path: root/include/synopsys/dwcddr21mctl.h
2011-11-09dwcddr21mctl: Synopsys DWC DDR2/1 Memory ControllerMacpaul Lin
Header definitions of Synopsys DWC DDR2/1 Memory Controller. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
