path: root/include/sysreset.h
2018-10-09sysreset: Add a way to find the last resetSimon Glass
We have a method to return the last reset as a string for humans, but not a method that allows it to be used programmatically. Add a new method that returns the last reset as an enum. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-09sysreset: Tidy up a few comments and loggingSimon Glass
Some comments are incorrect or missing pieces. Fix these and use logging to print the error. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-09-18sysreset: Add get_status methodMario Six
It's useful to have the reset status of the SoC printed out during reset (e.g. to learn whether the reset was caused by software or a watchdog). As a first step to implement this, add a get_status method to the sysreset class, which enables the caller to get printable information about the reset status (akin to get_desc in the CPU uclass). Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mario Six <mario.six@gdsys.cc>
2016-05-26Rename reset to sysresetStephen Warren
The current reset API implements a method to reset the entire system. In the near future, I'd like to introduce code that implements the device tree reset bindings; i.e. the equivalent of the Linux kernel's reset API. This controls resets to individual HW blocks or external chips with reset signals. It doesn't make sense to merge the two APIs into one since they have different semantic purposes. Resolve the naming conflict by renaming the existing reset API to sysreset instead, so the new reset API can be called just reset. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
