Take over the plain 'tpm_...' functions for use by the new TPM API. Rename
all the TPMv1 functions so they are called from the API.
Update the TPMv1 functions so that they are called from the API. Change
existing users to use the tpm1_ prefix so they don't need to go through
the API, which might introduce uncertainty.
Acked-by: Ilias Apalodimas <ilias.apalodimas@linaro.org>
Move this out of the common header and include it only where needed. In
a number of cases this requires adding "struct udevice;" to avoid adding
another large header or in other cases replacing / adding missing header
files that had been pulled in, very indirectly. Finally, we have a few
cases where we did not need to include <asm/global_data.h> at all, so
remove that include.
Move this uncommon header out of the common header.
At present many TPM calls assume there is only one TPM in the system and
look up this TPM themselves. This is inconsistent with driver model, which
expects all driver methods to have a device parameter. Update the code to
correct this.
These are needed for the 2018 version of Chromium OS vboot. Add an
implementation for TPM v1, with v2 to come later.
This driver was originally written against Chromium OS circa 2012. A few
new features have been added. Enhance the TPM driver to match. This mostly
includes a few new messages and properly modelling whether a particular
'space' is present or not.
Use an enum for command values instead of open-coding them. This removes
the need for comments. Also make sure the driver returns proper error
numbers instead of -1.
There are no changes in this commit but a new organization of the code
as follow.
* cmd/ directory:
> move existing code from cmd/tpm.c in cmd/tpm-common.c
> move specific code in cmd/tpm-v1.c
> create a specific header file with generic definitions for
commands only called cmd/tpm-user-utils.h
* lib/ directory:
> move existing code from lib/tpm.c in lib/tpm-common.c
> move specific code in lib/tpm-v1.c
the library itself called lib/tpm-utils.h
* include/ directory:
> move existing code from include/tpm.h in include/tpm-common.h
> move specific code in include/tpm-v1.h
Code designated as 'common' is compiled if TPM are used. Code designated
as 'specific' is compiled only if the right specification has been
selected.
All files include tpm-common.h.
Files in cmd/ include tpm-user-utils.h.
Files in lib/ include tpm-utils.h.
Depending on the specification, files may include either (not both)
tpm-v1.h or tpm-v2.h.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
[trini: Fix a few more cases of tpm.h -> tpm-v1.h, some Kconfig logic]
