path: root/include/soc.h
2021-02-02common: Drop asm/global_data.h from common headerSimon Glass
Move this out of the common header and include it only where needed. In a number of cases this requires adding "struct udevice;" to avoid adding another large header or in other cases replacing / adding missing header files that had been pulled in, very indirectly. Finally, we have a few cases where we did not need to include <asm/global_data.h> at all, so remove that include. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2020-07-25dm: soc: Introduce UCLASS_SOC for SOC ID and attribute matchingDave Gerlach
Introduce UCLASS_SOC to be used for SOC identification and attribute matching based on the SoC ID info. This allows drivers to be provided for SoCs to retrieve SoC identifying information and also for matching device attributes for selecting SoC specific data. This is useful for other device drivers that may need different parameters or quirks enabled depending on the specific device variant in use. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Dave Gerlach <d-gerlach@ti.com>
2020-07-24Revert "Merge tag 'dm-pull-20jul20' of git://git.denx.de/u-boot-dm"Tom Rini
This reverts commit 5d3a21df6694ebd66d5c34c9d62a26edc7456fc7, reversing changes made to 56d37f1c564107e27d873181d838571b7d7860e7. Unfortunately this is causing CI failures: https://travis-ci.org/github/trini/u-boot/jobs/711313649 Signed-off-by: Tom Rini <trini@konsulko.com>
2020-07-20dm: soc: Introduce UCLASS_SOC for SOC ID and attribute matchingDave Gerlach
