path: root/include/test/compression.h
2017-12-04test: compression: Convert to unit test frameworkSimon Glass
Adjust this test to use the unit test framework. Drop the two existing commands for running the tests and replace them with a single 'ut compression' command, with sub-commands. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Continue to have ret = run_test_internal(...) in run_test so ret is always initialized] Signed-off-by: Tom Rini <trini@konsulko.com>
