path: root/include/tsec.h
2008-09-02Add SGMII support to the tsecAndy Fleming
Adds support for configuring the TBI to talk properly with the SerDes. Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Pass in tsec_info struct through tsec_initializeAndy Fleming
The tsec driver contains a hard-coded array of configuration information for the tsec ethernet controllers. We create a default function that works for most tsecs, and allow that to be overridden by board code. It creates an array of tsec_info structures, which are then parsed by the corresponding driver instance to determine configuration. Also, add regs, miiregs, and devname fields to the tsec_info structure, so that we don't need the kludgy "index" parameter. Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02tsec: Move tsec.h to include/Andy Fleming
This is to prepare the way for board code passing in the tsec_info structure Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
