path: root/include/usb/ehci-fsl.h
2011-12-11USB: MX5: Abstract out mx51 USB pixmux configurationMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Remy Bohmer <linux@bohmer.net> Cc: Wolfgang Grandegger <wg@denx.de> Cc: Jason Liu <r64343@freescale.com>
2011-12-11USB: MX5: add generic USB EHCI support for mx51 and mx53Wolfgang Grandegger
It's derived from ehci-mxc and uses the header files of the ehci-fsl interface. The callback board_ehci_hcd_init() has been introduced to allow for board-specific setup when USB is started. Signed-off-by: Wolfgang Grandegger <wg@denx.de> CC: Stefano Babic <sbabic@denx.de> CC: Remy Bohmer <linux@bohmer.net>
2011-12-11ehci-fsl: correct size of ehci caplengthWolfgang Grandegger
According to the EHCI specification the Capability Register Length has a size of 8 bits. Signed-off-by: Wolfgang Grandegger <wg@denx.de> Acked-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-21Fix building for 83xx boards with USB supportAnatolij Gustschin
Commit 29c6fbe0471afd7ffa41fcb2103eec5b53294897 broke building for 83xx boards with USB support: ehci-fsl.c: In function 'ehci_hcd_init': ehci-fsl.c:43: error: 'CONFIG_SYS_FSL_USB_ADDR' undeclared (first use in this function) ehci-fsl.c:43: error: (Each undeclared identifier is reported only once ehci-fsl.c:43: error: for each function it appears in.) make[1]: *** [ehci-fsl.o] Error 1 Signed-off-by: Anatolij Gustschin <agust@denx.de>
2010-10-18MPC5121: Add USB EHCI supportDamien Dusha
Signed-off-by: Francesco Rendine <francesco.rendine@valueteam.com> Signed-off-by: Damien Dusha <d.dusha@gmail.com> Signed-off-by: Anatolij Gustschin <agust@denx.de> Coding style cleanup; slight file restructuring. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Remy Bohmer <linux@bohmer.net>
2010-01-17PCIe, USB: Replace 'end point' references with 'endpoint'Peter Tyser
When referring to PCIe and USB 'endpoint' is the standard naming convention. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Remy Bohmer <linux@bohmer.net>
2009-07-09usb: fix CONFIG_SYS_MPC83xx_USB_ADDR not defined errorKim Phillips
fix a stray CONFIG_MPC83XX that escaped commit 0f898604945af4543c1525fc33b6bae621a3b805. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Remy Bohmer <linux@bohmer.net>
2009-06-12mpc85xx: USB: Add supportVivek Mahajan
The following patch adds 85xx-specific USB support and also revamps Copyright in immap_85xx.h Signed-off-by: Vivek Mahajan <vivek.mahajan@freescale.com> Signed-off-by: Remy Bohmer <linux@bohmer.net>
2009-06-12mpc83xx: USB: Reorganized its supportVivek Mahajan
The following patch reorganizes/reworks the USB support for mpc83xx as under:- * Moves the 83xx USB clock init from drivers/usb/host/ehci-fsl.c to cpu/mpx83xx/cpu_init.c * Board specific usb_phy_type is read from the environment * Adds USB EHCI specific structure in include/usb/ehci-fsl.h * Copyrights revamped in most of the following files Signed-off-by: Vivek Mahajan <vivek.mahajan@freescale.com> Signed-off-by: Remy Bohmer <linux@bohmer.net>
2009-06-12mpc8xxx: USB: Relocates ehci-fsl.h to include/usbVivek Mahajan
The following patch moves 8xxx-specifc USB #defines from drivers/usb/host/ehci-fsl.h to include/usb. Signed-off-by: Vivek Mahajan <vivek.mahajan@freescale.com> Signed-off-by: Remy Bohmer <linux@bohmer.net>
