path: root/include/tsi148.h
2009-07-19Add support for the Tundra TSI148 VME-bridgeReinhard Arlt
From: Reinhard Arlt <reinhard.arlt@esd-electronics.com> This patch adds support for the Tundra TSI148 VME-bridge. It's used on the upcoming esd VME8349 board. Signed-off-by: Reinhard Arlt <reinhard.arlt@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de>
