path: root/include/usb/s3c_udc.h
2012-05-20usb:udc:samsung:cleanup Replace DEBUG_* macros with debug_cond() callsLukasz Majewski
This patch cleans up the Samsung's UDC driver. It replaces several DEBUG_* macros with debug_cond(). Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Marek Vasut <marex@denx.de>
2012-05-20usb:udc: Remove duplicated USB definitions from include/linux/usb/ch9.h fileLukasz Majewski
Remove the repeated USB descriptor code and use usbdescriptors.h file. ch9.h file has been copied from linux and is needed for USB gadget related work. Now usbdescriptors.h and ch9.h shall be used together. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Marek Vasut <marex@denx.de>
2012-03-19usb:udc:samsung:fix Remove the req_config flagƁukasz Majewski
The dev->req_config flag was indicating that the forwarded request needs to perform the usb gadget delayed status. This is however not needed anymore, so it can be removed. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Marek Vasut <marex@denx.de>
2011-12-20usb: s3c_udc_otg: fix GCC 4.6 build warningsAnatolij Gustschin
Fix: In file included from s3c_udc_otg.c:216:0: s3c_udc_otg_xfer_dma.c: In function 'complete_tx': s3c_udc_otg_xfer_dma.c:280:33: warning: variable 'is_short' set but not used s3c_udc_otg_xfer_dma.c:280:6: warning: variable 'ep_tsr' set but not used s3c_udc_otg_xfer_dma.c: In function 's3c_udc_irq': s3c_udc_otg_xfer_dma.c:469:16: warning: variable 'flags' set but not used s3c_udc_otg_xfer_dma.c:468:18: warning: variable 'gintmsk' set but not used s3c_udc_otg_xfer_dma.c: In function 's3c_queue': s3c_udc_otg_xfer_dma.c:582:14: warning: variable 'gintsts' set but not used s3c_udc_otg_xfer_dma.c:581:16: warning: variable 'flags' set but not used s3c_udc_otg_xfer_dma.c: In function 's3c_ep0_read': s3c_udc_otg_xfer_dma.c:778:6: warning: variable 'ret' set but not used s3c_udc_otg_xfer_dma.c: In function 's3c_udc_set_halt': s3c_udc_otg_xfer_dma.c:1020:16: warning: variable 'flags' set but not used s3c_udc_otg_xfer_dma.c: In function 's3c_ep0_setup': s3c_udc_otg_xfer_dma.c:1258:13: warning: initialization from incompatible pointer type [enabled by default] s3c_udc_otg_xfer_dma.c:1239:16: warning: variable 'is_in' set but not used s3c_udc_otg_xfer_dma.c:1239:9: warning: variable 'bytes' set but not used s3c_udc_otg.c: In function 'usb_gadget_register_driver': s3c_udc_otg.c:292:16: warning: variable 'flags' set but not used s3c_udc_otg.c: In function 'usb_gadget_unregister_driver': s3c_udc_otg.c:338:16: warning: variable 'flags' set but not used s3c_udc_otg.c: In function 's3c_ep_enable': s3c_udc_otg.c:582:16: warning: variable 'flags' set but not used s3c_udc_otg.c: In function 's3c_ep_disable': s3c_udc_otg.c:646:16: warning: variable 'flags' set but not used s3c_udc_otg.c: In function 's3c_dequeue': s3c_udc_otg.c:704:16: warning: variable 'flags' set but not used Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Remy Bohmer <linux@bohmer.net>
2011-12-11usb:gadget:s5p USB Device Controller (UDC) implementationLukasz Majewski
This commit provides UDC driver support for Samsung's SoC family of processors. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Remy Bohmer <linux@bohmer.net>
