path: root/include/u-boot
2012-04-30gunzip: rename z{alloc, free} to gz{alloc, free}Mike Frysinger
This allows us to add a proper zalloc() func (one that does a zeroing alloc), and removes duplicate prototypes. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-04-29GCC47: Fix warning in md5.cMarek Vasut
md5.c: In function ‘MD5Final’: md5.c:156:2: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing] md5.c:157:2: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing] Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-09-10tools: mkimage: Fixed build warningsPrafulla Wadaskar
uninitialized retval variable warning fixed crc32 APIs moved to crc.h (newly added) and build warnings fixed Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-08-23start a linker script helper fileMike Frysinger
Start a common header file for common linker script code (such as workarounds for older linkers) rather than doing this in the build system. As fallout, we no longer execute the linker every time config.mk is included by a build file (which can easily be 70+ times), but rather only execute it once. This also fixes a bug in the major version checking by creating a macro to easily compare versions and keep people from making the same common mistake (forgetting to check major and minor together). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-08-11zlib: updated to v.1.2.3Giuseppe CONDORELLI
This patch updates zlib to the latest stable version. Only relevant zlib parts were ported to u-boot tree, as already did for the current zlib (0.95). New zlib guarantees a faster inflate performances other then others improvements as explained at www.zlib.net. It also includes Alessandro Rubini's patches to allow 0 as destination pointer and to call watchdog reset if required by architecture. Signed-off-by: Giuseppe Condorelli <giuseppe.condorelli@st.com> Reviewed-by: Angelo Castello <angelo.castello@st.com> Reviewed-by: Alessandro Rubini <rubini-list@gnudd.com>
2009-07-24Revert "zlib: updated to v.1.2.3"Wolfgang Denk
This reverts commit b201171f2b4d509f3ad510b214bee70ff902e3d6. The commit caused problems for example when unpacking kernel images: Uncompressing Kernel Image ... Error: inflate() returned -2 GUNZIP: uncompress, out-of-mem or overwrite error - must RESET board to recover Conflicts: include/u-boot/zlib.h lib_generic/zlib.c Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-23Coding Style cleanup; update CHANGELOG.Wolfgang Denk
2009-07-23zlib: updated to v.1.2.3Giuseppe CONDORELLI
This patch updates zlib to the latest stable version. Only relevant zlib parts were ported to u-boot tree, as was done for the previously used version of zlib (0.95). New zlib gives faster inflate performance and other improvements, see www.zlib.net Signed-off-by: Giuseppe Condorelli <giuseppe.condorelli@st.com> Reviewed-by: Angelo Castello <angelo.castello@st.com> Edited commit message Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-19compiler.h: unify system ifdef cruft hereMike Frysinger
Shove a lot of the HOSTCC and related #ifdef checking crap into the new compiler.h header so that we can keep all other headers nice and clean. Also introduce custom uswap functions so we don't have to rely on the non standard implementations that a host may (or may not in the case of OS X) provide. This allows mkimage to finally build cleanly on an OS X system. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-04-04rename include/zlib.h to include/u-boot/zlib.hJean-Christophe PLAGNIOL-VILLARD
Some systems have zlib.h installed in /usr/include/. This isn't the desired file for u-boot code - we want the one in include/zlib.h. This rename will avoid the conflict. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-04-25Add support for calculating hashes with watchdog triggeringBartlomiej Sieka
Implement watchodg-aware variants of hash calculation functions: - crc32_wd() - md5_wd() - sha1_csum_wd() The above functions calculate the hash of the input buffer in chunks, triggering the watchdog after processing each chunk. The chunk size is given as a function call parameter. Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-04-13Rename include/md5.h to include/u-boot/md5.hAndy Fleming
Some systems have md5.h installed in /usr/include/. This isn't the desired file (we want the one in include/md5.h). This will avoid the conflict. This fixes the host tools building problem by creating a new directory for U-Boot specific header files. [Patch by Andy Fleming, modified to use separate directory by Wolfgang Denk] Signed-off-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Andy Fleming <afleming@freescale.com> Acked-by: Timur Tabi <timur@freescale.com>
