path: root/include/smbios.h
2016-10-19smbios: Expose in efi_loader as tableAlexander Graf
We can pass SMBIOS easily as EFI configuration table to an EFI payload. This patch adds enablement for that case. While at it, we also enable SMBIOS generation for ARM systems, since they support EFI_LOADER. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-19smbios: Generate type 4 on non-x86 systemsAlexander Graf
The type 4 table generation code is very x86 centric today. Refactor things out into the device model cpu class to allow the tables to get generated for other architectures as well. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-10-19smbios: Allow compilation on 64bit systemsAlexander Graf
The SMBIOS generation code passes pointers as u32. That causes the compiler to warn on casts to pointers. This patch moves all address pointers to uintptr_t instead. Technically u32 would be enough for the current SMBIOS2 style tables, but we may want to extend the code to SMBIOS3 in the future which is 64bit address capable. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-19x86: Move smbios generation into arch independent directoryAlexander Graf
We will need the SMBIOS generation function on ARM as well going forward, so let's move it into a non arch specific location. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
