path: root/include/spi.h
2019-04-12dm: spi: Read default speed and mode values from DTPatrick Delaunay
This patch update the behavior introduced by commit 96907c0fe50a ("dm: spi: Read default speed and mode values from DT") In case of DT boot, don't read default speed and mode for SPI from CONFIG_* but instead read from DT node. This will make sure that boards with multiple SPI/QSPI controllers can be probed at different bus frequencies and SPI modes. Remove also use in boards of the value speed=0 (no more supported) for ENV in SPI by using CONFIG_ENV_SPI_MAX_HZ=0. DT values will be always used when available (full DM support of SPI slave with available DT node) even if speed and mode are requested; for example in splash screen support (in splash_sf_read_raw) or in SPL boot (in spl_spi_load_image). The caller of spi_get_bus_and_cs() no more need to force speed=0. But the current behavior don't change if the SPI slave is not present (device with generic driver is created automatically) or if platdata is used (CONFIG_OF_PLATDATA). Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Acked-by: Jagan Teki <jagan@amarulasolutions.com>
2018-11-27spi: Remove unused spi_initJagan Teki
Remove spi_init definition which never used on respective code since from many years. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2018-09-20spi: Extend the core to ease integration of SPI memory controllersBoris Brezillon
Some controllers are exposing high-level interfaces to access various kind of SPI memories. Unfortunately they do not fit in the current spi_controller model and usually have drivers placed in drivers/mtd/spi-nor which are only supporting SPI NORs and not SPI memories in general. This is an attempt at defining a SPI memory interface which works for all kinds of SPI memories (NORs, NANDs, SRAMs). Signed-off-by: Boris Brezillon <boris.brezillon@bootlin.com> Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Acked-by: Jagan Teki <jagan@openedev.com>
2018-01-24spi: Remove spi_setup_slave_fdtMario Six
A previous patch removed the spi_flash_probe_fdt function, which contained the last call of the spi_setup_slave_fdt function, which is now equally obsolete. This patch removes the function. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jagan@openedev.com> Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-01-24spi: Remove obsolete spi_base_setup_slave_fdtMario Six
0efc024 ("spi_flash: Add spi_flash_probe_fdt() to locate SPI by FDT node") added a helper function spi_base_setup_slave_fdt to to set up a SPI slave from a given FDT blob. The only user was the exynos SPI driver. But commit 73186c9 ("dm: exynos: Convert SPI to driver model") removed the use of this function, hence rendering it obsolete. Remove this function, as well as the CONFIG_OF_SPI option, which guarded only this function. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jagan@openedev.com> Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-01-24drivers: spi: consider command bytes when sending transfersÁlvaro Fernández Rojas
Command bytes are part of the written bytes and they should be taken into account when sending a spi transfer. Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-01-24drivers: spi: allow limiting readsÁlvaro Fernández Rojas
For some SPI controllers it's not possible to keep the CS active between transfers and they are limited to a known number of bytes. This splits spi_flash reads into different iterations in order to respect the SPI controller limits. Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-11-21spi: Zap unneeded optionJagan Teki
option from spi_slave {} never used so drop the same. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2017-06-01dm: spi: Convert uclass to livetreeSimon Glass
Update the SPI uclass to support a live device tree. Also adjust spi_slave_ofdata_to_platdata() to accept a device instead of a blob and offset. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-11-19spi: Remove dual flash options/flagsJagan Teki
Dual flash code in spi are usually take the spi controller to work with dual connected flash devices. Usually these dual connection operation's are referred to flash controller protocol rather with spi controller protocol, these are still present in flash side for the usage of spi-nor controllers. So, this patch remove the dual_flash options or flags in sf which are triggered from spi controller side. Cc: Bin Meng <bmeng.cn@gmail.com> Cc: York Sun <york.sun@nxp.com> Cc: Vignesh R <vigneshr@ti.com> Cc: Mugunthan V N <mugunthanvnm@ti.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Jagan Teki <jagan@openedev.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jagan@openedev.com>
2016-09-22spi: Remove SPI_RX_FASTJagan Teki
Removed SPI_RX_FAST since default read for spi slaves are always 1-wire fast read. Cc: Simon Glass <sjg@chromium.org> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Cc: Vignesh R <vigneshr@ti.com> Cc: Mugunthan V N <mugunthanvnm@ti.com> Signed-off-by: Jagan Teki <jteki@openedev.com>
2016-09-22spi: Use mode for rx mode flagsJagan Teki
Make rx mode flags as generic to spi, earlier mode_rx is maintained separately because of some flash specific code. Cc: Simon Glass <sjg@chromium.org> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Cc: Vignesh R <vigneshr@ti.com> Cc: Mugunthan V N <mugunthanvnm@ti.com> Signed-off-by: Jagan Teki <jteki@openedev.com>
2016-05-17dm: spi: introduce dm apiPeng Fan
Introduce dm_spi_claim_bus, dm_spi_release_bus and dm_spi_xfer Convert spi_claim_bus, spi_release_bus and spi_xfer to use the new API. Signed-off-by: Peng Fan <van.freenix@gmail.com> Cc: Simon Glass <sjg@chromium.org> Cc: Jagan Teki <jteki@openedev.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-01-13spi: Add support for dual and quad modeMugunthan V N
spi bus can support dual and quad wire data transfers for tx and rx. So defining dual and quad modes for both tx and rx. Also add support to parse bus width used for spi tx and rx transfers. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Jagan Teki <jteki@openedev.com> Signed-off-by: Jagan Teki <jteki@openedev.com>
2016-01-13spi: Add SPI_TX_DUAL modeJagan Teki
Added SPI_TX_DUAL mode flag. Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Mugunthan V N <mugunthanvnm@ti.com> Tested-by: Jagan Teki <jteki@openedev.com> Signed-off-by: Jagan Teki <jteki@openedev.com>
2016-01-13sf: Make IO modes at last in read modesJagan Teki
SLOW, FAST, DUAL, DUAL_IO, QUAD, QUAD_IO changed order to SLOW, FAST, DUAL, QUAD, DUAL_IO, QUAD_IO Cc: Simon Glass <sjg@chromium.org> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Tested-by: Jagan Teki <jteki@openedev.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Jagan Teki <jteki@openedev.com>
2016-01-13spi: Minor cleanupJagan Teki
- Add comments on mode_rx - Tab space's Cc: Simon Glass <sjg@chromium.org> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Tested-by: Mugunthan V N <mugunthanvnm@ti.com> Tested-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Jagan Teki <jteki@openedev.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Jagan Teki <jteki@openedev.com>
2016-01-13spi: Use BIT macroJagan Teki
Used BIT macro like 1 << nr as BIT(nr) where nr is 0...n Cc: Simon Glass <sjg@chromium.org> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Tested-by: Mugunthan V N <mugunthanvnm@ti.com> Tested-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Jagan Teki <jteki@openedev.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Jagan Teki <jteki@openedev.com>
2016-01-13spi: Fix bit assignment with flagsJagan Teki
Fixed bit assignment with flags members on spi_slave{} Cc: Simon Glass <sjg@chromium.org> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Tested-by: Mugunthan V N <mugunthanvnm@ti.com> Tested-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Jagan Teki <jteki@openedev.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Jagan Teki <jteki@openedev.com>
2016-01-13spi: Move flags macro's to spi_slave{} membersJagan Teki
This patch moves flags macro's to respective member position on spi_slave{}, for better readabilty and finding the respective member macro's easily. Cc: Simon Glass <sjg@chromium.org> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Tested-by: Mugunthan V N <mugunthanvnm@ti.com> Tested-by: Jagan Teki <jteki@openedev.com> Signed-off-by: Jagan Teki <jteki@openedev.com>
2016-01-13spi: Rename op_mode_rx to mode_rxJagan Teki
Since spi rx mode macro's are renamed to simple and meaninfull, this patch will rename the respective structure members. Cc: Simon Glass <sjg@chromium.org> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Tested-by: Mugunthan V N <mugunthanvnm@ti.com> Tested-by: Jagan Teki <jteki@openedev.com> Signed-off-by: Jagan Teki <jteki@openedev.com>
2016-01-13spi: Rename SPI_OPM_RX_* to SPI_RX_*Jagan Teki
SPI_OPM_RX_AS - SPI_RX_SLOW SPI_OPM_RX_AF - SPI_RX_FAST SPI_OPM_RX_DOUT - SPI_RX_DUAL SPI_OPM_RX_QOF - SPI_RX_QUAD Cc: Simon Glass <sjg@chromium.org> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Tested-by: Mugunthan V N <mugunthanvnm@ti.com> Tested-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Jagan Teki <jteki@openedev.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Jagan Teki <jteki@openedev.com>
2016-01-13spi: Remove SPI_OPM_RX_DIO|QIOFJagan Teki
SPI_OPM_RX_DIO and SPI_OPM_RX_QIOF are rx IO commands/opmodes for dual and quad. Usually IO operation's are referred to flash protocol rather with spi controller protocol, these are still present in flash side for the usage of spi-nor controllers. Cc: Simon Glass <sjg@chromium.org> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Tested-by: Mugunthan V N <mugunthanvnm@ti.com> Tested-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Jagan Teki <jteki@openedev.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Jagan Teki <jteki@openedev.com>
2016-01-13spi: Remove SPI_OPM_RX_EXTNJagan Teki
SPI_OPM_RX_EXTN is a combination of all rx opmode's and spi driver shall use any one of the rx mode at a time not the combination and it is true in case of flash where spi_flash_table mention combination of supported read opmodes so-that the required one will pick based on the rx mode from spi driver. Cc: Simon Glass <sjg@chromium.org> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Tested-by: Mugunthan V N <mugunthanvnm@ti.com> Tested-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Jagan Teki <jteki@openedev.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Jagan Teki <jteki@openedev.com>
2016-01-13spi: Rename SPI_TX_BP|QPP to SPI_TX_BYTE|QUADJagan Teki
Since SPI_TX_* are spi_slave{} members so use spi protocol notation instead spi flash programming, like SPI_TX_BP => SPI_TX_BYTE SPI_TX_QPP => SPI_TX_QUAD Cc: Simon Glass <sjg@chromium.org> Tested-by: Jagan Teki <jteki@openedev.com> Tested-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Jagan Teki <jteki@openedev.com>
2016-01-13spi: Use mode instead of op_mode_txJagan Teki
Used mode member from spi_slave{} instead of op_mode_tx. Cc: Simon Glass <sjg@chromium.org> Tested-by: Jagan Teki <jteki@openedev.com> Tested-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Jagan Teki <jteki@openedev.com>
2016-01-13spi: make mode visible to both dm and non-dmJagan Teki
Couldn't find the exact reason to define 'mode' for dm, probably it is not using in non-dm drivers but it need to visible both dm and non-dm as mode data is getting dereferred in spi flash core ie common to both. Cc: Simon Glass <sjg@chromium.org> Tested-by: Jagan Teki <jteki@openedev.com> Tested-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Jagan Teki <jteki@openedev.com>
2015-10-23dm: Rename dev_get_parentdata() to dev_get_parent_priv()Simon Glass
The current name is inconsistent with other driver model data access functions. Rename it and fix up all users. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2015-08-17sf: ops: Add spi_flash_copy_mmap functionTom Rini
When doing a memory mapped copy we may have DMA available and thus need to have this copy abstracted so that the driver can do it, rather than a simple memcpy. Signed-off-by: Tom Rini <trini@ti.com> Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-07-01spi/sf: Minor cleanupsJagan Teki
- Adjust tab spaces - Add comments Signed-off-by: Jagan Teki <jteki@openedev.com>
2015-05-05dm: spi: Correct the comment on spi_get_ops()Simon Glass
This comment should refer to SPI, not serial. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
2015-05-05dm: spi: Avoid setting the speed with every transferSimon Glass
Only set the speed if it has changed from last time. Since the speed will be 0 when the device is probed it will always be changed on the first transfer after the device is probed. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-23dm: spi: Correct SPI claim/release_bus() methodsSimon Glass
These methods should be passed a slave device, not a bus. This matches the old SPI interface. It is important to know which device is claiming the bus so passing a bus is not that useful. Reported-by: Haikun Wang <haikun.wang@freescale.com> Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Peng Fan <Peng.Fan@freescale.com> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
2015-04-22sf: Correct the macros as per new array fast read commandSiva Durga Prasad Paladugu
Correct the macros as per insertion of array fast read command CMD_READ_ARRAY_FAST in spi_read_cmds_array in file sf_probe.c Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
2015-01-29dm: spi: Move slave details to child platdataSimon Glass
At present we go through various contortions to store the SPI slave's chip select in its private data. This only exists when the slave is active so must be set up when it is probed. Until the device is probed we don't actually know what chip select it will appear on. However, now that we can support per-child platform data, we can use that instead. This allows us to set up the chip select when the child is bound, and avoid the messy contortions. Unfortunately this is a fairly large change and it seems to be difficult to break it down further. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-12-13sf: Enable byte program supportJagannadha Sutradharudu Teki
Enabled byte program support for sst flashes in sf. Few controllers will only support BP, so this patch gives a tx transfer flag to set the BP so-that sf will operate on byte program transfer. A new TX operation mode SPI_OPM_TX_BP is introduced for such SPI controller to use byte program op for SST flash. Signed-off-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2014-11-22dm: spi: Use device_bind_driver() instead of our own functionSimon Glass
The SPI function does the same thing, so we may as well just use the new generic function. The 'cs' parameter was not actually used, so can be dropped. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com> Acked-by: Heiko Schocher <hs@denx.de>
2014-11-22dm: spi: Correct handling of SPI chip selects in sandboxSimon Glass
This code was not updated when the chip select handling was adjusted. Fix it to call the correct function. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com> Acked-by: Heiko Schocher <hs@denx.de>
2014-10-22dm: sandbox: Add a SPI emulation uclassSimon Glass
U-Boot includes a SPI emulation driver already but it is not explicit, and is hidden in the SPI flash code. Conceptually with sandbox's SPI implementation we have a layer which creates SPI bus transitions and a layer which interprets them, currently only for SPI flash. The latter is actually an emulation, and it should be possible to add more than one emulation - not just SPI flash. Add a SPI emulation uclass so that other emulations can be plugged in to support different types of emulated devices on difference buses/chip selects. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
2014-10-22dm: spi: Add a uclass for SPISimon Glass
Add a uclass which provides access to SPI buses and includes operations required by SPI. For a time driver model will need to co-exist with the legacy SPI interface so some parts of the header file are changed depending on which is in use. The exports are adjusted also since some functions are not available with driver model. Boards must define CONFIG_DM_SPI to use driver model for SPI. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com> (Discussed some follow-up comments which will address in future add-ons)
2014-09-26spi: Add brackets and tidy defines in spi.hSimon Glass
Some of the #defines in spi.h are not bracketed. To avoid future mistakes add brackets. Also add an explanatory comment for SPI_CONN_DUAL_... Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-12sf: Add dual memories support - DUAL_PARALLELJagannadha Sutradharudu Teki
This patch added support for accessing dual memories in parallel connection with single chipselect line from controller. For more info - see doc/SPI/README.dual-flash Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-12sf: Add dual memories support - DUAL_STACKEDJagannadha Sutradharudu Teki
This patch added support for accessing dual memories in stacked connection with single chipselect line from controller. For more info - see doc/SPI/README.dual-flash Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-11sf: Add QUAD_IO_FAST read supportJagannadha Sutradharudu Teki
This patch adds support QUAD_IO_FAST read command. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-11sf: Add quad read/write commands supportJagannadha Sutradharudu Teki
This patch add quad commands support like - QUAD_PAGE_PROGRAM => for write program - QUAD_OUTPUT_FAST ->> for read program Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-11sf: Add extended read commands supportJagannadha Sutradharudu Teki
Current sf uses FAST_READ command, this patch adds support to use the different/extended read command. This implementation will determine the fastest command by taking the supported commands from the flash and the controller, controller is always been a priority. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2013-12-09spi_flash: Add spi_flash_probe_fdt() to locate SPI by FDT nodeSimon Glass
This allows us to put the SPI flash chip inside the SPI interface node, with U-Boot finding the correct bus and chip select automatically. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-11-12spi: define SPI_XFER_ONCENikita Kiryanov
The flag combination "SPI_XFER_BEGIN | SPI_XFER_END" is a common use case of spi_xfer, and it can easily cause an already long line (spi_xfer takes 5 parameters) to go over the 80 character limit. define SPI_XFER_ONCE to be a shorter version of the above flag combination. Cc: Tom Rini <trini@ti.com> Cc: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2013-11-12spi: omap3: add support for more word lengthsNikita Kiryanov
Current implementation only supports 8 bit word lengths, even though omap3 can handle anything between 4 and 32. Update the spi interface to support changing the SPI word length, and implement it in omap3_spi driver to support the full range of possible word lengths. This implementation is backwards compatible by defaulting to the old behavior of 8 bit word lengths. Also, it required a change to the omap3_spi non static I/O functions, but since they are not used anywhere else, no collateral changes are required. Cc: Tom Rini <trini@ti.com> Cc: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
