path: root/include/tables_csum.h
2022-04-14Remove duplication of table_compute_checksum functionTom Rini
It seems like there was some merge error when first cleaning up and sharing this function. We have both an inline version of the function in include/tables_csum.h and a non-inline version in lib/tables_csum.c. Rework things so that we only have the non-inline version (due to number of calls, we should not inline this). Fixes: 1befb38b8682 ("x86: Move table csum into separate file") Fixes: 2b445e4d3194 ("x86: Move table csum into separate header") Cc: Alexander Graf <agraf@csgraf.de> Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-18x86: Move table csum into separate headerAlexander Graf
We need the checksum function without all the other table functionality soon, so let's split it out into its own header file. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
