path: root/include/usb.h
2008-03-27Fix compilation error in cmd_usb.cAnatolij Gustschin
This patch fixes compilation error cmd_usb.c: In function 'do_usb': cmd_usb.c:552: error: void value not ignored as it ought to be Signed-off-by: Anatolij Gustschin <agust@denx.de>
2007-06-06USB event poll supportZhang Wei
This patch adds USB event poll support, which could be used in usbkbd and other usb devices driver when the asynchronous interrupt processing is supported. Signed-off-by: Zhang Wei <wei.zhang@freescale.com
2007-04-03Support for the Philips ISP116x HCD (Host Controller Driver)Rodolfo Giometti
Signed-off-by: Rodolfo Giometti <giometti@enneenne.com>
2006-11-27Fix some endianness issues related to the generic ohci driverMarkus Klotzbuecher
2006-11-27Introduced the configuration option CONFIG_USB_OHCI_NEW in order to be ableMarkus Klotzbuecher
to choose between the old and the generic OHCI drivers.
2006-08-02Add rudimentary handling of alternate settings of USB interfaces - to fixBartlomiej Sieka
problems with some USB storage devices. Some code readability improvements.
2005-07-21Fix low-level OHCI transfers for ARM920t and MPC5xxxWolfgang Denk
A new, Windows compatible init sequence was also backported from Linux 2.6, but disabled with #undef NEW_INIT_SEQ as it wouldn't change the behaviour of the memopry sticks we tested. Maybe it's not relevant for mass storage devices. For recerence, see file common/usb.c, function usb_new_device(), section #ifdef NEW_INIT_SEQ.
2004-04-23* Modify KUP4X board configuration to use SL811 driver for USB memoryLABEL_2004_04_23_2240wdenk
sticks (including FAT / VFAT filesystem support) * Add SL811 Host Controller Interface driver for USB * Add CFG_I2C_EEPROM_ADDR_OVERFLOW desription to README * Patch by Pantelis Antoniou, 19 Apr 2004: Allow to use shell style syntax (i. e. ${var} ) with standard parser. Minor patches for Intracom boards. * Patch by Christian Pell, 19 Apr 2004: cleanup support for CF/IDE on PCMCIA for PXA25X
2004-02-23* CVS add missing fileswdenk
* Cleanup compiler warnings * Fix problem with side effects in macros in include/usb.h * Patch by David Benson, 13 Nov 2003: bug 841358 - fix TFTP download size limit * Fixing bug 850768: improper flush_cache() in load_serial() * Fixing bug 834943: MPC8540 - missing volatile declarations * Patch by Stephen Williams, 09 Feb 2004: Add support for Xilinx SystemACE chip: - New files common/cmd_ace.c and include/systemace.h - Hook systemace support into cmd_fat and the partition manager * Patch by Travis Sawyer, 09 Feb 2004: Add bi_opbfreq & bi_iic_fast to 440GX bd_info as needed for Linux
2003-09-10* Add support for USB Mass Storage Devices (BBB)wdenk
(tested with USB memory sticks only) * Avoid flicker on TRAB's VFD
2002-03-08Initial revisionwdenk
