DMA_MINALIGN used in aligned attribute on musb_regs structure but this attribute seems to be unneeded (old MUSB code doesn't support any DMA at all). Signed-off-by: Ilya Yanok <ilya.yanok@cogentembedded.com>
2009-01-28Prepare USB layer for ehciMichael Trimarchi
Prepare USB layer for ehci support Signed-off-by: Michael Trimarchi <trimarchi@gandalf.sssup.it> Signed-off-by: Remy Böhmer <linux@bohmer.net>
2005-08-02Remove unnecessary defines from usb_defs.h again.Stefan Roese
Patch by Stefan Roese, 2 Aug 2005
2005-08-01Add support for AMCC PPC440EP/GR eval boards Yosemite and Yellowstone.Stefan Roese
Patch by Steven Blakeslee, 27 Jul 2005
2005-07-21Fix low-level OHCI transfers for ARM920t and MPC5xxxWolfgang Denk
A new, Windows compatible init sequence was also backported from Linux 2.6, but disabled with #undef NEW_INIT_SEQ as it wouldn't change the behaviour of the memopry sticks we tested. Maybe it's not relevant for mass storage devices. For recerence, see file common/usb.c, function usb_new_device(), section #ifdef NEW_INIT_SEQ.
2002-03-08Initial revisionwdenk
