path: root/include/usb.h
2012-07-18ehci-hcd.c, musb_core, usb.h: Add USB_DMA_MINALIGN define for cache alignmentTom Rini
The USB spec says that 32 bytes is the minimum required alignment. However on some platforms we have a larger minimum requirement for cache coherency. In those cases, use that value rather than the USB spec minimum. We add a cpp check to <usb.h> to define USB_DMA_MINALIGN and make use of it in ehci-hcd.c and musb_core.h. We cannot use MAX() here as we are not allowed to have tests inside of align(...). Signed-off-by: Tom Rini <trini@ti.com> [marek.vasut]: introduce some crazy macro voodoo Signed-off-by: Marek Vasut <marex@denx.de> [ilya.yanok]: moved external buffer fixes to separate patch, we use {ALLOC,DEFINE}_ALIGN_BUFFER macros with alignment of USB_DMA_MINALIGN for qh_list, qh and qtd structures to make sure they are proper aligned for both controller and cache operations. Signed-off-by: Ilya Yanok <ilya.yanok@cogentembedded.com>
2012-05-20USB: Align buffers at cachelinePuneet Saxena
This avoids cache-alignment warnings shown in console when a usb command is entered. Whenever X bytes of unaligned buffer is invalidated, arm core invalidates X + Y bytes as per the cache line size and throws these warnings. Signed-off-by: Puneet Saxena <puneets@nvidia.com> Signed-off-by: Marek Vasut <marex@denx.de>
2012-03-19usb: replace wait_ms() with mdelay()Mike Frysinger
Common code has a mdelay() func, so use that instead of the usb-specific wait_ms() func. This also fixes the build errors: ohci-hcd.c: In function 'submit_common_msg': /usr/local/src/u-boot/blackfin/include/usb.h:202:44: sorry, unimplemented: inlining failed in call to 'wait_ms': function body not available ohci-hcd.c:1519:9: sorry, unimplemented: called from here /usr/local/src/u-boot/blackfin/include/usb.h:202:44: sorry, unimplemented: inlining failed in call to 'wait_ms': function body not available ohci-hcd.c:1816:10: sorry, unimplemented: called from here /usr/local/src/u-boot/blackfin/include/usb.h:202:44: sorry, unimplemented: inlining failed in call to 'wait_ms': function body not available ohci-hcd.c:1827:10: sorry, unimplemented: called from here /usr/local/src/u-boot/blackfin/include/usb.h:202:44: sorry, unimplemented: inlining failed in call to 'wait_ms': function body not available ohci-hcd.c:1844:10: sorry, unimplemented: called from here /usr/local/src/u-boot/blackfin/include/usb.h:202:44: sorry, unimplemented: inlining failed in call to 'wait_ms': function body not available ohci-hcd.c:1563:11: sorry, unimplemented: called from here /usr/local/src/u-boot/blackfin/include/usb.h:202:44: sorry, unimplemented: inlining failed in call to 'wait_ms': function body not available ohci-hcd.c:1583:9: sorry, unimplemented: called from here make[1]: *** [ohci-hcd.o] Error 1 Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Marek Vasut <marex@denx.de>
2012-03-03USB: move keyboard polling into kbd driveramartin@nvidia.com
This moves keyboard polling logic from USB HCD drivers into USB keyboard driver. Remove usb_event_poll() as keyboard polling was the only user of this API. With this patch USB keyboard works with EHCI controllers again. Tested on a tegra2 seaboard. Signed-off-by: Allen Martin <amartin@nvidia.com>
2012-03-03USB: Separate out USB hub driverMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Remy Bohmer <linux@bohmer.net> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-08-08usb: increase non-bulk timeout for slow chipsets.Jason Cooper
If you take a look at 96820a35, you'll see the original timeout was CONFIG_SYS_HZ. Which is 1000. After the mentioned change, non-bulk timeout was changed to 100. This causes timeout failures on the dreamplug platform when trying to initialize the usb microsd reader. Signed-off-by: Jason Cooper <u-boot@lakedaemon.net> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-02-19Add USB host ethernet adapter supportSimon Glass
This adds support for using USB Ethernet dongles in host mode. This is just the framework - drivers will come later. A new config option called CONFIG_USB_HOST_ETHER can be defined in board config files to switch this on. The was originally written by NVIDIA and was cleaned up for release by the Chromium authors. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-02-19Fix EHCI usb submit timeout and unify with OHCISimon Glass
Changed both to use a common timeout for URB submission, since they were using different values and EHCI's was too short. Also fixed EHCI to actually check if urb submission succeeded, rather than silently continuing into the weeds. Change-Id: I7f71499ffaa05187d8e5618db2419e1606007b82 Signed-off-by: Simon Glass <sjg@chromium.org>
2010-08-12musb: MSC host support for AM35xAjay Kumar Gupta
Tested MSC Host on AM3517EVM. Signed-off-by: Ajay Kumar Gupta <ajay.gupta@ti.com>
2010-05-27USB: fix create_pipe()Sergei Shtylyov
create_pipe() can give wrong result if an expression is passed as the 'endpoint' argument -- due to missing parentheses. Thanks to Martin Mueller for finding the bug and providing the patch. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com>
2010-01-09usb: musb: add support for Blackfin MUSBBryan Wu
Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Cliff Cai <cliff.cai@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Remy Bohmer <linux@bohmer.net>
2010-01-09DA8xx: Add MUSB host supportAjay Kumar Gupta
Tested USB host functionality on DA830 EVM. Signed-off-by: Ajay Kumar Gupta <ajay.gupta@ti.com> Signed-off-by: Swaminathan S <swami.iyer@ti.com>
2009-12-20OMAP3 Add usb device supportTom Rix
This change adds the usb device support for musb. Omap3 platform support added at the same level as davinci. The interface for usbtty to use the musb device support was added. Verified on omap3 beagle, zoom1 and zoom2. Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-12-20USB Consolidate descriptor definitionsTom Rix
The header files usb.h and usbdescriptors.h have the same nameed structure definitions for usb_config_descriptor usb_interface_descriptor usb_endpoint_descriptor usb_device_descriptor usb_string_descriptor These are out right duplicates in usb.h usb_device_descriptor usb_string_descriptor This one has extra unused elements usb_endpoint_descriptor unsigned char bRefresh unsigned char bSynchAddress; These in usb.h have extra elements at the end of the usb 2.0 specified descriptor and are used. usb_config_descriptor usb_interface_descriptor The change is to consolidate the definition of the descriptors to usbdescriptors.h. The dublicates in usb.h are removed. The extra element structure will have their name shorted by removing the '_descriptor' suffix. So usb_config_descriptor -> usb_config usb_interface_descriptor -> usb_interface For these, the common descriptor elements are accessed now by an element 'desc'. As an example - if (iface->bInterfaceClass != USB_CLASS_HUB) + if (iface->desc.bInterfaceClass != USB_CLASS_HUB) This has been compile tested on MAKEALL arm, ppc and mips. Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-01-28usb : musb : Enabling DM6446 (TI DaVinci) USB module powerThomas Abraham
Enabling DM6446 (TI DaVinci) USB module power and MUSB low-level controller hook up to USB core layer. Signed-off-by: Ravi Babu <ravibabu@ti.com> Signed-off-by: Swaminathan S <swami.iyer@ti.com> Signed-off-by: Thomas Abraham <t-abraham@ti.com> Signed-off-by: Ajay Kumar Gupta <ajay.gupta@ti.com> Signed-off-by: Remy Bohmer <linux@bohmer.net>
2009-01-28usb.h: use standard __LITTLE_ENDIAN from Linux headersMike Frysinger
Rather than forcing people to define a custom "LITTLEENDIAN", just use the __LITTLE_ENDIAN one from the Linux byteorder headers that every arch is already setting up. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Remy Bohmer <linux@bohmer.net>
2009-01-28[PATCH] This patch add varius fix to the ehci.michael
- fix ehci_readl, ehci_writel - introduce new define in ehci.h - introduce the handshake function for waiting on a register - fix usb_ehci_fsl with the new HC_LENGTH macro Signed-off-by: Michael Trimarchi <trimarchimichael@yahoo.it> Signed-off-by: Remy Böhmer <linux@bohmer.net>
2009-01-28Prepare USB layer for ehciMichael Trimarchi
Prepare USB layer for ehci support Signed-off-by: Michael Trimarchi <trimarchi@gandalf.sssup.it> Signed-off-by: Remy Böhmer <linux@bohmer.net>
2008-12-09USB: descriptor handlingStefan Althoefer
Hi, I found a bug when working with the u-boot USB subsystem on IXP425 processor (big endian Xscale aka ARMv5). I recognized that the second usb_endpoint_descriptor of the attached memory stick was corrupted. The reason for this are the packed structures below (either u-boot and u-boot-usb): -------------- /* Endpoint descriptor */ struct usb_endpoint_descriptor { unsigned char bLength; unsigned char bDescriptorType; unsigned char bEndpointAddress; unsigned char bmAttributes; unsigned short wMaxPacketSize; unsigned char bInterval; unsigned char bRefresh; unsigned char bSynchAddress; } __attribute__ ((packed)); /* Interface descriptor */ struct usb_interface_descriptor { unsigned char bLength; unsigned char bDescriptorType; unsigned char bInterfaceNumber; unsigned char bAlternateSetting; unsigned char bNumEndpoints; unsigned char bInterfaceClass; unsigned char bInterfaceSubClass; unsigned char bInterfaceProtocol; unsigned char iInterface; unsigned char no_of_ep; unsigned char num_altsetting; unsigned char act_altsetting; struct usb_endpoint_descriptor ep_desc[USB_MAXENDPOINTS]; } __attribute__ ((packed)); ------------ As usb_endpoint_descriptor is only 7byte in length, the start of all odd ep_desc[] structures is not word aligned. This makes wMaxPacketSize of these structures also not word aligned. ARMv5 Architecture however does not support non-aligned multibyte data type (see A2.8 of ARM Architecture Reference Manual). Signed-off-by: Stefan Althoefer <stefan.althoefer@web.de> Signed-off-by: Remy Böhmer <linux@bohmer.net>
2008-11-28USB style patch, 80 chars strictMichael Trimarchi
USB Code style patch Signed-off-by: Michael Trimarchi <trimarchi@gandalf.sssup.it> Signed-off-by: Remy Böhmer <linux@bohmer.net>
2008-10-14fix USB initialisation procedureRemy Bohmer
The max packet size is encoded as 0,1,2,3 for 8,16,32,64 bytes. At some places directly 8,16,32,64 was used instead of the encoded value. Made a enum for the options to make this more clear and to help preventing similar errors in the future. After fixing this bug it became clear that another bug existed where the 'pipe' is and-ed with PIPE_* flags, where it should have been 'usb_pipetype(pipe)', or even better usb_pipeint(pipe). Also removed the triple 'get_device_descriptor' sequence, it has no use, and Windows nor Linux behaves that way. There is also a poll going on with a timeout when usb_control_msg() fails. However, the poll is useless, because the flag will never be set on a error, because there is no code that runs in a parallel that can set this flag. Changed this to something more logical. Tested on AT91SAM9261ek and compared the flow on the USB bus to what Linux is doing. There is no difference anymore in the early initialisation sequence. Signed-off-by: Remy Bohmer <linux@bohmer.net> Signed-off-by: Markus Klotzbuecher <mk@denx.de>
2008-08-07usb: add support for R8A66597 usb controllerYoshihiro Shimoda
add support for Renesas R8A66597 usb controller. This patch supports USB Host mode. Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Markus Klotzbuecher <mk@denx.de>
2008-03-27Fix compilation error in cmd_usb.cAnatolij Gustschin
This patch fixes compilation error cmd_usb.c: In function 'do_usb': cmd_usb.c:552: error: void value not ignored as it ought to be Signed-off-by: Anatolij Gustschin <agust@denx.de>
2007-06-06USB event poll supportZhang Wei
This patch adds USB event poll support, which could be used in usbkbd and other usb devices driver when the asynchronous interrupt processing is supported. Signed-off-by: Zhang Wei <wei.zhang@freescale.com
2007-04-03Support for the Philips ISP116x HCD (Host Controller Driver)Rodolfo Giometti
Signed-off-by: Rodolfo Giometti <giometti@enneenne.com>
2006-11-27Fix some endianness issues related to the generic ohci driverMarkus Klotzbuecher
2006-11-27Introduced the configuration option CONFIG_USB_OHCI_NEW in order to be ableMarkus Klotzbuecher
to choose between the old and the generic OHCI drivers.
2006-08-02Add rudimentary handling of alternate settings of USB interfaces - to fixBartlomiej Sieka
problems with some USB storage devices. Some code readability improvements.
2005-07-21Fix low-level OHCI transfers for ARM920t and MPC5xxxWolfgang Denk
A new, Windows compatible init sequence was also backported from Linux 2.6, but disabled with #undef NEW_INIT_SEQ as it wouldn't change the behaviour of the memopry sticks we tested. Maybe it's not relevant for mass storage devices. For recerence, see file common/usb.c, function usb_new_device(), section #ifdef NEW_INIT_SEQ.
2004-04-23* Modify KUP4X board configuration to use SL811 driver for USB memoryLABEL_2004_04_23_2240wdenk
sticks (including FAT / VFAT filesystem support) * Add SL811 Host Controller Interface driver for USB * Add CFG_I2C_EEPROM_ADDR_OVERFLOW desription to README * Patch by Pantelis Antoniou, 19 Apr 2004: Allow to use shell style syntax (i. e. ${var} ) with standard parser. Minor patches for Intracom boards. * Patch by Christian Pell, 19 Apr 2004: cleanup support for CF/IDE on PCMCIA for PXA25X
2004-02-23* CVS add missing fileswdenk
* Cleanup compiler warnings * Fix problem with side effects in macros in include/usb.h * Patch by David Benson, 13 Nov 2003: bug 841358 - fix TFTP download size limit * Fixing bug 850768: improper flush_cache() in load_serial() * Fixing bug 834943: MPC8540 - missing volatile declarations * Patch by Stephen Williams, 09 Feb 2004: Add support for Xilinx SystemACE chip: - New files common/cmd_ace.c and include/systemace.h - Hook systemace support into cmd_fat and the partition manager * Patch by Travis Sawyer, 09 Feb 2004: Add bi_opbfreq & bi_iic_fast to 440GX bd_info as needed for Linux
2003-09-10* Add support for USB Mass Storage Devices (BBB)wdenk
(tested with USB memory sticks only) * Avoid flicker on TRAB's VFD
2002-03-08Initial revisionwdenk
