path: root/include/trace.h
2019-07-10trace: do not limit trace buffer to 2GiBHeinrich Schuchardt
There is no good reason to limit the trace buffer to 2GiB on a 64bit system. Adjust the types of the relevant parameters. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-01-12common/board_f.c: fix compile error when tracing disabledKevin Hilman
When CONFIG_TRACE is disabled, linking fails with: common/built-in.o:(.data.init_sequence_f+0x8): undefined reference to `trace_early_init' To fix, wrap trace init calls with #ifdef CONFIG_TRACE. While at it, remove the static inline version of the init call from trace.h as suggested by Simon Glass, since it doesnt work. Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@ti.com> Signed-off-by: Kevin Hilman <khilman@linaro.org> Acked-by: Simon Glass <sjg@chromium.org>
2013-06-26Add trace librarySimon Glass
Add a library which supports tracing of execution using built-in gcc features and a microsecond timer. This can be used to record a list of function which are executed, along with a timestamp for each. Later this information can be sent to the host for processing. Signed-off-by: Simon Glass <sjg@chromium.org>
