path: root/include/serial.h
2017-07-03powerpc: remove 4xx supportHeiko Schocher
There was for long time no activity in the 4xx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in 4xx, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-16powerpc, 5xx: remove some "5xx" remainsHeiko Schocher
we removed 5xx support. So delete some forgotten remains. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-16powerpc, 82xx: remove some missed mpc82xx remainsHeiko Schocher
we removed 82xx support. Missed some 82xx remains, remove them now. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-16powerpc, 5xxx, 512x: remove support for mpc5xxx and mpc512xHeiko Schocher
There was for long time no activity in the mpx5xxx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in mpc5xxx, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2016-05-27board: am335x: Allow to choose serial device dynamicallyLokesh Vutla
Different AM335x based platforms have different serial consoles. As serial console is Kconfig option a separate defconfig has to be created for each platform. So pass the serial device dynamically. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-10-23serial: remove altera serial initializationsThomas Chou
Both altera_jtag_serial_initialize() and altera_serial_initialize() are no longer used after they are converted to driver model. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Marek Vasut <marex@denx.de>
2015-02-24ARM: remove cm4008 and cm41xx board supportMasahiro Yamada
These are still non-generic boards. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Greg Ungerer <greg.ungerer@opengear.com> Acked-by: Marek Vasut <marex@denx.de>
2015-02-24ARM: remove jadecpu board supportMasahiro Yamada
This is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Matthias Weisser <weisserm@arcor.de> Acked-by: Marek Vasut <marex@denx.de>
2014-11-04serial: add prototypes for init functionsJeroen Hofstee
While at it, sort them. Cc: Tom Rini <trini@ti.com> Cc: Simon Glass <sjg@chromium.org> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-09-10dm: Add a uclass for serial devicesSimon Glass
Serial devices support simple byte input/output and a few operations to find out whether data is available. Add a basic uclass for serial devices to be used by drivers that are converted to driver model. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-08-20ppc4xx: Remove support for PPC405CR CPUsMatthias Fuchs
This patch removes support for the APM 405CR CPU. This CPU is EOL and no board uses this chip. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2013-01-16Tegra30: Add generic Tegra30 build supportTom Warren
This patch adds basic Tegra30 (T30) build support - no specific board is targeted. Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2012-10-17serial: Implement default_serial_puts()Marek Vasut
U-Boot contains a lot of duplicit implementations of serial_puts() call which just pipes single characters into the port in loop. Implement function that does this behavior into common code, so others can make easy use of it. This function is called default_serial_puts() and it's sole purpose is to call putc() in loop on the whole string passed to it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com>
2012-10-15serial: Remove CONFIG_SERIAL_MULTI from remaining sourcesMarek Vasut
Remove the parts depending either on disabled CONFIG_SERIAL_MULTI or ifdefs around CONFIG_SERIAL_MULTI parts since CONFIG_SERIAL_MULTI is now enabled by default. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de>
2012-10-15serial: zoom2: Remove zoom2 serial prototypes from serial.hMarek Vasut
Remove the prototypes for zoom2_serial_deviceN from serial.h . This can't be done right away, as they are referenced from the zoom2 config file. Therefore, adjust the code so the config file only specifies number of the port. Then, replace the simple return in default_serial_console() with a switch across possible values, which returns the zoom2_serial_deviceN . With such adjustment in place, the exported prototypes in serial.h can be safely removed. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com>
2012-10-15serial: bfin: Adjust serial_register_bfin_uart()Marek Vasut
Rename the serial_register_bfin_uart() to bfin_initialize_serial() to be consistent with the rest of the naming. Next, remove it's prototype from serial.h and properly insert it into serial.c as the rest of the serial initialization functions. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-15serial: bfin: Remove the bfin_serialN_device exports from serial.hMarek Vasut
Remove the exports from serial.h as they are only used in the blackfin serial driver. Furthermore, they are only used for registration, which is handled already inside that driver and default_serial_port() call, which is also handled in that driver. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-15serial: ns16550: Move serial registration from serial_initialize()Marek Vasut
Move the registration of eserialN_device ports from default serial_initialize() into driver specific function called from serial_initialize(). This slims down the serial_initialize() call to a bare tracker of all possible serial port registration routines in U-Boot. The newly implemented ns16550_serial_initialize() function, which is implemented inside of the ns16550 serial driver allows encapsulation of eserialN_device within the ns16550 serial driver itself. Also, remove the exports of eserialN_device from include/serial.h as they are no longer needed. This is simply because the implementation of default_serial_console() is wrapped into the ns16550 serial driver and the default console is picked by CONFIG_SERIAL<N> macro in config file. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Michal Simek <monstr@monstr.eu>
2012-10-15serial: mpc512x: Move serial registration from serial_initialize()Marek Vasut
Move the registration of serialN_device ports from default serial_initialize() into driver specific function called from serial_initialize(). This slims down the serial_initialize() call to a bare tracker of all possible serial port registration routines in U-Boot. The newly implemented mpc512x_serial_initialize() function, which is implemented inside of the mpc512x serial driver allows encapsulation of serialN_device within the mpc512x serial driver itself. Also, remove the exports of serialN_device from include/serial.h as they are no longer needed. This is simply because the implementation of default_serial_console() is wrapped into the mpx512x serial driver and the default console is picked by CONFIG_SERIAL<N> macro in config file. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de>
2012-10-15serial: microblaze: Move serial registration from serial_initialize()Marek Vasut
Move the registration of xuartlite_serialN_device ports from default serial_initialize() into driver specific function called from serial_initialize(). This slims down the serial_initialize() call to a bare tracker of all possible serial port registration routines in U-Boot. The newly implemented xuartlite_serial_initialize() function, which is implemented inside of the serial_xuartlite driver allows encapsulation of xuartlite_serialN_device within the serial_xuartlite driver itself. Also, remove the exports of xuartlite_serialN_device from include/serial.h as they are no longer needed. This is simply because the implementation of default_serial_console() is wrapped into the serial_xuartlite driver and the default console is picked by CONFIG_SERIAL<N> macro in config file. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> Cc: Michal Simek <monstr@monstr.eu>
2012-10-15serial: zynq: Move serial registration from serial_initialize()Tom Rini
Move the registration of zynq_serialN_device ports from default serial_initialize() into driver specific function called from serial_initialize(). This slims down the serial_initialize() call to a bare tracker of all possible serial port registration routines in U-Boot. The newly implemented zynq_serial_initialize() function, which is implemented inside of the serial_zynq driver allows encapsulation of zynq_serialN_device within the serial_zynq driver itself. Also, remove the exports of zynq_serialN_device from include/serial.h as they are no longer needed. This is simply because the implementation of default_serial_console() is wrapped into the serial_zynq driver and the default console is picked by CONFIG_SERIAL<N> macro in config file. Signed-off-by: Tom Rini <trini@ti.com>
2012-10-15serial: s5p: Move serial registration from serial_initialize()Marek Vasut
Move the registration of s5p_serialN_device ports from default serial_initialize() into driver specific function called from serial_initialize(). This slims down the serial_initialize() call to a bare tracker of all possible serial port registration routines in U-Boot. The newly implemented s5p_serial_initialize() function, which is implemented inside of the serial_s5p driver allows encapsulation of s5p_serialN_device within the serial_s5p driver itself. Also, remove the exports of s5p_serialN_device from include/serial.h as they are no longer needed. This is simply because the implementation of default_serial_console() is wrapped into the serial_s5p driver and the default console is picked by CONFIG_SERIAL<N> macro in config file. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> Cc: Minkyu Kang <mk7.kang@samsung.com>
2012-10-15serial: pxa: Move serial registration from serial_initialize()Marek Vasut
Move the registration of serial_XXuart ports from default serial_initialize() into driver specific function called from serial_initialize(). This slims down the serial_initialize() call to a bare tracker of all possible serial port registration routines in U-Boot. The newly implemented pxa_serial_initialize() function, which is implemented inside of the serial_pxa driver allows encapsulation of serial_XXuart within the serial_pxa driver itself. Also, remove the exports of serial_XXuart from include/serial.h as they are no longer needed. This is simply because the implementation of default_serial_console() is wrapped into the serial_pxa driver and the default console is picked by CONFIG_CONS_IDX macro in config file. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com>
2012-10-15serial: s3c24xx: Move serial registration from serial_initialize()Marek Vasut
Move the registration of s3c24xx_serialN_device ports from default serial_initialize() into driver specific function called from serial_initialize(). This slims down the serial_initialize() call to a bare tracker of all possible serial port registration routines in U-Boot. The newly implemented s3c24xx_serial_initialize() function, which is implemented inside of the serial_s3c24xx driver allows encapsulation of s3c24xx_serialN_device within the serial_s3c24xx driver itself. Also, remove the exports of s3c24xx_serialN_device from include/serial.h as they are no longer needed. This is simply because the implementation of default_serial_console() is wrapped into the serial_s3c24xx driver and the default console is picked by CONFIG_SERIAL<N> macro in config file. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> Cc: C Nauman <cnauman@diagraph.com>
2012-10-15serial: Rename .init() and .uninit() in serial_deviceMarek Vasut
Rename .init() to .start() and .uninit() to .stop() in struct serial_device. This allows aligning struct serial_device with closer to struct stdio_dev. The real goal here is to allow these two structures to converge together and eventually make one to be a superset of the other. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Tom Rini <trini@ti.com>
2012-10-15serial: Coding style cleanup of struct serial_deviceMarek Vasut
Do a simple cleanup of the struct serial_device and align it with current coding style. Checkpatch now reports no errors. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com>
2012-10-04serial: Add Zynq serial driverMichal Simek
The driver is used on Xilinx Zynq platform. Signed-off-by: Michal Simek <monstr@monstr.eu> CC: Joe Hershberger <joe.hershberger@gmail.com> CC: Marek Vasut <marex@denx.de> Acked-by: Marek Vasut <marex@denx.de>
2012-09-11serial: Support serial multi for MicroblazeMichal Simek
enable serial multi for Microblaze. Signed-off-by: Michal Simek <monstr@monstr.eu> Acked-by: Stephan Linz <linz@li-pro.net>
2012-09-01tegra20: rename tegra2 -> tegra20Allen Martin
This is make naming consistent with the kernel and devicetree and in preparation of pulling out the common tegra20 code. Signed-off-by: Allen Martin <amartin@nvidia.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Tested-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-03-18net/miiphy/serial: drop duplicate "NAMESIZE" defineMike Frysinger
A few subsystems are using the same define "NAMESIZE". This has been working so far because they define it to the same number. However, I want to change the size of eth_device's NAMESIZE, so rather than tweak the define names, simply drop references to it. Almost no one does, and the handful that do can easily be changed to a sizeof(). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-12-19x86: Initial commit for running as a coreboot payloadGabe Black
Add a target for running u-boot as a coreboot payload in boards.cfg, a board, CPU and a config. This is a skeleton implementation which always reports the size of memory as 64 MB. Signed-off-by: Gabe Black <gabeblack@chromium.org>
2011-12-05serial: constify serial_assign()Gerlando Falauto
Signed-off-by: Gerlando Falauto <gerlando.falauto@keymile.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-12-05serial: cosmetic checkpatch complianceGerlando Falauto
2011-10-09serial: uartlite: Support for SERIAL_MULTIMichal Simek
Add support for SERIAL MULTI for uartlite. Signed-off-by: Michal Simek <monstr@monstr.eu>
2011-08-02Merge branch 'master' of git://git.denx.de/u-boot-blackfinWolfgang Denk
* 'master' of git://git.denx.de/u-boot-blackfin: Blackfin: jtag-console: fix timer usage Blackfin: switch to common display_options() Blackfin: serial: move early debug strings into .rodata section Blackfin: adi boards: also set stderr to nc with helper Blackfin: update anomaly lists to latest public info Blackfin: serial: convert to bfin_{read,write} helpers Blackfin: split out async setup Blackfin: adi boards: enable pretty flash progress output Blackfin: drop unused dma.h header from start code Blackfin: portmux: allow header to be included in assembly files Blackfin: cm-bf537e/cm-bf537u/tcm-bf537: enable mmc_spi support Blackfin: cm-bf537e/cm-bf537u/tcm-bf537: update network settings Blackfin: sync MMR read/write helpers with Linux Blackfin: gpio: optimize free path a little Blackfin: post: setup default CONFIG_SYS_POST_WORD_ADDR Blackfin: uart: fix printf warning Blackfin: add init.elf helper code Blackfin: dont reset SWRST on newer bf526 parts Blackfin: adi boards: enable multi serial support by default Blackfin: uart: add multiple serial support Blackfin: uart: move debug buffers into local bss
2011-07-26serial: implement common uart post testMike Frysinger
The current arch/driver specific UART posts basically boil down to setting the UART to loop back mode, then reading and writing data. If we ignore the loop back part, the rest can be built upon the existing common serial API. So let's do just that. First add a call back for serial drivers to implement loop back control. Then write a post test that walks all of the serial drivers, puts them into loop back mode, and verifies that reading/writing at all the diff baud rates is OK. If a serial driver doesn't support loop back mode (either it can't or it hasn't done so yet), then skip it. This should allow for people to easily migrate to the new post test with existing serial drivers. I haven't touched the few already existing uart post tests as I don't the hardware or knowledge of converting them over. So I've marked the new test as weak which will allow the existing tests to override the default until they are converted. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-26serial: drop useless ctlr fieldMike Frysinger
The multi serial support has a "ctlr" field which almost no one uses, but everyone is forced to set to useless strings. So punt it. Funny enough, the only code that actually reads this field (the mpc8xx driver) has a typo where it meant to look for the SCC driver. Fix it while converting the check to use the name field. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Heiko Schocher <hs@denx.de> CC: Anatolij Gustschin <agust@denx.de> CC: Tom Rix <Tom.Rix@windriver.com> CC: Minkyu Kang <mk7.kang@samsung.com> CC: Craig Nauman <cnauman@diagraph.com> CC: Marek Vasut <marek.vasut@gmail.com> CC: Prafulla Wadaskar <prafulla@marvell.com> CC: Mahavir Jain <mjain@marvell.com>
2011-07-12Blackfin: uart: add multiple serial supportMike Frysinger
This brings CONFIG_SERIAL_MULTI support to the Blackfin on-chip UARTs. Ends up adding only ~512bytes per additional UART. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-02-21serial: Add Tegra2 serial port supportTom Warren
2010-09-08Merge branch 'master' of git://git.denx.de/u-boot-samsungWolfgang Denk
2010-08-26ARMV7: S5P: rename from CONFIG_S5PC1XX to CONFIG_S5PMinkyu Kang
Use the same configuration around S5P SoCs. (s5pc100, s5pc110, s5pc210 and so on) Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2010-08-10ARM: Add support for MB86R0x SoCsMatthias Weisser
Signed-off-by: Matthias Weisser <weisserm@arcor.de>
2010-05-06x86: Use CONFIG_SERIAL_MULTIGraeme Russ
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2010-04-30SAMSUNG: serial: modify name from s5pc1xx to s5pMinkyu Kang
Because of other s5p series SoC will use these serial functions, modify function's name and structure's name. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2010-04-24mpc5121: add PSC serial communication routinesAnatolij Gustschin
2010-04-24mpc512x: add multi serial PSC supportAnatolij Gustschin
Extend mpc512x serial driver to support multiple PSC ports. Subsequent patches for PDM360NG board support make use of this functionality by defining CONFIG_SERIAL_MULTI in the board config file. Additionally the used PSC devices are specified by defining e.g. CONFIG_SYS_PSC1, CONFIG_SYS_PSC4 and CONFIG_SYS_PSC6. Support for PSC devices other than 1, 3, 4 and 6 is not added by this patch because these aren't used currently. In the future it can be easily added using DECLARE_PSC_SERIAL_FUNCTIONS(N) and INIT_PSC_SERIAL_STRUCTURE(N) macros in cpu/mpc512x/serial.c. Additionally you have to add code for registering added devices in serial_initialize() in common/serial.c. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2010-04-24serial: struct serial_device: add uninit() entry for driversAnatolij Gustschin
Subsequent patch extends mpc512x serial driver to support multiple PSC ports. The driver will provide an uninit() function to stop the serial controller and to disable the controller's clock. Adding uninit() entry to struct serial_device allows disabling the serial controller after usage of a stdio serial device. This patch adds uninit() entry to the struct serial_device and fixes initialization of this structure in the code accordingly. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2009-12-20OMAP3 zoom2 Use usbtty if the debug board is not connected.Tom Rix
The preferred serial output comes from the debug board. When the debug board is disconnected, fall back on using usbtty from the usb connector on the Zoom2 board. This shows up as /dev/ttyACM0 in a linux host. Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-12-20USBTTY make some function declarations easier to use.Tom Rix
Zoom2 needs to use these declarations and the include directory is a better place from them than in the middle of the driver directory. It did not make sense to create a new file for just a couple of lines so they were appended to the serial.h Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-10-13s5pc1xx: support serial driverMinkyu Kang
This patch includes the serial driver for s5pc1xx. s5pc1xx uart driver needs own register setting and clock configuration. So, need to special driver. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
