path: root/include/timer.h
2020-10-22timer: Return count from timer_ops.get_countSean Anderson
No timer drivers return an error from get_count. Instead of possibly returning an error, just return the count directly. Signed-off-by: Sean Anderson <seanga2@gmail.com> Reviewed-by: Claudiu Beznea <claudiu.beznea@microchip.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-10-22doc: Document timer APISean Anderson
This adds kerneldocs for <timer.h>. I don't know who should maintain doc/api/timer.rst, since the timer subsystem seems to be maintained by SoC maintainers. MAINTAINERS is left un-updated for the moment. Signed-off-by: Sean Anderson <seanga2@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-09-30timer: Add helper for drivers using timebase fallbackSean Anderson
This function is designed to be used when a timer used to be initialized by the cpu (e.g. RISC-V timers), but now is initialized by dm_timer_init. In such a case, the timer may prefer to use the clocks and clock-frequency properties, but should be able to fall back on using the cpu's timebase-frequency. Signed-off-by: Sean Anderson <seanga2@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bin.meng@windriver.com> Reviewed-by: Rick Chen <rick@andestech.com>
2016-02-26timer: Provide an early timerSimon Glass
In some cases the timer must be accessible before driver model is active. Examples include when using CONFIG_TRACE to trace U-Boot's execution before driver model is set up. Enable this option to use an early timer. These functions must be supported by your timer driver: timer_early_get_count() and timer_early_get_rate(). Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-20dm: timer: uclass: add timer init in uclass driver to add timer deviceMugunthan V N
Adding timer init function in timer-uclass driver to create and initialize the timer device on platforms where u-boot,dm-pre-reloc is not used. Since there will be multiple timer devices in the system, adding a tick-timer node in chosen node to know which timer device to be used as tick timer in u-boot. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
2015-12-01dm: timer: Support 64-bit counterBin Meng
There are timers with a 64-bit counter value but current timer uclass driver assumes a 32-bit one. Modify timer_get_count() to ask timer driver to always return a 64-bit counter value, and provide an inline helper function timer_conv_64() to handle the 32-bit/64-bit conversion automatically. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2015-12-01dm: timer: Fix several nitsBin Meng
This changes 'Timer' to 'timer' at several places. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-10-23dm: implement a Timer uclassThomas Chou
Implement a Timer uclass to work with lib/time.c. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Simon Glass <sjg@chromium.org>
