path: root/include/splash.h
2016-07-26splash: Introduce default_splash_locationsAlexey Brodkin
This change introduces default_splash_locations which simplifies splash recovery from the first partition of USB/MMC/SATA drive. Given usual mapping of the first partition of external media for basic boot stuff like uImage/zImage, .dtb etc it looks quite obvious option to put there splash.bmp as well. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Simon Glass <sjg@chromium.org> Cc: Jeroen Hofstee <jeroen@myspectrum.nl> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2016-06-14splash_source: add support for ubifs formatted nandEran Matityahu
Add support for loading splash image from NAND Flash formatted with a (UBI) filesystem. Signed-off-by: Eran Matityahu <eran.m@variscite.com> Cc: Heiko Schocher <hs@denx.de> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Tom Rini <trini@konsulko.com> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Nikita Kiryanov <nikita@compulab.co.il>
2015-11-16splash_source: add support for filesystem formatted sataNikita Kiryanov
Add support for loading splashimage from filesystem formatted sata storage. Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Tom Rini <trini@konsulko.com> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2015-11-16splash_source: add support for filesystem formatted usbNikita Kiryanov
Add support for loading splash image from USB drive formatted with a filesystem. Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Tom Rini <trini@konsulko.com> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2015-11-16splash_source: add support for filesystem formatted mmcNikita Kiryanov
Add support for loading splash image from an SD card formatted with a filesystem. Update boards to maintain original behavior where needed. Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Tom Rini <trini@konsulko.com> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2015-02-10Merge branch 'master' of git://git.denx.de/u-boot-videoTom Rini
Conflicts: include/splash.h Signed-off-by: Tom Rini <trini@ti.com>
2015-02-10lcd: split splash code into its own functionNikita Kiryanov
lcd_logo() currently performs tasks well beyond just displaying the logo. It has code which displays splash image, it has logic which determines when the different display features are displayed, and it is coupled with the lcd console because it holds the responsibility of returning the lcd console base address. Make lcd_logo() just about the logo by: * Moving splash image display code into a dedicated function * Moving the logic regarding when various features are displayed to lcd_clear() (which is arguably not the correct name for housing such code either, but it is currently the most fitting location code wise) * Move the responsibility of setting the console base address to lcd_clear() too. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Bo Shen <voice.shen@atmel.com> Tested-by: Josh Wu <josh.wu@atmel.com> Cc: Bo Shen <voice.shen@atmel.com> Cc: Simon Glass <sjg@chromium.org> Cc: Anatolij Gustschin <agust@denx.de>
2015-01-29common: convert compulab splash load code to common codeNikita Kiryanov
Move board/compulab/common/splash.c code to common/splash_source.c to make it available for everybody. This move renames cl_splash_screen_prepare() to splash_source_load(), and the compilation of this code is conditional on CONFIG_SPLASH_SOURCE. splash_source features: * Provide a standardized way for declaring board specific splash screen locations * Provide existing routines for auto loading the splash image from the locations as declared by the board * Introduce the "splashsource" environment variable, which makes it possible to select the splash image source. cm-t35 and cm-fx6 are updated to use the modified version. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Anatolij Gustschin <agust@denx.de> Reviewed-by: Tom Rini <trini@ti.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2013-07-08video: consolidate splash screen alignment codeAnatolij Gustschin
Code for checking "splashpos" environment variable is duplicated in drivers, move it to the common function. Call this function also in the bmp display command to consider "splashpos" settings. Signed-off-by: Anatolij Gustschin <agust@denx.de> Acked-by: Otavio Salvador <otavio@ossystems.com.br>
2013-07-01video: lcd: Add CONFIG_SPLASH_SCREEN_PREPARE support to CONFIG_VIDEORobert Winkler
Create splash.c/h to put the function and any future common splash screen code in. Signed-off-by: Robert Winkler <robert.winkler@boundarydevices.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
