path: root/include/uboot_aes.h
2018-01-29aes: Allow non-zero initialization vectorАндрей Мозжухин
AES encryption in CBC mode, in most cases, must be used with random initialization vector. Using the same key and initialization vector several times is weak and must be avoided. Added iv parameter to the aes_cbc_encrypt_blocks and aes_cbc_decrypt_blocks functions for passing initialization vector. Command 'aes' now also require the initialization vector parameter. Signed-off-by: Andrey Mozzhuhin <amozzhuhin@yandex.ru>
2017-04-12Rename aes.h to uboot_aes.hStefano Babic
aes.h is a too generic name if this file can be exported and used by a program. Rename it to avoid any conflicts with other files (for example, from openSSL). Signed-off-by: Stefano Babic <sbabic@denx.de>
