path: root/include/tpm-v2.h
2018-12-05tpm: Add non-volatile index attributes needed for v2Simon Glass
Version-2 TPMs support attributes for nvdata. Add definitions to the header file so that clients can use it. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-11-29tpm: Convert to use a device parameterSimon Glass
At present many TPM calls assume there is only one TPM in the system and look up this TPM themselves. This is inconsistent with driver model, which expects all driver methods to have a device parameter. Update the code to correct this. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-09sandbox: tpm: Tidy up enums and return valuesSimon Glass
Use an enum for command values instead of open-coding them. This removes the need for comments. Also make sure the driver returns proper error numbers instead of -1. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-05-25tpm: add PCR authentication commands supportMiquel Raynal
Add support for the TPM2_PCR_SetAuthPolicy and TPM2_PCR_SetAuthValue commands. Change the command file and the help accordingly. Note: These commands could not be tested because the TPMs available do not support them, however they could be useful for someone else. The user is warned by the command help. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-05-25tpm: add TPM2_HierarchyChangeAuth command supportMiquel Raynal
Add support for the TPM2_HierarchyChangeAuth command. Change the command file and the help accordingly. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-05-25tpm: add dictionary attack mitigation commands supportMiquel Raynal
Add support for the TPM2_DictionaryAttackParameters and TPM2_DictionaryAttackLockReset commands. Change the command file and the help accordingly. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-05-25tpm: add TPM2_GetCapability command supportMiquel Raynal
Add support for the TPM2_GetCapability command. Change the command file and the help accordingly. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-05-25tpm: add TPM2_PCR_Read command supportMiquel Raynal
Add support for the TPM2_PCR_Read command. Change the command file and the help accordingly. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-05-25tpm: add TPM2_PCR_Extend command supportMiquel Raynal
Add support for the TPM2_PCR_Extend command. Change the command file and the help accordingly. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-05-25tpm: add TPM2_Clear command supportMiquel Raynal
Add support for the TPM2_Clear command. Change the command file and the help accordingly. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-05-25tpm: add TPM2_SelfTest command supportMiquel Raynal
Add support for the TPM2_Selftest command. Change the command file and the help accordingly. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-05-25tpm: add TPM2_Startup command supportMiquel Raynal
Add support for the TPM2_Startup command. Change the command file and the help accordingly. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-05-25tpm: prepare support for TPMv2.x commandsMiquel Raynal
Choice between v1 and v2 compliant functions is done with the configuration. Create the various files that will receive TPMv2-only code on the same scheme as for the TPMv1 code. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
