path: root/include/status_led.h
2019-12-02status_led: Tidy up the code styleSimon Glass
There are a few whitespace problems with this code. Tidy them up. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-06-16powerpc, 5xxx, 512x: remove support for mpc5xxx and mpc512xHeiko Schocher
There was for long time no activity in the mpx5xxx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in mpc5xxx, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-12powerpc, 8xx: remove support for 8xxHeiko Schocher
There was for long time no activity in the 8xx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in 8xx, so remove it (with a heavy heart, knowing that I remove here the root of U-Boot). Signed-off-by: Heiko Schocher <hs@denx.de>
2017-01-21status_led: Kconfig migrationUri Mashiach
Move all of the status LED feature to drivers/led/Kconfig. The LED status definitions were moved from the board configuration files to the defconfig files. TBD: Move all of the definitions in the include/status_led.h to the relevant board's defconfig files. Tested boards: CL-SOM-AM57x, CM-T335 Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il>
2015-10-24allow LED initialization without STATUS_LED_BOOTBernhard Nortmann
For current U-Boot to initialize status LEDs via status_led_init(), it is required to have both CONFIG_STATUS_LED and STATUS_LED_BOOT defined. This may be a particular concern with GPIO LEDs, where __led_init() is required to correctly set up the GPIO (gpio_request and gpio_direction_output). Without STATUS_LED_BOOT the initialization isn't called, which could leave the user with a non-functional "led" command - due to the fact that the LED routines in gpio_led.c use gpio_set_value() just fine, but the GPIO never got set up properly in the first place. I think having CONFIG_STATUS_LED is sufficient to justify a corresponding call to status_led_init(), even with no STATUS_LED_BOOT defined. To do so, common/board_r.c needs call that routine, so it now is exposed via status_led.h. Signed-off-by: Bernhard Nortmann <bernhard.nortmann@web.de> [trini: Add dummy __led_init to pca9551_led.c] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-09-02powerpc: mpc5xx: remove cmi_mpc5xx supportMasahiro Yamada
This has not been converted to Generic Board, so should be removed. (See doc/README.generic-board for details.) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-04-23cmd_led: Extend led command to support blinking and more ledsStefan Roese
This patch extends the U-Boot "led" command to support automatic blinking by setting a blink frequency in milliseconds. Additionally the number of supported LEDs is increased to 6 (0...5). This will be used by the PCA9551 LED driver. Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-01-05mpc8xx: remove IVMS8, IVML24 board supportMasahiro Yamada
This board is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de>
2015-01-05mpc8xx: remove NETVIA board supportMasahiro Yamada
This board is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Pantelis Antoniou <panto@intracom.gr>
2015-01-05mpc8xx: remove KUP4X, KUP4K board supportMasahiro Yamada
These boards are still non-generic boards. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Klaus Heydeck <heydeck@kieback-peter.de>
2014-10-27ppc: Zap ICU862 boardMarek Vasut
This board is the only user of CONFIG_SYS_EEPROM_X40430 , remove it so the EEPROM command code can be cleansed of the related code as well. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Heiko Schocher <hs@denx.de>
2014-08-21powerpc: mpc8xx: remove GEN860T, GEN806T_SC board supportMasahiro Yamada
These boards have been orphaned for a while and old enough. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-08-21powerpc: mpc8xx: remove svm_sc8xx boardMasahiro Yamada
This board has been orphaned for a while and old enough. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-08-21powerpc: mpc8xx: remove stxxtc board supportMasahiro Yamada
2014-07-18common: board_f: cosmetic use __weak for ledsJeroen Hofstee
First of all this looks a lot better, but it also prevents a gcc warning (W=1), that the weak function has no previous prototype. cc: Simon Glass <sjg@chromium.org> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl> Acked-by: Simon Glass <sjg@chromium.org>
2014-07-07mpc8xx: remove netta, netta2, netphone board supportMasahiro Yamada
These boards are old enough and have no maintainers. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-07-07mpc8xx: remove rbc823 board supportMasahiro Yamada
This board is old enough and has no maintainer. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2012-11-10nios2: remove asm/status_led.hThomas Chou
The file has a wrong inline keyword of __led_toggle(), which causes compilation error. And its content is defined in common status_led.h. So define CONFIG_BOARD_SPECIFIC_LED in board config files and remove this header file. Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2012-10-28PPC: remove dead boards (AMX860, c2mon, ETX094, IAD210, LANTEC, SCM)Wolfgang Denk
These boards have long reached EOL, and there has been no indication of any active users of such hardware for years. Get rid of the dead weight. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Wolfgang Grandegger <wg@denx.de>
2011-10-01sbc82xx: delete support for obsolete SBC8240/SBC8260Paul Gortmaker
The EST SBC8260 is over 10 years old, and the SBC8240 older than that. With the tiny amount of RAM (by today's standards), there really isn't anyone interested in running the latest U-boot on these EOL products anymore. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> CC: jon.diekema@smiths-aerospace.com
2011-09-13led: remove camel casing of led identifiers globallyJason Kridner
Result of running the following command to address Wolfgang's comment about camel case: for file in `find . | grep '\.[chS]$'`; do perl -i -pe 's/(green|yellow|red|blue)_LED_(on|off)/$1_led_$2/g' $file; done Discussion: http://patchwork.ozlabs.org/patch/84988/ Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Signed-off-by: Joel A Fernandes <agnel.joel@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-10-06CCM: remove code for yet another corpseWolfgang Denk
The CCM board has long reached EOL, and support for it is no longer relevant in current versions of U-Boot. Remove it. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-10-06PCU_E: remove code for yet another corpseWolfgang Denk
The PCU_E board has long reached EOL, and support for it is no longer relevant in current versions of U-Boot. Remove it. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-19Remove HMI10 board supportWolfgang Denk
Recent changes caused that the HMI10 board now is included in the boards built by MAKEALL, which revealed that compilation for this board has been broken for a long time: ps2ser.c: In function 'ps2ser_init': ps2ser.c:155: error: 'UART_LCR' undeclared (first use in this function) ps2ser.c:155: error: (Each undeclared identifier is reported only once ps2ser.c:155: error: for each function it appears in.) ps2ser.c:156: error: 'UART_DLL' undeclared (first use in this function) ps2ser.c:157: error: 'UART_DLM' undeclared (first use in this function) ps2ser.c:159: error: 'UART_IER' undeclared (first use in this function) ps2ser.c:160: error: 'UART_MCR' undeclared (first use in this function) ps2ser.c:161: error: 'UART_FCR' undeclared (first use in this function) ps2ser.c:162: error: 'UART_FCR_ENABLE_FIFO' undeclared (first use in this function) ps2ser.c:166: error: 'UART_LSR' undeclared (first use in this function) ps2ser.c: In function 'ps2ser_putc': ps2ser.c:198: error: 'UART_LSR' undeclared (first use in this function) ps2ser.c:200: error: 'UART_TX' undeclared (first use in this function) ps2ser.c: In function 'ps2ser_getc_hw': ps2ser.c:224: error: 'UART_LSR' undeclared (first use in this function) ps2ser.c:225: error: 'UART_RX' undeclared (first use in this function) ps2ser.c: In function 'ps2ser_interrupt': ps2ser.c:293: error: 'UART_IIR' undeclared (first use in this function) The board is orphaned, and AFAICT has reached EOL. Drop support for it. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-07-05Blackfin: back out status_led.h stubsMike Frysinger
When boards define CONFIG_BOARD_SPECIFIC_LED, the common led definitions are OK for Blackfin boards. So switch the few boards using these over to the common code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-12ARM Add blue colour LED to status_led.Tom Rix
There is exiting support for red,yellow,green but no blue. The main LED on the zoom2 is a blue LED. Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-01-28Blackfin: implement general support for CONFIG_STATUS_LEDMike Frysinger
Here are the Blackfin-specific and board-independent pieces for status leds. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2007-10-13Coding Style cleanup.Wolfgang Denk
2007-09-18Move coloured led API to status_led.hPeter Pearse
Improve indentation in drivers/at45.c
2007-06-22[PCS440EP] upgrade the PCS440EP board:Heiko Schocher
- Show on the Status LEDs, some States of the board. - Get the MAC addresses from the EEProm - use PREBOOT - use the CF on the board. - check the U-Boot image in the Flash with a SHA1 checksum. - use dynamic TLB entries generation for the SDRAM Signed-off-by: Heiko Schocher <hs@denx.de>
2007-05-27Motion-PRO: Add LED support.Bartlomiej Sieka
Signed-off-by: Jan Wrobel <wrr@semihalf.com> Signed-off-by: Marian Balakowicz <m8@semihalf.com> Acked-by: Bartlomiej Sieka <tur@semihalf.com>
2006-10-13Preliminary patch adding support for the MarelV38B board.Bartlomiej Sieka
2005-08-15Add support for Silicon Turnkey eXpress XTc (mpc87x/88x) board.Wolfgang Denk
Patch by Dan Malek and Pantelis Antoniou, 15 Aug 2005
2004-10-10Patches by Scott McNutt, 24 Aug 2004:wdenk
- Add support for Altera Nios-II processors. - Add support for Psyent PCI-5441 board. - Add support for Psyent PK1C20 board.
2004-07-10* Rename SBC8560 into sbc8560 for consistencywdenk
* Patch by Daniel Poirot, 24 Jun 2004: Add support for Wind River's sbc8240 board * Patches by Yasushi Shoji, 26 Jun 2004: - drivers/serial_xuartlite.c: fix "return 0" in void function - add microblaze support to mkimage tool
2004-06-07Patch by Pantelis Antoniou, 5 May 2004:wdenk
- Intracom board update. - Add Codec POST.
2004-04-15* Patches by Pantelis Antoniou, 30 Mar 2004:wdenk
- add auto-complete support to the U-Boot CLI - add support for NETTA and NETPHONE boards; fix NETVIA board * Patch by Yuli Barcohen, 28 Mar 2004: - Add support for MPC8272 family including MPC8247/8248/8271/8272 - Add support for MPC8272ADS evaluation board (another flavour of MPC8260ADS) - Change configuration method for MPC8260ADS family
2004-03-25* Patch by Klaus Heydeck, 13 Mar 2003:wdenk
Add support for KUP4X Board
2004-03-13* Patch by Rune Torgersen, 27 Feb 2004:wdenk
- Added LBA48 support (CONFIG_LBA48 & CFG_64BIT_LBA) - Added support for 64bit printing in vsprintf (CFG_64BIT_VSPRINTF) - Added support for 64bit strtoul (CFG_64BIT_STRTOUL) * Patch by Masami Komiya, 27 Feb 2004: Fix rarpboot: add autoload by NFS * Patch by Dan Eisenhut, 26 Feb 2004: fix flash_write return value in saveenv * Patch by Stephan Linz, 11 Dec 2003 expand config.mk to avoid trigraph warnings on NIOS * Rename "BMS2003" board into "HMI10"
2004-01-04* Make BMS2003 use a separate config file to avoid #ifdef mess;wdenk
add I2C support; add support for DS1337 RTC * Add CompactFlash support for BMS2003 board * Add support for status LED on BMS2003 board
2003-06-26* Patches by Robert Schwebel, 26 Jun 2003:U-Boot-0_4_0wdenk
- logdl - csb226 - innokom * Patch by Pantelis Antoniou, 25 Jun 2003: update NetVia with V2 board support
2003-06-19* Patches by David Müller, 12 Jun 2003:wdenk
- rewrite of the S3C24X0 register definitions stuff - "driver" for the built-in S3C24X0 RTC * Patches by Yuli Barcohen, 12 Jun 2003: - Add MII support and Ethernet PHY initialization for MPC8260ADS board - Fix incorrect SIUMCR initialisation caused by wrong Hard Reset configuration word supplied by FPGA on some MPC8260ADS boards * Patch by Pantelis Antoniou, 10 Jun 2003: Unify status LED interface
2003-06-03* Patches by Udi Finkelstein, 2 June 2003:LABEL_2003_06_04_0200wdenk
- Added support for custom keyboards, initialized by defining a board-specific drv_keyboard_init as well as defining CONFIG_KEYBOARD . - Added support for the RBC823 board. - cpu/mpc8xx/lcd.c now automatically calculates the Horizontal Pixel Count field. * Fix alignment problem in BOOTP (dhcp_leasetime option) [pointed out by Nicolas Lacressonnière, 2 Jun 2003] * Patch by Mark Rakes, 14 May 2003: add support for Intel e1000 gig cards. * Patch by Nye Liu, 3 Jun 2003: fix critical typo in MAMR definition (include/mpc8xx.h) * Fix requirement to align U-Boot image on 16 kB boundaries on PPC. * Patch by Klaus Heydeck, 2 Jun 2003 Minor changes for KUP4K configuration
2003-05-03* Add support for Promess ATC boardLABEL_2003_05_03_1700wdenk
* Patch by Keith Outwater, 28 Apr 2003: - Miscellaneous corrections and additions to GEN860T board specific code. - Added GEN860_SC variant to GEN860T. - Miscellaneous corrections to GEN860T documentation. - Correct duplicate entry in U-Boot CREDITS file. - Add GEN860T_SC entry in MAINTAINERS file. - Update CREDITS file with GEN860T_SC info. * Update Smiths Aerospace addresses in MAINTAINERS file * Fix error handling in hush's version of "run" command
2003-03-31* Patch by Martin Winistoerfer, 23 Mar 2003wdenk
- Add port to MPC555/556 microcontrollers - Add support for cmi customer board with Intel 28F128J3A, 28F320J3A or 28F640J3A flash. * Patch by Rick Bronson, 28 Mar 2003: - fix common/cmd_nand.c
2003-03-26* Patch by Rick Bronson, 16 Mar 2003:wdenk
Add support for Atmel AT91RM9200DK w/NAND * Patches by Robert Schwebel, 19 Mar 2003: - use arm-linux-gcc as default compiler for ARM - fix i2c fixup code - fix missing baudrate setting - added $loadaddr / CFG_LOAD_ADDR support to loadb - moved "ignoring trailing characters" _before_ u-boot wants to print out diagnostics messages; removes bogus characters at the end of transmission * Patch by John Zhan, 18 Mar 2003: Add support for SinoVee Microsystems SC8xx boards * Patch by Rolf Offermanns, 21 Mar 2003: ported the dnp1110 related changes from the current armboot cvs to current u-boot cvs. smc91111 does not work. problem marked in smc91111.c, grep for "FIXME". * Patch by Brian Auld, 25 Mar 2003: Add support for STM flash chips on ebony board * Add PCI support for MPC8250 Boards (PM825 module) * Patch by Stefan Roese, 25 Mar 2003:
