path: root/include/stdio_dev.h
2016-10-23Convert CONFIG_SYS_STDIO_DEREGISTER to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_STDIO_DEREGISTER This option should never be enabled in SPL, so use CONFIG_IS_ENABLED(SYS_STDIO_DEREGISTER) when checking the option. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Re-sync] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-11-05video: Drop DEV_EXT_VIDEO flagBin Meng
DEV_EXT_VIDEO does not have any actual meaning, hence drop it. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-11-05video: Drop DEV_FLAGS_SYSTEM flagBin Meng
DEV_FLAGS_SYSTEM does not have any actual meaning, hence drop it. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-03-05stdio: extend "name" to 32 symbolsAlexey Brodkin
With limit of 16 symbols very simple device names derived drom device tree description could not be displayed correctly. For example "serial0@0xc0fc1000" will be truncated to sensless "serial0@0xc0fc10" - note dropped tariling zeros. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-10-06stdio: Add force parameter to stdio_deregisterHans de Goede
In some cases we really want to move forward with a deregister, add a force parameter to allow this, and replace the dev with a nulldev in this case. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-09-10dm: Make driver model available before board_init()Simon Glass
For some boards board_init() will change GPIOs, so we need to have driver model available before then. Adjust the board init to arrange this, but enable it for driver model only, just to be safe. This does create additional #ifdef logic, but it is safer than trying to make a pervasive change which may cause some boards to break. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-07-23stdio: Provide functions to add/remove devices using stdio_devSimon Glass
The current functions for adding and removing devices require a device name. This is not convenient for driver model, which wants to store a pointer to the relevant device. Add new functions which provide this feature and adjust the old ones to call these. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-07-23stdio: Pass device pointer to stdio methodsSimon Glass
At present stdio device functions do not get any clue as to which stdio device is being acted on. Some implementations go to great lengths to work around this, such as defining a whole separate set of functions for each possible device. For driver model we need to associate a stdio_dev with a device. It doesn't seem possible to continue with this work-around approach. Instead, add a stdio_dev pointer to each of the stdio member functions. Note: The serial drivers have the same problem, but it is not strictly necessary to fix that to get driver model running. Also, if we convert serial over to driver model the problem will go away. Code size increases by 244 bytes for Thumb2 and 428 for PowerPC. 22: stdio: Pass device pointer to stdio methods arm: (for 2/2 boards) all +244.0 bss -4.0 text +248.0 powerpc: (for 1/1 boards) all +428.0 text +428.0 Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Marek Vasut <marex@denx.de> Reviewed-by: Marek Vasut <marex@denx.de>
2013-08-13serial: arm_dcc: Remove stdio structure supportJagannadha Sutradharudu Teki
Removed stdio structure ops support on arm_dcc driver, and need to register with serial core so-that it can access like remianing serial drivers. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-02-04serial: arm_dcc: Remove CONFIG_ARM_DCC_MULTI optionMichal Simek
CONFIG_ARM_DCC_MULTI should be also removed in the patch "serial: Remove CONFIG_SERIAL_MULTI from serial drivers" (sha1: a3827250606895ec2dd4b8d867342b7cabf3692f) Because the driver defines serial_* functions which cause conflict with serial.c (multiple definition of serial_*) Removing CONFIG_SERIAL_MULTI function also require to define default_serial_console for cases where another serial driver is not available in the system. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Marek Vasut <marex@denx.de>
2012-11-30x86: Add CBMEM console driver for corebootVadim Bendebury
This patch builds upon the recently introduced CBMEM console feature of coreboot. CBMEM console uses a memry area allocated by coreboot to store the console output. The memory area has a certain structure, which allows to determine where the buffer is, the buffer size and the location of the pointer in the buffer. This allows different phases of the firmware (rom based coreboot, ram based coreboot, u-boot after relocation with this change) to keep adding text to the same buffer. Note that this patch introduces a new console driver and adds the driver to the list of drivers to be used for console output, i.e. it engages only after u-boot relocates. Usiong CBMEM console for capturing the pre-relocation console output will be done under a separate change. >From Linux, run the cbmem.py utility (which is a part of the coreboot package) to see the output, e.g.: vvvvvvvvvvvvvvvvv SCSI: AHCI 0001.0300 32 slots 6 ports ? Gbps 0xf impl SATA mode flags: 64bit ilck stag led pmp pio ... Magic signature found Kernel command line: "cros_secure quiet loglevel=1 console=tty2... ^^^^^^^^^^^^^^^^^ Note that the entire u-boot output fits into the buffer only if the coreboot log level is reduced from the most verbose. Ether the buffer size will have to be increased, or the coreboot verbosity permanently reduced. Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2011-06-22ARM: drop unsupported 'trab' boardWolfgang Denk
The 'trab' board configuration is broken, and there is nobody who is interested and willing to fix it. Drop it. This includes support for VFD displays which have always been used by this board only. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-11-28stdio: constify "name" arg in public apiMike Frysinger
2009-07-19console: unify printing current devicesJean-Christophe PLAGNIOL-VILLARD
Create stdio_print_current_devices() for this purpose Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-07-18stdio/device: rework function naming conventionJean-Christophe PLAGNIOL-VILLARD
So far the console API uses the following naming convention: ======Extract====== typedef struct device_t; int device_register (device_t * dev); int devices_init (void); int device_deregister(char *devname); struct list_head* device_get_list(void); device_t* device_get_by_name(char* name); device_t* device_clone(device_t *dev); ======= which is too generic and confusing. Instead of using device_XX and device_t we change this into stdio_XX and stdio_dev This will also allow to add later a generic device mechanism in order to have support for multiple devices and driver instances. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Edited commit message. Signed-off-by: Wolfgang Denk <wd@denx.de>
