Now that the other architecture-specific lib directories have been
moved out of the top-level directory there's not much reason to have the
'_generic' suffix on the common lib directory.
uninitialized retval variable warning fixed
crc32 APIs moved to crc.h (newly added) and build warnings fixed
Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
Start a common header file for common linker script code (such as
workarounds for older linkers) rather than doing this in the build system.
As fallout, we no longer execute the linker every time config.mk is
included by a build file (which can easily be 70+ times), but rather only
execute it once.
This also fixes a bug in the major version checking by creating a macro to
easily compare versions and keep people from making the same common
mistake (forgetting to check major and minor together).
This patch updates zlib to the latest stable version.
Only relevant zlib parts were ported to u-boot tree, as already did for the
current zlib (0.95). New zlib guarantees a faster inflate performances
other then others improvements as explained at www.zlib.net.
It also includes Alessandro Rubini's patches to allow 0 as destination pointer
and to call watchdog reset if required by architecture.
Signed-off-by: Giuseppe Condorelli <giuseppe.condorelli@st.com>
Reviewed-by: Angelo Castello <angelo.castello@st.com>
Reviewed-by: Alessandro Rubini <rubini-list@gnudd.com>
This reverts commit b201171f2b4d509f3ad510b214bee70ff902e3d6.
The commit caused problems for example when unpacking kernel images:
Uncompressing Kernel Image ... Error: inflate() returned -2
GUNZIP: uncompress, out-of-mem or overwrite error - must
RESET board to recover
include/u-boot/zlib.h
lib_generic/zlib.c
Only relevant zlib parts were ported to u-boot tree, as was done for
the previously used version of zlib (0.95). New zlib gives faster
inflate performance and other improvements, see www.zlib.net
Edited commit message
Shove a lot of the HOSTCC and related #ifdef checking crap into the new
compiler.h header so that we can keep all other headers nice and clean.
Also introduce custom uswap functions so we don't have to rely on the non
standard implementations that a host may (or may not in the case of OS X)
provide. This allows mkimage to finally build cleanly on an OS X system.
Some systems have zlib.h installed in /usr/include/. This isn't the
desired file for u-boot code - we want the one in include/zlib.h.
This rename will avoid the conflict.
Implement watchodg-aware variants of hash calculation functions:
- crc32_wd()
- md5_wd()
- sha1_csum_wd()
The above functions calculate the hash of the input buffer in chunks,
triggering the watchdog after processing each chunk. The chunk size
is given as a function call parameter.
Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
Some systems have md5.h installed in /usr/include/. This isn't the
desired file (we want the one in include/md5.h). This will avoid the
conflict. This fixes the host tools building problem by creating a new
directory for U-Boot specific header files.
[Patch by Andy Fleming, modified to use separate directory by Wolfgang
Denk]
Signed-off-by: Andy Fleming <afleming@freescale.com>
Acked-by: Timur Tabi <timur@freescale.com>
