path: root/include/spi.h
2015-07-01spi/sf: Minor cleanupsJagan Teki
- Adjust tab spaces - Add comments Signed-off-by: Jagan Teki <jteki@openedev.com>
2015-05-05dm: spi: Correct the comment on spi_get_ops()Simon Glass
This comment should refer to SPI, not serial. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
2015-05-05dm: spi: Avoid setting the speed with every transferSimon Glass
Only set the speed if it has changed from last time. Since the speed will be 0 when the device is probed it will always be changed on the first transfer after the device is probed. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-23dm: spi: Correct SPI claim/release_bus() methodsSimon Glass
These methods should be passed a slave device, not a bus. This matches the old SPI interface. It is important to know which device is claiming the bus so passing a bus is not that useful. Reported-by: Haikun Wang <haikun.wang@freescale.com> Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Peng Fan <Peng.Fan@freescale.com> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
2015-04-22sf: Correct the macros as per new array fast read commandSiva Durga Prasad Paladugu
Correct the macros as per insertion of array fast read command CMD_READ_ARRAY_FAST in spi_read_cmds_array in file sf_probe.c Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
2015-01-29dm: spi: Move slave details to child platdataSimon Glass
At present we go through various contortions to store the SPI slave's chip select in its private data. This only exists when the slave is active so must be set up when it is probed. Until the device is probed we don't actually know what chip select it will appear on. However, now that we can support per-child platform data, we can use that instead. This allows us to set up the chip select when the child is bound, and avoid the messy contortions. Unfortunately this is a fairly large change and it seems to be difficult to break it down further. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-12-13sf: Enable byte program supportJagannadha Sutradharudu Teki
Enabled byte program support for sst flashes in sf. Few controllers will only support BP, so this patch gives a tx transfer flag to set the BP so-that sf will operate on byte program transfer. A new TX operation mode SPI_OPM_TX_BP is introduced for such SPI controller to use byte program op for SST flash. Signed-off-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2014-11-22dm: spi: Use device_bind_driver() instead of our own functionSimon Glass
The SPI function does the same thing, so we may as well just use the new generic function. The 'cs' parameter was not actually used, so can be dropped. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com> Acked-by: Heiko Schocher <hs@denx.de>
2014-11-22dm: spi: Correct handling of SPI chip selects in sandboxSimon Glass
This code was not updated when the chip select handling was adjusted. Fix it to call the correct function. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com> Acked-by: Heiko Schocher <hs@denx.de>
2014-10-22dm: sandbox: Add a SPI emulation uclassSimon Glass
U-Boot includes a SPI emulation driver already but it is not explicit, and is hidden in the SPI flash code. Conceptually with sandbox's SPI implementation we have a layer which creates SPI bus transitions and a layer which interprets them, currently only for SPI flash. The latter is actually an emulation, and it should be possible to add more than one emulation - not just SPI flash. Add a SPI emulation uclass so that other emulations can be plugged in to support different types of emulated devices on difference buses/chip selects. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
2014-10-22dm: spi: Add a uclass for SPISimon Glass
Add a uclass which provides access to SPI buses and includes operations required by SPI. For a time driver model will need to co-exist with the legacy SPI interface so some parts of the header file are changed depending on which is in use. The exports are adjusted also since some functions are not available with driver model. Boards must define CONFIG_DM_SPI to use driver model for SPI. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com> (Discussed some follow-up comments which will address in future add-ons)
2014-09-26spi: Add brackets and tidy defines in spi.hSimon Glass
Some of the #defines in spi.h are not bracketed. To avoid future mistakes add brackets. Also add an explanatory comment for SPI_CONN_DUAL_... Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-12sf: Add dual memories support - DUAL_PARALLELJagannadha Sutradharudu Teki
This patch added support for accessing dual memories in parallel connection with single chipselect line from controller. For more info - see doc/SPI/README.dual-flash Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-12sf: Add dual memories support - DUAL_STACKEDJagannadha Sutradharudu Teki
This patch added support for accessing dual memories in stacked connection with single chipselect line from controller. For more info - see doc/SPI/README.dual-flash Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-11sf: Add QUAD_IO_FAST read supportJagannadha Sutradharudu Teki
This patch adds support QUAD_IO_FAST read command. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-11sf: Add quad read/write commands supportJagannadha Sutradharudu Teki
This patch add quad commands support like - QUAD_PAGE_PROGRAM => for write program - QUAD_OUTPUT_FAST ->> for read program Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-11sf: Add extended read commands supportJagannadha Sutradharudu Teki
Current sf uses FAST_READ command, this patch adds support to use the different/extended read command. This implementation will determine the fastest command by taking the supported commands from the flash and the controller, controller is always been a priority. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2013-12-09spi_flash: Add spi_flash_probe_fdt() to locate SPI by FDT nodeSimon Glass
This allows us to put the SPI flash chip inside the SPI interface node, with U-Boot finding the correct bus and chip select automatically. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-11-12spi: define SPI_XFER_ONCENikita Kiryanov
The flag combination "SPI_XFER_BEGIN | SPI_XFER_END" is a common use case of spi_xfer, and it can easily cause an already long line (spi_xfer takes 5 parameters) to go over the 80 character limit. define SPI_XFER_ONCE to be a shorter version of the above flag combination. Cc: Tom Rini <trini@ti.com> Cc: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2013-11-12spi: omap3: add support for more word lengthsNikita Kiryanov
Current implementation only supports 8 bit word lengths, even though omap3 can handle anything between 4 and 32. Update the spi interface to support changing the SPI word length, and implement it in omap3_spi driver to support the full range of possible word lengths. This implementation is backwards compatible by defaulting to the old behavior of 8 bit word lengths. Also, it required a change to the omap3_spi non static I/O functions, but since they are not used anywhere else, no collateral changes are required. Cc: Tom Rini <trini@ti.com> Cc: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2013-10-16sf: Minor cleanups.Jagannadha Sutradharudu Teki
- Add comments. - Renamed few macros. - Add tabs. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Signed-off-by: Bo Shen <voice.shen@atmel.com>
2013-10-07sf: Minor cleanupsJagannadha Sutradharudu Teki
- Add spaces, tabs - Commenting. - Rearrange code. - Add static qualifier for missing func. - Remove memory_map from ramtron.c - Ramtron: spi_flash_internal.h -> sf_internal.h Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2013-10-07sf: Add memory mapped read supportPoddar, Sourav
Qspi controller can have a memory mapped port which can be used for data read. Added support to enable memory mapped port read. This patch enables the following: - It enables exchange of memory map address between mtd and qspi through the introduction of "memory_map" flag. - Add support to communicate to the driver that memory mapped transfer is to be started through introduction of new flags like "SPI_XFER_MEM_MAP" and "SPI_XFER_MEM_MAP_END". This will enable the spi controller to do memory mapped configurations if required. Signed-off-by: Sourav Poddar <sourav.poddar@ti.com> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
2013-10-07spi: spi cleanupsJagannadha Sutradharudu Teki
- Rearranged multi-line comment style. - Add tabs. - Add spaces. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2013-06-26cros: exynos: add SPI support for cros_ecHung-ying Tyan
This patch adds SPI support for carrying out the cros_ec protocol. Signed-off-by: Hung-ying Tyan <tyanh@chromium.org> Signed-off-by: Randall Spangler <rspangler@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2013-06-03spi: Add support for preamble bytesRajeshwari Shinde
A SPI slave may take time to react to a request. For SPI flash devices this time is defined as one bit time, or a whole byte for 'fast read' mode. If the SPI slave is another CPU, then the time it takes to react may vary. It is convenient to allow the slave device to tag the start of the actual reply so that the host can determine when this 'preamble' finishes and the actual message starts. Add a preamble flag to the available SPI flags. If supported by the driver then it will ignore any received bytes before the preamble on each transaction. This ensures that reliable communication with the slave is possible. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
2013-03-19spi: Add parameter for maximum write sizeSimon Glass
Some SPI controllers (e.g. Intel ICH) have a limit on the number of SPI bytes that can be written at a time. Add this as a parameter so that clients of the SPI interface can respect this value. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-19spi: Add function to allocate a new SPI slaveSimon Glass
At present it is difficult to extend the SPI structure since all drivers allocate it themselves, and few of them zero all fields. Add a new function spi_alloc_slave() which can be used by SPI drivers to perform this allocation, and thus ensure that all drivers can better cope with SPI structure changes. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-04-29powerpc: eSPI and eSPI controller supportMingkai Hu
Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com> Singed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com> Signed-off-by: Shaohui Xie <b21989@freescale.com> Cc: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-25spi: add spi_set_speed funcThomas Chou
This func helps mmc_spi driver set correct speed for mmc/sd, as mmc card needs 400KHz clock for spi mode initialization. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-07-01Move conditional compilation of MPC8XXX SPI driver to MakefileBen Warren
2008-06-03SPI API improvementsHaavard Skinnemoen
This patch gets rid of the spi_chipsel table and adds a handful of new functions that makes the SPI layer cleaner and more flexible. Instead of the spi_chipsel table, each board that wants to use SPI gets to implement three hooks: * spi_cs_activate(): Activates the chipselect for a given slave * spi_cs_deactivate(): Deactivates the chipselect for a given slave * spi_cs_is_valid(): Determines if the given bus/chipselect combination can be activated. Not all drivers may need those extra functions however. If that's the case, the board code may just leave them out (assuming they know what the driver needs) or rely on the linker to strip them out (assuming --gc-sections is being used.) To set up communication parameters for a given slave, the driver needs to call spi_setup_slave(). This returns a pointer to an opaque spi_slave struct which must be passed as a parameter to subsequent SPI calls. This struct can be freed by calling spi_free_slave(), but most driver probably don't want to do this. Before starting one or more SPI transfers, the driver must call spi_claim_bus() to gain exclusive access to the SPI bus and initialize the hardware. When all transfers are done, the driver must call spi_release_bus() to make the bus available to others, and possibly shut down the SPI controller hardware. spi_xfer() behaves mostly the same as before, but it now takes a spi_slave parameter instead of a spi_chipsel function pointer. It also got a new parameter, flags, which is used to specify chip select behaviour. This may be extended with other flags in the future. This patch has been build-tested on all powerpc and arm boards involved. I have not tested NIOS since I don't have a toolchain for it installed, so I expect some breakage there even though I've tried fixing up everything I could find by visual inspection. I have run-time tested this on AVR32 ATNGW100 using the atmel_spi and DataFlash drivers posted as a follow-up. I'd like some help testing other boards that use the existing SPI API. But most of all, I'd like some comments on the new API. Is this stuff usable for everyone? If not, why? Changed in v4: - Build fixes for various boards, drivers and commands - Provide common struct spi_slave definition that can be extended by drivers - Pass a struct spi_slave * to spi_cs_activate and spi_cs_deactivate - Make default bus and mode build-time configurable - Override default SPI bus ID and mode on mx32ads and imx31_litekit. Changed in v3: - Add opaque struct spi_slave for controller-specific data associated with a slave. - Add spi_claim_bus() and spi_release_bus() - Add spi_free_slave() - spi_setup() is now called spi_setup_slave() and returns a struct spi_slave - soft_spi now supports four SPI modes (CPOL|CPHA) - Add bus parameter to spi_setup_slave() - Convert the new i.MX32 SPI driver - Convert the new MC13783 RTC driver Changed in v2: - Convert the mpc8xxx_spi driver and the mpc8349emds board to the new API. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Tested-by: Guennadi Liakhovetski <lg@denx.de>
2008-04-18New i.MX31 SPI driverGuennadi Liakhovetski
This is an SPI driver for i.MX and MXC based SoCs from Freescale. So far only implemented and tested on i.MX31, can with a modified register layout and definitions be used for i.MX27, I think, MXC CPUs have similar SPI controllers too. Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2002-09-26Initial revisionwdenk
