path: root/include/spartan3.h
2010-03-24add block write function to spartan3 slave serial loadWolfgang Wegner
Using seperate function calls for each bit-bang of slave serial load can be painfully slow. This patch adds the possibility to supply a block write function that loads the complete block of data in one call (like it can already be done with Altera FPGAs). On an MCF5373L (240 MHz) loading an XC3S4000 this reduces the load time from around 15 seconds to around 3 seconds Signed-off-by: Wolfgang Wegner <w.wegner at astro-kom.de>
2009-10-03fpga: Remove relocation fixupsPeter Tyser
PPC boards are the only users of the current FPGA code which is littered with manual relocation fixups. Now that proper relocation is supported for PPC boards, remove FPGA manual relocation. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-09-22Fix Spartan-3 definitions.Laurent Pinchart
A few Spartan-3 definitions erroneously use Spartan-3E size constants. This patch fixes them. Signed-off-by: Laurent Pinchart <laurentp@cse-semaphore.com>
2008-09-22Remove duplicate Spartan-3E definition.Laurent Pinchart
Signed-off-by: Laurent Pinchart <laurentp@cse-semaphore.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-01-09Add new Xilinx Spartan FPGA typesMatthias Fuchs
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2008-01-09Add pre and post configuration callbacks for Spartan FPGAsMatthias Fuchs
This patch adds a post configuration callback for Spartan2/3 FPGAs. pre and post configuration callback are now optional and not called when the function pointer is set to NULL. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2007-08-11add image size and descriptors for Spartan 3E FPGA chipsBruce Adler
Spartan 3E image sizes taken from Table 1-4 in Xilinx UG332 (v1.1) Signed-off by: Bruce Adler <bruce.adler@ccpu.com>
2005-09-25Add Xilinx Spartan3 family FPGA supportWolfgang Denk
Patch by Kurt Stremerch, 14 February 2005
