path: root/include/thermal.h
2015-07-26thermal: Fix commentsFabio Estevam
It seems that many comments were copied from the I2C uclass, so adjust the comments for the thermal class. Reported-by: Simon Glass <sjg@chromium.org> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Simon Glass <sjg@chromium.org>
2014-11-21DM: thermal: Add imx thermal DM driverYe.Li
Add a new thermal uclass for thermal sensor and implement the imx thermal driver basing on this uclass. Signed-off-by: Ye.Li <B37916@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
