path: root/include/usb_defs.h
2009-01-28Prepare USB layer for ehciMichael Trimarchi
Prepare USB layer for ehci support Signed-off-by: Michael Trimarchi <trimarchi@gandalf.sssup.it> Signed-off-by: Remy Böhmer <linux@bohmer.net>
2005-08-02Remove unnecessary defines from usb_defs.h again.Stefan Roese
Patch by Stefan Roese, 2 Aug 2005
2005-08-01Add support for AMCC PPC440EP/GR eval boards Yosemite and Yellowstone.Stefan Roese
Patch by Steven Blakeslee, 27 Jul 2005
2005-07-21Fix low-level OHCI transfers for ARM920t and MPC5xxxWolfgang Denk
A new, Windows compatible init sequence was also backported from Linux 2.6, but disabled with #undef NEW_INIT_SEQ as it wouldn't change the behaviour of the memopry sticks we tested. Maybe it's not relevant for mass storage devices. For recerence, see file common/usb.c, function usb_new_device(), section #ifdef NEW_INIT_SEQ.
2002-03-08Initial revisionwdenk
